Power saving settings don´t work
Hello,
I recently installed NixOS with Gnome on my Ideapad Pro 5 14AHP9.
My configuration looks like the following:
{ config, pkgs, ... }:
  imports =
      ./hardware-configuration.nix
  # Bootloader.
  # Enable networking
  # Set your time zone.
  time.timeZone = "Europe/Berlin";
  i18n.defaultLocale = "en_GB.UTF-8";
  i18n.extraLocaleSettings = {
    LC_ADDRESS = "en_GB.UTF-8";
    LC_IDENTIFICATION = "en_GB.UTF-8";
    LC_MEASUREMENT = "en_GB.UTF-8";
    LC_MONETARY = "en_GB.UTF-8";
    LC_NAME = "en_GB.UTF-8";
    LC_NUMERIC = "en_GB.UTF-8";
    LC_PAPER = "en_GB.UTF-8";
    LC_TELEPHONE = "en_GB.UTF-8";
    LC_TIME = "en_GB.UTF-8";
  # Enable the GNOME Desktop Environment.
  services.xserver.desktopManager.gnome.enable = true;
  # Configure keymap in X11
  services.xserver.xkb = {
    layout = "us";
    variant = "intl";
  # Configure console keymap
  console.keyMap = "us-acentos";
  # Enable sound with pipewire.
  security.rtkit.enable = true;
  services.pipewire = {
    alsa.enable = true;
    alsa.support32Bit = true;
    pulse.enable = true;
    #jack.enable = true;
    #media-session.enable = true;
  users.users.andi = {
    isNormalUser = true;
    description = "Andreas Weinzierl";
    packages = with pkgs; [
    	vscode
    	element-desktop
    	bitwarden
      pinta
      typst
  # Tray Icons
  # https://nixos.wiki/wiki/GNOME#Managing_extensions
  services.udev.packages = with pkgs; [ gnome.gnome-settings-daemon ];
  # Debug Infos for Gnome Bugreports
  services.nixseparatedebuginfod.enable = true;
  # Laptop energy settings #############################
  # Disable Gnome Energy utils
  services.power-profiles-daemon.enable = false;
  services.tlp = {
    settings = {
      CPU_SCALING_GOVERNOR_ON_BAT = "powersave";
      CPU_SCALING_GOVERNOR_ON_AC = "performance";
      CPU_ENERGY_PERF_POLICY_ON_BAT = "power";
      CPU_ENERGY_PERF_POLICY_ON_AC = "performance";
      CPU_MIN_PERF_ON_BAT = 0;
      CPU_MAX_PERF_ON_BAT = 20;
      CPU_MIN_PERF_ON_AC = 0;
      CPU_MAX_PERF_ON_AC = 100;
      #Optional helps save long term battery health
      START_CHARGE_THRESH_BAT0 = 60;
      STOP_CHARGE_THRESH_BAT0 = 80;
  # Remove default applications
  environment.gnome.excludePackages = [
    #pkgs.gnome.cheese
    #pkgs.gnome-photos
    #pkgs.gnome.gnome-music
    #pkgs.gnome.gnome-terminal \
    #pkgs.gnome.gedit
    pkgs.epiphany
    #pkgs.evince
    #pkgs.gnome.gnome-characters
    #pkgs.gnome.totem
    #pkgs.gnome.tali
    #pkgs.gnome.iagno
    #pkgs.gnome.hitori
    #pkgs.gnome.atomix
    pkgs.gnome-tour
  # Install firefox.
  # Allow unfree packages
  # $ nix search wget
  #  vim # Do not forget to add an editor to edit configuration.nix! The Nano editor is also installed by default.
  #  wget
    gnomeExtensions.appindicator # Tray Icons: https://nixos.wiki/wiki/GNOME#Managing_extensions
  # started in user sessions.
  # programs.mtr.enable = true;
  # programs.gnupg.agent = {
  #   enable = true;
  #   enableSSHSupport = true;
  # Enable the OpenSSH daemon.
  # Open ports in the firewall.
  system.stateVersion = "24.05"; # Did you read the comment?
However, it turns out that the following power settings don’t work:
According to some searching the screen should dim after 30s, but even after minutes neither the screen dims nor does it turn off.
I have tried different apps in the foreground, but the result is always the same.
How can I go about fixing this problem?
