Passing Environment Variable to nixos-rebuild
I have a nixos system flake in some directory ${FLAKE_PATH}.
I have a file ${FLAKE_PATH}/mutable_file I mutably map to ${HOME}/mutable_file.
I do this using home-manager’s mkOutOfStoreSymlink.
This allows me to version it in my flake but also make changes to it without having to rebuild the system.
Currently, I have to hardcode ${FLAKE_PATH}.
But I want to pass it in as an environment variable.
This works:
FLAKE_PATH='...' nix flake check --impure
where flake.nix is
  outputs = _: assert builtins.getEnv "FLAKE_PATH" != ""; {};
But for invocations of nixos-rebuild, it does not.
What would be the best way to pass that env var to nixos-rebuild? Will it be necessary to manually do the steps in nixos-rebuild?
How are you setting the envvar, and what is the exact rebuild command you’re running after you set the envvar?
I tried
export FLAKE_PATH="$(realpath "$(dirname "${0}")")"
sudo nixos-rebuild switch --impure --verbose --show-trace --flake '.'
and
FLAKE_PATH="..." sudo nixos-rebuild switch --impure --verbose --show-trace --flake '.'
Instead of sudo, use either sudo -E to preserve envvars, or --use-remote-sudo which will only run sudo when needed.
Perfect, that works:
sudo --preserve-env=FLAKE_PATH nixos-rebuild switch --impure ...
Thanks a lot!
