jimzer
February 21, 2022, 7:37pm
1
Hello,
I’m trying to install scipy with Poetry inside a nix shell.
Here is my nix.shell
pkgs.mkShell {
nativeBuildInputs = [
pkgs.lapack-reference
pkgs.python310
(pkgs.poetry.override { python = pkgs.python310; })
When I run poetry add scikit-image (which has to install scipy) I get this error:
numpy.distutils.system_info.NotFoundError: No BLAS/LAPACK libraries found.
I tried to specify other BLAS provider (instead of lapack-reference) like openblas but it doesn’t work.
I’m relatively new to Nix and Nix/OS, could you help me?
Thanks
NobbZ
February 21, 2022, 8:05pm
2
How to solve this depends on the discovery mechanism that scikit is using.
If you are lucky, adding pkgConfig to native and the libs to regular build inputs is sufficient, if you are unlucky though, you will need to build env vars pointing to headers and/or libs on your own.
jimzer
February 21, 2022, 10:23pm
3
Thank you.
I will give it a try.
jimzer
February 22, 2022, 1:17pm
5
I almost made it work with this nix.shell
pkgs.mkShell {
pkgs.python310
pkgs.zlib
shellHook = ''
export BLAS="${pkgs.lapack-reference}/lib/libblas.so"
export LAPACK="${pkgs.lapack-reference}/lib/liblapack.so"
export LD_LIBRARY_PATH="${pkgs.zlib}/lib"
But now I get another error, later, with a lot of compiler outputs:
INFO: CCompilerOpt.__init__[1734] : initialize targets groups
INFO: CCompilerOpt.__init__[1736] : parse target group simd_test
INFO: CCompilerOpt._parse_target_tokens[1947] : skip targets (ASIMD XOP VSX2 FMA4 NEON VSX VSX3) not part of baseline or dispatch-able features
INFO: CCompilerOpt._parse_policy_not_keepbase[2059] : skip baseline features (SSE2)
INFO: CCompilerOpt.generate_dispatch_header[2280] : generate CPU dispatch header: (build/src.linux-x86_64-3.10/numpy/distutils/include/npy_cpu_dispatch_config.h)
WARN: CCompilerOpt.generate_dispatch_header[2289] : dispatch header dir build/src.linux-x86_64-3.10/numpy/distutils/include does not exist, creating it
INFO: CCompilerOpt.feature_extra_checks[1554] : Testing extra checks for feature 'AVX512F' (AVX512F_REDUCE)
INFO: C compiler: gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -fPIC
INFO: compile options: '-c'
extra options: '-msse -msse2 -msse3 -mssse3 -msse4.1 -mpopcnt -msse4.2 -mavx -mf16c -mfma -mavx2 -mavx512f -Werror'
INFO: CCompilerOpt.feature_extra_checks[1554] : Testing extra checks for feature 'AVX512_SKX' (AVX512BW_MASK AVX512DQ_MASK)
extra options: '-msse -msse2 -msse3 -mssse3 -msse4.1 -mpopcnt -msse4.2 -mavx -mf16c -mfma -mavx2 -mavx512f -mavx512cd -mavx512vl -mavx512bw -mavx512dq -Werror'
INFO: building 'mach' library
error: library mach has Fortran sources but no Fortran compiler found
INFO:
########### CLIB COMPILER OPTIMIZATION ###########
INFO: Platform :
Architecture: x64
Compiler : gcc
CPU baseline :
Requested : 'min'
Enabled : SSE SSE2 SSE3
Flags : -msse -msse2 -msse3
Extra checks: none
CPU dispatch :
Requested : 'max -xop -fma4'
Enabled : SSSE3 SSE41 POPCNT SSE42 AVX F16C FMA3 AVX2 AVX512F AVX512CD AVX512_KNL AVX512_KNM AVX512_SKX AVX512_CLX AVX512_CNL AVX512_ICL
Generated : none
INFO: CCompilerOpt.cache_flush[817] : write cache to path -> /run/user/1000/pip-req-build-lmxxwzag/build/temp.linux-x86_64-3.10/ccompiler_opt_cache_clib.py
ERROR: Failed building wheel for scipy
Failed to build scipy
ERROR: Could not build wheels for scipy, which is required to install pyproject.toml-based projects
jimzer
February 22, 2022, 1:18pm
6
Thanks, but I would prefer to use python 3.10 for this project.
Chiming in a bit late, here. But, it looks like you were just missing the fortran compiler. The following worked for me.
pkgs.mkShell {
pkgs.gfortran
pkgs.pkg-config
pkgs.python310
shellHook = ''
