description = "A Python API for various tools I use at work.";
nixpkgs.url = github:NixOS/nixpkgs/nixos-22.05;
flake-utils.url = github:numtide/flake-utils;
devShell = pkgs.mkShell {
buildInputs = [
pkgs.gnumake
(pkgs.poetry2nix.mkPoetryEnv {
projectDir = ./.;
pkgs.python39Packages.poetry
shellHook = ''
export DJANGO_SETTINGS_MODULE=network_inventory.settings.local
However when I enter the shell I get this error and don’t know how to solve it.
[0/167 built, 4/9/77 copied (9.1/78.5 MiB), 8.1/35.8 MiB DL] fetching django-filter-22.1.tar.gz from https://cache.nixos.orgdirenv: ([/nix/store/a5kmn3sij0dlkxy5xxv7drs08k0qp267-direnv-2.31.0/bin/direnv export bash]) is taking a while to execute. Use CTRL-C to give up.
error: builder for '/nix/store/5axpdf5qb9fq2gx8c0iy2i8ajidszb9q-python3.9-findpython-0.2.2.drv' failed with exit code 2;
last 10 log lines:
> File "<frozen importlib._bootstrap>", line 1030, in _gcd_import
> File "<frozen importlib._bootstrap>", line 1007, in _find_and_load
> File "<frozen importlib._bootstrap>", line 972, in _find_and_load_unlocked
> File "<frozen importlib._bootstrap>", line 228, in _call_with_frames_removed
> File "<frozen importlib._bootstrap>", line 984, in _find_and_load_unlocked
> ModuleNotFoundError: No module named 'pdm'
For full logs, run 'nix log /nix/store/5axpdf5qb9fq2gx8c0iy2i8ajidszb9q-python3.9-findpython-0.2.2.drv'.
error: 1 dependencies of derivation '/nix/store/m7x3rrlj34m7dpjf78c87w0jlryw5519-python3-3.9.13-env.drv' failed to build
error: 1 dependencies of derivation '/nix/store/kq0qc849zp7ml1s9qww2bvifam9m2w2w-nix-shell-env.drv' failed to build
direnv: nix-direnv: renewed cache
direnv: export ~XDG_DATA_DIRS
I tried to add it as a dependency with poetry and I tried to add it as a dependency through the flake.nix. But both attempts didn’t really work.
In addition I tried to just provide Python and Poetry to the shell and then create the virtual environment with Poetry but every time I exit the shell the Poetry venv seems to break and I have to reinstall it, in order to work.
I actually got the solution today thanks to the Matrix chat for poetry2nix.
You need to add an override for the build dependency of that package.
Something like the following, where findpython is the package that is failing to build and pdm is the missing build dependency. You can add as many overrides as you need.
The best is that you add the overrides to the upstream poetry2nix package when you fixed them (https://github.com/nix-community/poetry2nix/blob/0c5bae34bee822876a2dbb1c62d89cd1b29b648d/overrides/build-systems.json)
