We have a flake setup within which we override some packages with overlays, e.g. universal-ctags, to statically build them for darwin+linux, or otherwise modify them. Link to the flake where we apply the set of overlays and then create devShells, expose packages as outputs etc.
For universal-ctags, we also create a symlink from $out/bin/universal-ctags
to $out/bin/ctags
using postFixup
in overrideAttrs
. This would error out however, stating that the file already existed. Upon looking further (adding ls -l $out/bin
to postFixup
), I noticed that it was invoking the contents of my postFixup
twice. Sprinkling some builtins.trace
, I could see that the attributes to overrideAttrs
were being evaluated twice. The following builtins.trace
was giving the following output (first call prints the rhs of the oldAttrs.postFixup or "nada"
expr):
trace: nada
trace: # unideal -f here, theres a weird double-eval going on here
ln -sf $out/bin/ctags $out/bin/universal-ctags
You can reproduce the issue by running nix build 'github:Sourcegraph/sourcegraph/8c7718c1cc91150cb6772dc70ae8f0f8ded8356a#universal-ctags'
yourself.
Exploring further, this doesn’t happen when we make any of the following changes:
- Use
prev.universal-ctags.override{Attrs}
instead ofprev.pkgs{Static,Musl}.override{Attrs}
.- This is not a solution for us, as we specifically want to statically build them.
- Don’t shadow
universal-ctags
in the overlay aka assign the overriddenuniversal-ctags
to a new name likeuniversal-ctags' = prev.pkgsStatic.universal-ctags.override{Attrs}
- Possible solution but I feel this shouldn’t be necessary
Same issue happens in our overriding of comby in comby.nix, where we’re using prev.pkgsMusl.comby
with a postPatch
override. Overriding prev.comby
as opposed to prev.pkgsMusl.comby
also removes the double evaluation, but again not desirable for us as we want a musl-based comby.
Not sure if Im missing something in this post to help give context, so please do ask any questions I can help clarify. All links should be pinned to a specific commit so they won’t change. Thanks everyone : )
