xusiai
February 27, 2024, 8:54pm
1
Running sudo nixos-rebuild results in:
error: builder for '/nix/store/jka5w6xgkkjz8bfcmz0x522lj3a0b3aq-etc.drv' failed with exit code 1;
last 1 log lines:
> mkdir: cannot create directory '/nix/store/p0kgcra5fyq0a4ny04cinln68dbrk3ia-etc/etc/pipewire/pipewire-pulse.d': Permission denied
For full logs, run 'nix log /nix/store/jka5w6xgkkjz8bfcmz0x522lj3a0b3aq-etc.drv'.
Nix log provide no additional information. If I disable pulse support the rebuild fails with the same permission issue but for a different dir (etc/wireplumber/bluetooth.lua.d) and so on.
- system: `"x86_64-linux"`
- host os: `Linux 6.7.5-xanmod1, NixOS, 24.05 (Uakari), 24.05.20240221.0e74ca9`
- multi-user?: `yes`
- sandbox: `yes`
- version: `nix-env (Nix) 2.19.3`
- nixpkgs: `/nix/store/gzf4zwcakda1nykn6h0avh45xhjhvsz4-source`
Damage
February 28, 2024, 1:24am
2
I had this or a very similar issue and it seemed to be the bluetooth config has changed. I commented out the following and seem to have had no adverse affects:
environment = {
etc = {
âwireplumber/bluetooth.lua.d/51-bluez-config.luaâ.text = ââ
bluez_monitor.properties = {
[âbluez5.enable-sbc-xqâ] = true,
[âbluez5.enable-msbcâ] = true,
[âbluez5.enable-hw-volumeâ] = true,
[âbluez5.headset-rolesâ] = â[ hsp_hs hsp_ag hfp_hf hfp_ag ]â
ââ;
variables = {
VK_ICD_FILENAMES = â/run/opengl-driver/share/vulkan/icd.d/amd_icd64.jsonâ;
# VK_ICD_FILENAMES = "/run/opengl-driver-32/share/vulkan/icd.d/amd_icd.i686.json";
(Ignore Vulkan variables)
Not sure what has chagewd, but hope this helps!
Babalas
February 29, 2024, 2:16am
3
Looks like it is the addition of pipewire-extra-config and wireplumber-configs. Do you something like
# pulse clients config
environment.etc."pipewire/pipewire-pulse.d/99-lowlatency.conf" = { ... }
hensou
March 1, 2024, 8:22am
4
It seems that in the latest version things have changed and now you need to specify configurations through services.pipewire.extraConfig.pipewire.
You can check the other configs here: options for services.pipewire
I guess it also changed for wireplumer configurations
Here is how my config looks like now after changing it to this new way:
services.pipewire = {
wireplumber.enable = true;
alsa.enable = true;
alsa.support32Bit = true;
pulse.enable = true;
jack.enable = true;
extraConfig = {
pipewire = {
"92-low-latency.conf" = {
context.properties = {
default.clock.rate = 48000;
default.clock.quantum = 1024;
default.clock.min-quantum = 1024;
default.clock.max-quantum = 1024;
riking
March 6, 2024, 10:06pm
5
That doesnât seem to work for me:
services.pipewire.wireplumber.configPackages."51-bluez-config.lua" = {
"bluez5.enable-sbc-xq" = true;
"bluez5.enable-msbc" = true;
"bluez5.enable-hw-volume" = true;
"bluez5.headset-roles" = [ "hsp_hs" "hsp_ag" "hfp_hf" "hfp_ag"];
error: A definition for option `services.pipewire.wireplumber.configPackages' is not of type `list of package'. Definition values:
How do I turn this into a package?
edit: yeah this is definitely a different type:
List of packages that provide WirePlumber configuration, in the form of share/wireplumber/*/*.lua files.
LV2 dependencies will be picked up from config packages automatically via passthru.requiredLv2Packages.
