Problem installing Geneious with provided shell script
I’m not new, but relatively unexperiened using nixos. I was trying to install Geneious(https://www.geneious.com/) for a uni class when I try to install using the available bash script they provide(https://assets.geneious.com/installers/geneious/release/latest/Geneious_Prime_linux64_with_jre.sh) I was into an error message
Unpacking JRE …
Starting Installer …
Could not start dynamically linked executable: /home/User/Downloads/Geneious_Prime_linux64_with_jre.sh.95955.dir/jre/bin/java
NixOS cannot run dynamically linked executables intended for generic
linux environments out of the box. For more information, see:
What do I need to edit in the file or on my system to make this work, or is there a better way of installing this program?
You cn try to package it or use nix-ld, but really for uni you’re best off not using NixOS directly. Distrobox may work as an escape hatch if you don’t want to install another distro on bare metal.
Seconding distrobox (with podman). You can configure it more declaratively with home-manager and it keeps things installed more nicely than with nix-ld, You can probably even run the Geneious installer in init_hooks or build a custom image for it with home-manager’s services.podman.builds.
