Here’s what I’m doing:
- Download the 22.11 image from https://nixos.wiki/wiki/NixOS_on_ARM#Installation → https://hydra.nixos.org/job/nixos/release-22.11/nixos.sd_image.aarch64-linux. Got the file
nixos-sd-image-22.11.1991.36a81812f29-aarch64-linux.img.zst. - Uncompressing:
➜ ~ unzstd -d nixos-sd-image-22.11.1991.36a81812f29-aarch64-linux.img.zst
nixos-sd-image-22.11.1991.36a81812f29-aarch64-linux.img.zst: 2897481728 bytes
➜ ~ ll nixos-sd-image-22.11.1991.36a81812f29-aarch64-linux.img
Permissions Size User Date Modified Name
.rw-r--r-- 2.9G stian 25 Jan 19:54 nixos-sd-image-22.11.1991.36a81812f29-aarch64-linux.img
- Formatting:
➜ raspberrypi git:(main) ✗ nix-shell -p parted
[nix-shell:~]$ date && sudo parted /dev/mmcblk0 --script -- mklabel msdos && sudo parted /dev/mmcblk0 --script -- mkpart primary fat32 1MiB 100% && sudo mkfs.vfat -F32 /dev/mmcblk0p1 && sudo parted /dev/mmcblk0 --script print && date
Wed Jan 25 08:26:28 PM CET 2023
mkfs.fat 4.2 (2021-01-31)
Model: SD SD64G (sd/mmc)
Disk /dev/mmcblk0: 63.9GB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 63.9GB 63.9GB primary fat32 lba
Wed Jan 25 08:26:32 PM CET 2023
- Transferring:
➜ ~ date; sudo dd if=/home/stian/nixos-sd-image-22.11.1991.36a81812f29-aarch64-linux.img of=/dev/mmcblk0 bs=4M conv=fsync status=progress; date;
Wed Jan 25 08:27:06 PM CET 2023
2730491904 bytes (2.7 GB, 2.5 GiB) copied, 1 s, 2.7 GB/s2897481728 bytes (2.9 GB, 2.7 GiB) copied, 1.07606 s, 2.7 GB/s
690+1 records in
690+1 records out
2897481728 bytes (2.9 GB, 2.7 GiB) copied, 115.693 s, 25.0 MB/s
690+1 records in
690+1 records out
2897481728 bytes (2.9 GB, 2.7 GiB) copied, 115.973 s, 25.0 MB/s
Wed Jan 25 08:29:02 PM CET 2023
When I put this into my raspberry pi and boot it up, I first get to select the generation, then I see a bunch of text pass by, and then the screen goes black. The raspberry seems to be on still, but nothing shows on the screen. I have a video of what it looks like that I’ll share if I find somewhere to upload it to.
Question 1: Am I doing anthing wrong above? Should this work?
Question 2: Any tips for how to share that video of what the boot looks like?
