Hello, I’m currently working on configuring my Python environments using either poetry
or poetry2nix
. I’ve provided my pyproject.toml, poetry.lock and run.py for reference, but I’m encountering an error after running python run.py -d
File "/home/sukhman/Downloads/stanford_nlp_assignments/a3/student/.venv/lib/python3.10/site-packages/torch/__init__.py", line 168, in _load_global_deps
ctypes.CDLL(lib_path, mode=ctypes.RTLD_GLOBAL)
File "/nix/store/pkj7cgmz66assy7l18zc7j992npb41nx-python3-3.10.12/lib/python3.10/ctypes/__init__.py", line 374, in __init__
self._handle = _dlopen(self._name, mode)
OSError: libcurand.so.10: cannot open shared object file: No such file or directory
During handling of the above exception, another exception occurred:
File "/home/sukhman/Downloads/stanford_nlp_assignments/a3/student/run.py", line 16, in <module>
from torch import nn, optim
File "/home/sukhman/Downloads/stanford_nlp_assignments/a3/student/.venv/lib/python3.10/site-packages/torch/__init__.py", line 228, in <module>
_load_global_deps()
File "/home/sukhman/Downloads/stanford_nlp_assignments/a3/student/.venv/lib/python3.10/site-packages/torch/__init__.py", line 189, in _load_global_deps
_preload_cuda_deps(lib_folder, lib_name)
File "/home/sukhman/Downloads/stanford_nlp_assignments/a3/student/.venv/lib/python3.10/site-packages/torch/__init__.py", line 154, in _preload_cuda_deps
raise ValueError(f"{lib_name} not found in the system path {sys.path}")
ValueError: libcublas.so.*[0-9] not found in the system path ['/home/sukhman/Downloads/stanford_nlp_assignments/a3/student', '/nix/store/pkj7cgmz66assy7l18zc7j992npb41nx-python3-3.10.12/lib/python310.zip', '/nix/store/pkj7cgmz66assy7l18zc7j992npb41nx-python3-3.10.12/lib/python3.10', '/nix/store/pkj7cgmz66assy7l18zc7j992npb41nx-python3-3.10.12/lib/python3.10/lib-dynload', '/home/sukhman/Downloads/stanford_nlp_assignments/a3/student/.venv/lib/python3.10/site-packages']
(student-py3.10)
NixOS system:
- system: `"x86_64-linux"`
- host os: `Linux 6.1.49, NixOS, 23.11 (Tapir), 23.11pre521611.e56990880811`
- multi-user?: `yes`
- sandbox: `yes`
- version: `nix-env (Nix) 2.17.0`
- channels(sukhman): `"home-manager, nixpkgs-unstable"`
- channels(root): `"home-manager, nixos"`
- nixpkgs: `/nix/var/nix/profiles/per-user/root/channels/nixos`
Thank you
