tl;dr: Just use pkgs.writeShellApplication. I sketch a full tutorial for packaging more complex shell scripts that you don’t write in-line, too, though.
Hrm, I have to say I’m not a big fan of that tutorial. It doesn’t explain much, and then ends up with a solution that is more complex than it needs to be. Let me give it a try.
The tutorial is right - simply running an arbitrary shell script in NixOS you will run into two problems:
- Shebang will often point to
/usr/bin or similar
- Dependencies will not be available on
$PATH, unless they’re already installed on the system and you run it from a shell that has $PATH set up correctly
This means we need to do two things:
- Make sure we patch the shebang of the script at build time
- Have some mechanism for setting up
$PATH when the script runs
The former is trivial (but I’ll show you the idiomatic way of doing that too), but the latter isn’t.
The way setting up paths is generally done in NixOS is to “wrap” the script (as you attempt), such that we first run a script that basically does export PATH=${all the bin directories of our dependencies} and then executes the script in question.
There is an alternative too, though, and that is simply adding a header looking like this to the script:
#!${runtimeShell}
# rest of script here
This is how pkgs.writeShellApplication is implemented. pkgs.writeShellApplication unfortunately also adds set -euo pipefail, which may not be what you want, but if you did want the very simple way of doing this, here’s the documentation for it.
Personally I think it’s a bit unclean, and it’s better suited for simple scripts that you write in nix files, or that are very close to things you are implementing in a nix config.
Actually packaging a shell script is better through the normal packaging primitive, stdenv.mkDerivation. This is where we can use all those fancy makeWrapper and patchShebangs things.
This looks something like this:
# This derivation expects to be built with `pkgs.callPackage`.
# If you build it any other way, just refer to these via `pkgs.stdenv`
# and such.
lib,
stdenv,
makeWrapper,
curl,
}: let
# Import from lib.
inherit (lib) makeBinPath;
# We use `rec` here so that we can reuse the `buildInputs` variable.
# While `rec` is considered an anti-pattern by some, in this case it
# means that we can override the variable and everything will still
# work.
stdenv.mkDerivation rec {
## Metadata
name = "test";
version = "0.1";
## Source
# This adds our shell script directly to the nix store. I'd advise
# against doing this in practice, but rather using the tarball or
# source directory that you're packaging. If we didn't import the
# file directly, we could completely skip the `unpackCmd` below.
# If your script is tiny enough that you don't need all this
# packaging, just use `writeShellApplication` instead, but this
# derivation is written for educational purposes!
src = ./test.sh;
## Dependencies
# See also https://nixos.org/manual/nixpkgs/stable/#variables-specifying-dependencies
# Fair warning, this is all about cross-compilation, which you
# hardly care about for shell scripts.
# `nativeBuildInputs` are the build inputs that will run on the
# build host natively, and are expected to create files that will
# run on the target host.
# The distinction is practically pointless for `makeWrapper`,
# because it produces shell scripts that are target-independent, but
# for completeness' sake I split it out.
nativeBuildInputs = [makeWrapper];
# These are the build inputs that are actually expected to run on
# the target host.
# *Normally* nix will inspect the output, and make sure that any of
# these whose paths end up in the output will also be installed as
# runtime dependencies. Since we're packaging a shell script,
# however, this doesn't work, because we rely on $PATH, so we need
# to use `makeWrapper`.
# I still like putting `buildInputs` in these kinds of packages
# because it's very explicit, and who knows, maybe one day nix will
# be smart enough to propagate these kinds of dependencies.
buildInputs = [curl];
# I get these wrong all the time, so if @Nobbz comes and scolds me,
# sorry!
## Source unpacking
# Nix will assume we are using a tarball of some sort by default,
# and try to unpack the shell script, which obviously fails, so we
# need to handle this ourselves.
# A real shell script we want to package probably comes with a
# directory, likely bundled in a tarball, so this wouldn't normally
# be necessary.
# See also https://nixos.org/manual/nixpkgs/stable/#ssec-unpack-phase
unpackCmd = ''
# $curSrc is the variable that contains the path to our source.
mkdir test-src
# We rename the file here, because when nix adds files to the
# store it adds a hash, which obviously we don't want for our
# shell script.
cp $curSrc test-src/test.sh
# Note that we don't have a build phase. You'd think that we would
# need one to patch our shebang, but actually,
# `stdenv.mkDerivation` patches all shebangs it can find by
# default in the `fixupPhase` (which comes after the build phase),
# so we don't have to worry about patching shebangs.
# See also https://nixos.org/manual/nixpkgs/stable/#ssec-fixup-phase
## Installation
installPhase = ''
# Before we wrap it, we need to actually install our script.
# For reference, -D creates leading directories, and m755 makes
# it root-read-write-exec, all other users read-exec. This is
# pretty standard for binaries, because this allows root to
# easily delete the file if need-be.
# In practice, on NixOS, the file will be read-only for all
# users, but it's the thought that counts.
# See also `man install`
install -Dm755 test.sh $out/bin/test.sh
# This is where we create the wrapping script that sets PATH.
# Note the single quotes around our makeBinPath - after all, this
# is just an argument to a binary executed by bash. While nix
# paths can technically never result in splitting, this makes it
# very explicit that we're putting something in bash args that may
# need escaping otherwise.
# See also https://nixos.org/manual/nixpkgs/stable/#fun-wrapProgram
wrapProgram $out/bin/test.sh --prefix PATH : '${makeBinPath buildInputs}'
Thorough explanation in comments
You can create a test.sh script that requires curl, build that file with something like nix build --impure --expr 'with import (builtins.getFlake "nixpkgs") {}; pkgs.callPackage ./test.nix {}', and then run the script as ./result/bin/test.sh - or just import it, callPackage it, and add the derivation to your environment.systemPackages or whatever.
