I want to use a package in nur called netease music.But permittedInsecurePackages does not work.
Here is my minimal config:
description = "A very basic flake";
nixpkgs.url = "github:nixos/nixpkgs?ref=nixos-unstable";
nur.url = "github:nix-community/NUR";
outputs = { self, nixpkgs ,nur,...}: {
nixosConfigurations.art = nixpkgs.lib.nixosSystem {
system = "x86_64-linux";
modules = [
./configuration.nix
nur.nixosModules.nur
{ config, lib, pkgs, ... }:
imports =
./hardware-configuration.nix
# Use the systemd-boot EFI boot loader.
networking.hostName = "virt"; # Define your hostname.
# Pick only one of the below networking options.
# networking.wireless.enable = true; # Enables wireless support via wpa_supplicant.
networking.networkmanager.enable = true; # Easiest to use and most distros use this by default.
# Set your time zone.
time.timeZone = "Asia/Shanghai";
users.users.finger = {
isNormalUser = true;
extraGroups = [ "wheel" ]; # Enable ‘sudo’ for the user.
packages = with pkgs; [
# $ nix search wget
config.nur.repos.xddxdd.netease-cloud-music
vim # Do not forget to add an editor to edit configuration.nix! The Nano editor is also installed by default.
wget
just
git
# Enable the OpenSSH daemon.
system.stateVersion = "24.11"; # Did you read the comment?
nixpkgs.config.permittedInsecurePackages = [
"openssl"
nix = {
settings = {
experimental-features = [
"nix-command"
"flakes"
substituters = [
"https://mirror.sjtu.edu.cn/nix-channels/store"
"https://mirrors.tuna.tsinghua.edu.cn/nix-channels/store"
"https://mirrors.ustc.edu.cn/nix-channels/store"
channel.enable = false; # remove nix-channel related tools & configs, we use flakes instead.
# registry.nixpkgs.flake = nixpkgs;
