Problem creating a nixosConfiguration flake for a remote machine on non-nixos
Hello,
I am building with a flake nixosConfiguration for other machine. In my nixos machine all works like expected:
nixos-rebuild build --flake '.#rpi'
I tested on other non-nixos machine:
I open a shell with nixos-rebuild:
`nix-shell -E “with import {}; mkShell { buildInputs = [ (nixos {}).nixos-rebuild ]; }”
$ nixos-rebuild build --flake ‘.#rpi
error: unrecognised flag ‘–experimental-features’
Try ‘nix --help’ for more information
This machine is non-nixos, Can I run this using “nix build” command?
Is it possible to fix “nixos-rebuild --flake”?
AFAIK you also need to pull nixFlakes and nixUnstable into the shell to actually get those features.
Right now both are one and the same, and I feel the ecosystem has grown enough that nixUnstable won’t ship without flakes anymore.
But yes, nix-env -iA nixpkgs.nixFlakes should do it in a standard setup.
I get the same error with nixFlakes package at shell:
nix-shell -E "with import <nixpkgs> {}; mkShell { buildInputs = [ (nixos {}).nixos-rebuild nixFlakes ]; }"
$ nix --version
nix (Nix) 3.0pre20201020_e0ca98c
$nixos-rebuild build --flake '.#rpi'
error: unrecognised flag '--experimental-features'
Try 'nix --help' for more information.
$ nix flake show
warning: Git tree 'xxxx' is dirty
git+file:///xxxxx
├───devShell
│   └───x86_64-linux: development environment 'nix-shell-arm-unknown-linux-gnueabihf'
├───nixosConfigurations
│   └───rpi: NixOS configuration
└───overlay: Nixpkgs overlay
I have check nix version and that “nix flake” command is running correctly.
The nice thing is, if you only want to build, then you can use nix build like I do on CI:
That’s because nixos-rebuild uses the NixOS configuration’s Nix, not the one in your environment. Thus:
(nixos { nix.package = nixFlakes; }).nixos-rebuild
(I didn’t know you didn’t need .config.system.build though…)
@NobbZ Solution is good enough for me now.
It is in a non-nixos system (debian). Could be a problem with nixos-rebuild calling the wrong version of nix? I suspect that because of the error:
