Poor audio quality on Lenovo Legion Pro 7 16iax10h
Hi, so I got a new Lenovo Legion Pro 7 16iax10h a while back and I’m currently dualbooting NixOS and Windows 11 on it.
I’ve noticed that the audio on NixOS is a lot poorer in quality compared to Windows, but I can’t really figure out what to do.
Currently I have a pretty basic NixOS Config, with not much going on, beyond enabling NixOS hardware options: https://github.com/grobo-chan/nixos-config
Does anyone have any suggestions on what to do to fix this?
If yes, please help, thanks!
Oh yea I should also put the lscpi -k output as well here
00:00.0 Host bridge: Intel Corporation Arrow Lake-HX 8p+16e cores Host Bridge (rev 01)
Subsystem: Lenovo Device 3d6c
00:01.0 PCI bridge: Intel Corporation Meteor Lake-H PCIe Root Port #12 (rev 10)
Kernel driver in use: pcieport
00:02.0 VGA compatible controller: Intel Corporation Arrow Lake-S [Intel Graphics] (rev 06)
Subsystem: Lenovo Device 800e
Kernel driver in use: i915
Kernel modules: i915, xe
00:04.0 Signal processing controller: Intel Corporation Device ad03 (rev 01)
Kernel driver in use: proc_thermal_pci
Kernel modules: processor_thermal_device_pci
00:06.0 PCI bridge: Intel Corporation Arrow Lake-HX PCIe Root Port #13 (rev 10)
00:07.0 PCI bridge: Intel Corporation Meteor Lake-P Thunderbolt 4 PCI Express Root Port #0 (rev 10)
00:0a.0 Signal processing controller: Intel Corporation Arrow Lake-HX Crash Log & Telemetry (rev 01)
Kernel driver in use: intel_vsec
Kernel modules: intel_vsec
00:0b.0 Processing accelerators: Intel Corporation Arrow Lake NPU (rev 01)
Kernel driver in use: intel_vpu
Kernel modules: intel_vpu
00:0d.0 USB controller: Intel Corporation Meteor Lake-P Thunderbolt 4 USB Controller (rev 10)
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:0d.2 USB controller: Intel Corporation Meteor Lake-P Thunderbolt 4 NHI #0 (rev 10)
Kernel driver in use: thunderbolt
Kernel modules: thunderbolt
00:14.0 RAM memory: Intel Corporation Arrow Lake-HX Shared SRAM (SOC-S) (rev 10)
Kernel driver in use: intel_pmc_ssram_telemetry
Kernel modules: intel_pmc_ssram_telemetry
00:1f.0 ISA bridge: Intel Corporation Arrow Lake-HX Direct eSPI Controller (rev 10)
00:1f.5 Serial bus controller: Intel Corporation Arrow Lake-HX SPI (flash) Controller (rev 10)
01:00.0 Non-Volatile memory controller: SK hynix PVC10 NVMe Solid State Drive (DRAM-less)
Subsystem: SK hynix PVC10 NVMe Solid State Drive (DRAM-less)
Kernel driver in use: nvme
Kernel modules: nvme
02:00.0 VGA compatible controller: NVIDIA Corporation GB205M [GeForce RTX 5070 Ti Mobile] (rev a1)
Kernel driver in use: nvidia
Kernel modules: nvidiafb, nouveau, nova_core, nvidia_drm, nvidia
02:00.1 Audio device: NVIDIA Corporation GB205 High Definition Audio Controller (rev a1)
Subsystem: NVIDIA Corporation Device 0000
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
80:14.0 USB controller: Intel Corporation 800 Series PCH USB 3.1 xHCI HC (rev 10)
80:14.5 Non-VGA unclassified device: Intel Corporation Device 7f2f (rev 10)
80:15.0 Serial bus controller: Intel Corporation 800 Series PCH I2C Controller #0 (rev 10)
Kernel driver in use: intel-lpss
Kernel modules: intel_lpss_pci
80:15.1 Serial bus controller: Intel Corporation Device 7f4d (rev 10)
80:15.2 Serial bus controller: Intel Corporation Device 7f4e (rev 10)
80:16.0 Communication controller: Intel Corporation 800 Series PCH HECI #1 (rev 10)
Kernel driver in use: mei_me
Kernel modules: mei_me
80:19.0 Serial bus controller: Intel Corporation 800 Series PCH I2C Controller #4 (rev 10)
80:19.1 Serial bus controller: Intel Corporation 800 Series PCH I2C Controller #5 (rev 10)
80:1c.0 PCI bridge: Intel Corporation 800 Series PCH PCIe Root Port #7 (rev 10)
80:1c.7 PCI bridge: Intel Corporation Device 7f3f (rev 10)
80:1d.0 PCI bridge: Intel Corporation 800 Series PCH PCIe Root Port #13 (rev 10)
80:1f.0 ISA bridge: Intel Corporation HM870 Chipset LPC/eSPI Controller (rev 10)
80:1f.3 Audio device: Intel Corporation 800 Series ACE (Audio Context Engine) (rev 10)
Kernel modules: snd_sof_pci_intel_mtl, snd_hda_intel
80:1f.4 SMBus: Intel Corporation 800 Series PCH SMBus Controller (rev 10)
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
80:1f.5 Serial bus controller: Intel Corporation 800 Series PCH SPI (flash) Controller (rev 10)
Kernel driver in use: intel-spi
Kernel modules: spi_intel_pci
81:00.0 Ethernet controller: Intel Corporation Ethernet Controller I226-V (rev 04)
Subsystem: Lenovo Device 3801
Kernel driver in use: igc
Kernel modules: igc
82:00.0 Network controller: MEDIATEK Corp. MT7927 802.11be 320MHz 2x2 PCIe Wireless Network Adapter [Filogic 380]
Subsystem: Lenovo Device e0e4
83:00.0 Non-Volatile memory controller: SK hynix PVC10 NVMe Solid State Drive (DRAM-less)
hey first of all try your sound in ubuntu live iso boot from it and try playing the same stuff there that way we can know whether this is nixos-specific :snowflake:
Just tried audio on a Ubuntu 25.10 Live USB
It also had poor audio quality
Definitely not nixos-specific, more of a linux thing in general
So I eventually ended up finding this GitHub Repository
https://github.com/nadimkobeissi/16iax10h-linux-sound-saga
But I have no idea how to implement all that in a “nix” way @.@;
as far as i can tell the solution is super complicated to apply on nixos, which is immutable, though possible, but honestly if i were you i would just use bluetooth speakers :speaker_high_volume:/ earbuds :headphone:or, lowkey going hardcore, plug in an external usb sound card / usb headphones. it’s much more easier than to patch Linux innit. the missing firmware is gonna eventually be fixed, maybe in a year or two (hopefully), but like i said i won’t be tinkering with it till then. is it worth the time ?.. :watch:
took another look at it today and i got the first few steps done by adding this to hardware-configuration.nix
hardware.firmware = [
  (pkgs.runCommand “legion-audio-patch” {
    src = ./aw88399_acf.bin;
    mkdir -p $out/lib/firmware
    cp -f $src $out/lib/firmware/aw88399_acf.bin
boot.kernelPatches = [
    name = “16iax10h-audio-linux-6.18”;
    patch = ./16iax10h-audio-linux-6.18.patch;
    structuredExtraConfig = with lib.kernel; {
      SND_HDA_SCODEC_AW88399 = module;
      SND_HDA_SCODEC_AW88399_I2C = module;
      SND_SOC_AW88399 = module;
      SND_SOC_SOF_INTEL_TOPLEVEL = yes;
      SND_SOC_SOF_INTEL_COMMON = module;
      SND_SOC_SOF_INTEL_MTL = module;
      SND_SOC_SOF_INTEL_LNL = module;
audio is a LOT better but the controls are a bit wonky
0 is mute and 10-100 all sounds the same
can’t really figure out how to patch the alsa config and install nvidia dkms drivers though, which atleast according to the repo should fix it
