daguq
February 22, 2025, 7:51am
1
Hello, everyone. I am trying to override the kitty package to build version 0.39.1, which is not yet available in nixpkgs.
Here’s what I have put in my configuration file
(unstable.kitty.overrideAttrs (oldAttrs: rec{
pname = "kitty";
version = "0.39.1";
format = "other";
src = fetchFromGitHub {
owner = "kovidgoyal";
repo = "kitty";
tag = "v${version}";
hash = "sha256-Cgbs9tdEGKhDShNh3M8N1UdRJu4aMylr9xLOGLpDAZE";
goModules = (buildGo123Module {
pname = "kitty-go-modules";
inherit src version;
vendorHash = "sha256-j5ToLPQeaf4xIaziBAROYZNvoaOx2TkTcuY95X4Neqc";
}).goModules;
But, when I run the command nixos-rebuild --switch, it builds version 0.39.0. Why is this happening? What is wrong with my configuration?
Where did you put it? Are you using any kitty module?
daguq
February 22, 2025, 8:30am
3
I have put it in a packages.nix file, which I import in configuration.nix.
I am using home-manager to configure kitty, if that is relevant.
Here is my packages.nix file
{ config, lib, inputs,...}:
system = "x86_64-linux";
unstable = import inputs.nixpkgs-unstable { system = "x86_64-linux"; config.allowUnfree = true; };
stable = import inputs.nixpkgs-stable { system = "x86_64-linux"; config.allowUnfree = true; };
environment.systemPackages = with stable; [
pname = "kitty";
version = "0.39.1";
format = "other";
repo = "kitty";
}).goModules;
Yes it is relevant, you’d have to explicitly set programs.kitty.package.
daguq
February 22, 2025, 9:19am
5
It is currently set to unstable.kitty;
What do I set it, so that it uses the overridden package?
The full override expression you wrote.
daguq
February 22, 2025, 10:35am
7
Thank you, that solves it. Although, I have transformed it into an overlay and used it. I am including my complete configuration here, if anybody needs it in the future.
Here is my overwrite function I wrote down in kitty.nix:-
final: prev: {
kitty = prev.kitty.overrideAttrs (old: rec{
pname = "kitty";
version = "0.39.1";
format = "other";
src = prev.fetchFromGitHub {
repo = "kitty";
hash = "";
goModules =
(prev.buildGo123Module {
vendorHash = "";
}).goModules;
I’ve left the hashes empty, so that for future usage one can input the correct hashes.
Here’s how I have imported kitty.nix into my home.nix and packages.nix
{ config, pkgs, inputs, ... }:
unstable = import inputs.nixpkgs-unstable { system = "x86_64-linux"; config.allowUnfree = true; overlays = [ (import ./kitty.nix) ]; };
Now, it is possible to install/enable the package using unstable.kitty.
