Hi! I’m working to add vcpkg into nixpkgs. I’m having a problem because it tries to write into a lockfile into the nix store and I’m exploring idea on how to do it.
- Making the lock file a symlink to /run, but that feels a bit wrong
- Gently asking vcpkg to skip the lock and implement our own locking using flock
- Just skip the lock and tell our users to be careful (not ideal)
I just wanted some input before going forward with one of the options, thanks
Thank you for your insight. Now I also have to create a directory where it is expected to write files and read from them later. Since vcpkg is already creating a $HOME/.vcpkg/
directory I was thinking creating a subdirectory of that and let vcpkg write the build trees there. Is it an acceptable solution or is something more like /var/vpckg/buildtrees
actually preferable?
Hmm, actually on MacOS there is only /var/run
and it’s not writable by users by default. I’ll have to dig a bit more there.
