Hey all, Nix beginner here, hopefully this is the right place to ask this question.
I’m trying to create a derivation for a Yarn + Vite + Electron project which use the electron-forge CLI tool for packing, however I’m having some troubles. When I use the electron-forge package command inside the mkYarnPackage it fails with the EAI_AGAIN error when trying to download something from the internet (I suppose its trying to download the Electron binary, but I’m not sure if is only that), which make sense as in the nix build process the network access is disabled.
Giving some search, I did find this issue which indicated that in order to run the electron-forge offline I would need to populate the Electron binary cache myself, however I don’t really know how to do that using the nix language, as the cache should look something like this (reference):
├── a91b089b5dc5b1279966511344b805ec84869b6cd60af44f800b363bba25b915
│ └── electron-v15.3.1-darwin-x64.zip
So I’m stuck with that for quite some time now, I would love to know if someone already had this problem or if there is other path that I should take which would make packing this project easier.
Here is my current flake.nix config file:
description = "Dash project";
nixpkgs = {url = "github:NixOS/nixpkgs/nixos-23.11";};
nixpkgs-unstable = {url = "github:NixOS/nixpkgs/nixos-unstable";};
flake-utils = {url = "github:numtide/flake-utils";};
outputs = {
self,
nixpkgs,
nixpkgs-unstable,
flake-utils,
flake-utils.lib.eachDefaultSystem (system: let
inherit (pkgs.lib) optional optionals;
pkgs = import nixpkgs {inherit system;};
unstable = import nixpkgs-unstable {inherit system;};
electron = pkgs.electron_28;
executableName = "dash";
shellHook = ''
# Go to the user $SHELL
export PATH="''${PWD}/node_modules/.bin:''${PATH}"
export ELECTRON_OVERRIDE_DIST_PATH="${electron}/bin/"
$SHELL
with pkgs; {
formatter = nixpkgs.legacyPackages.${system}.alejandra;
devShell = pkgs.mkShell {
shellHook = shellHook;
buildInputs = [
nodejs
yarn
nodePackages.prettier
electron_28
packages.default = mkYarnPackage rec {
name = "dash";
src = ./.;
packageJSON = ./package.json;
yarnNix = ./yarn.nix;
nativeBuildInputs = [makeWrapper git];
buildPhase = ''
export ELECTRON_SKIP_BINARY_DOWNLOAD=1
# Runs the `electron-forge package` command
yarn --offline run package
installPhase = ''
# executable wrapper
makeWrapper '${electron}/bin/electron' "$out/bin/${executableName}"
distPhase = ''
true
And here is the logs of the failed build:
$ nix build
❯ Packaging application
❯ Packaging for x64 on linux
✖ Copying files
› getaddrinfo EAI_AGAIN github.com
◼ Preparing native dependencies
◼ Finalizing package
◼ Running postPackage hook
An unhandled rejection has occurred inside Forge:
RequestError: getaddrinfo EAI_AGAIN github.com
at ClientRequest.<anonymous> (/nix/store/lxn8fpla0kr11i5id9g0fgb615pi0k4x-dash-modules-1.0.0/node_modules/got/dist/source/core/index.js:970:111)
at Object.onceWrapper (node:events:632:26)
at ClientRequest.emit (node:events:529:35)
at ClientRequest.emit (node:domain:489:12)
at ClientRequest.origin.emit (/nix/store/lxn8fpla0kr11i5id9g0fgb615pi0k4x-dash-modules-1.0.0/node_modules/@szmarczak/http-timer/dist/source/index.js:43:20)
at TLSSocket.socketErrorListener (node:_http_client:501:9)
at TLSSocket.emit (node:events:517:28)
at TLSSocket.emit (node:domain:489:12)
at emitErrorNT (node:internal/streams/destroy:151:8)
at emitErrorCloseNT (node:internal/streams/destroy:116:3)
at processTicksAndRejections (node:internal/process/task_queues:82:21)
at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:108:26)
