Hello NixOS Community,
I’m encountering a persistent and strange error while trying to configure my NixOS system. When running sudo nixos-rebuild switch, I consistently get the following error, even with a minimal configuration:
error: The option `hardware.graphics' does not exist. Definition values:
- In `/etc/nixos/configuration.nix': # (or previously /etc/nixos/hardware/nvidia.nix)
The really confusing part is that the file mentioned in the error message (/etc/nixos/configuration.nix in the minimal test case below) actually contains the correct syntax hardware.graphics.enable = true; when I check it with cat immediately before running the build. The error message incorrectly reports the definition value as { enable = true; }.
System Information:
- Channel: Currently set to nixos-24.05 (stable) after troubleshooting. Originally was on nixos-24.11.
$ sudo nix-channel --list
nixos https://nixos.org/channels/nixos-24.05
nixos-unstable https://nixos.org/channels/nixos-unstable # (Not currently used by 'nixos' channel)
IGNORE_WHEN_COPYING_START
content_copy download
Use code with caution.
IGNORE_WHEN_COPYING_END
- system.stateVersion: Set to “24.05” in the current minimal test configuration.
What I’ve Tried (Error Persists After Each Step):
- Verified Syntax: Quadruple-checked that hardware.graphics.enable = true; is correctly written in the relevant .nix file.
- Checked File Contents: Used cat /etc/nixos/configuration.nix (or the module file previously) right before nixos-rebuild switch to confirm the correct syntax is present.
- Modular vs. Main Config: The error occurred both when the option was in a separate module (/etc/nixos/hardware/nvidia.nix) and when placed directly in the main /etc/nixos/configuration.nix.
- Minimal Configuration: Reduced /etc/nixos/configuration.nix to the absolute minimum (shown below), importing only hardware-configuration.nix. The error still occurs.
- Searched for Conflicts: Ran sudo grep -R --include=‘*.nix’ “hardware.graphics = {” /etc/nixos/ - this command found nothing.
- Channel Switching: The error occurred on nixos-24.11 (unstable branch) and persists after switching the nixos channel to nixos-24.05 (stable) and updating stateVersion.
- Nix Store Maintenance: Ran sudo nix-collect-garbage -d and sudo nix-store --optimise.
- Restarted Nix Daemon: Ran sudo systemctl restart nix-daemon.service.
- Verified Nix Store: Ran sudo nix-store --verify --check-contents - completed without reporting errors.
Minimal /etc/nixos/configuration.nix (Reproduces the Error):
# /etc/nixos/configuration.nix (MINIMAL TEST CONFIG)
{ config, pkgs, lib, ... }:
imports = [ ./hardware-configuration.nix ];
# --- MINIMAL SETTINGS ---
networking.hostName = "nixos-graphics-test";
time.timeZone = "Europe/Warsaw";
i18n.defaultLocale = "ru_RU.UTF-8";
users.users.yakatze = {
isNormalUser = true;
extraGroups = [ "wheel" "networkmanager" "audio" "video" ];
shell = pkgs.zsh;
programs.zsh.enable = true;
nixpkgs.config.allowUnfree = true; # For NVIDIA drivers
# --- GRAPHICS & NVIDIA (DIRECTLY HERE) ---
hardware.graphics.enable = true; # Correct syntax is present here
hardware.nvidia = {
modesetting.enable = true;
open = true;
powerManagement.enable = true;
package = config.boot.kernelPackages.nvidiaPackages.stable;
boot.kernelParams = [ "nvidia-drm.modeset=1" ];
# Using stable channel version
system.stateVersion = "24.05";
Use code with caution. Nix
/etc/nixos/hardware-configuration.nix:
(This file seems standard, contains filesystems, boot modules, etc. - You might want to paste the content of your hardware-configuration.nix here if you think it’s relevant)
# Do not modify this file! It was generated by ‘nixos-generate-config’
# and may be overwritten by future invocations. Please make changes
# to /etc/nixos/configuration.nix instead.
{ config, lib, pkgs, modulesPath, ... }:
imports =
[ (modulesPath + "/installer/scan/not-detected.nix")
boot.initrd.availableKernelModules = [ "xhci_pci" "ahci" "usbhid" "usb_storage" "sd_mod" ];
boot.kernelModules = [ "kvm-amd" ];
boot.extraModulePackages = [ ];
fileSystems."/" =
{ device = "/dev/disk/by-uuid/843fb6cf-3a44-4262-a2ca-2c027cfc3098";
fsType = "ext4";
fileSystems."/boot" =
{ device = "/dev/disk/by-uuid/6155-128D";
fsType = "vfat";
options = [ "fmask=0077" "dmask=0077" ];
swapDevices = [ ];
networking.useDHCP = lib.mkDefault true;
# networking.interfaces.enp42s0.useDHCP = lib.mkDefault true;
nixpkgs.hostPlatform = lib.mkDefault "x86_64-linux";
hardware.cpu.amd.updateMicrocode = lib.mkDefault config.hardware.enableRedistributableFirmware;
I’m running out of ideas. It seems like Nix is evaluating the file incorrectly or using some cached/corrupted state, despite nix-store --verify reporting no issues.
Does anyone have suggestions on what could be causing Nix to misread the definition value for hardware.graphics.enable or why the option might appear non-existent even on the stable channel with a minimal config? Any further diagnostic steps I could take?
Thanks in advance for any help!
