A sudo nixos-rebuild switch --flake
fails because Electron 28/27 fail to build.
error: builder for '/nix/store/fbd4wbgknpgns5pcr6h5xnyrmagnqi2n-electron-unwrapped-28.2.10.drv' failed with exit code 1;
last 10 log lines:
> applying in src: enable_partition_alloc_ref_count_size.patch
> applying in src: ensure_an_axcontext_before_painting.patch
> applying in src: safely_crash_on_dangling_profile.patch
> applying in src: prevent_mojotrap_event_re-ordering.patch
> applying in src: m122_cherry_pick_cve-2024-25062_libxml_fix.patch
> applying in src: allowlist_devtools_for_file_access_permission.patch
> applying in src: update_crashpad_to_37afd37401253ebcebcf6e07ce15c8cfecb1a1cc.patch
> applying in src: m122_webcodecs_disable_async_videoframe_readback_to_mitigate_a.patch
> error: src/content/test/data/gpu/webcodecs/copyTo.html: No such file or directory
> /nix/store/ym5fm2km11rn0fb6z6n6zd16fwi5p159-stdenv-linux/setup: line 131: pop_var_context: head of shell_variables not a function context
For full logs, run 'nix log /nix/store/fbd4wbgknpgns5pcr6h5xnyrmagnqi2n-electron-unwrapped-28.2.10.drv'.
error: 1 dependencies of derivation '/nix/store/p0nsdrxfxz6lprhgb219wv8svwmxnb73-electron-28.2.10.drv' failed to build
error: 1 dependencies of derivation '/nix/store/h3g7x3lqkiaxl62r388rbm0rm5brx0rz-bitwarden-desktop-2024.3.0.drv' failed to build
error: 1 dependencies of derivation '/nix/store/1ynsd8m20q0d1cnrav82gmmh4p7q8x96-user-environment.drv' failed to build
error: 1 dependencies of derivation '/nix/store/kjsc99669sdplg9d1c0k7n92qhmnmmdg-etc.drv' failed to build
error: 1 dependencies of derivation '/nix/store/3xz7al886vdpddfjz6570q49xcna67ap-nixos-system-pie-24.05.20240408.4cba8b5.drv' failed to build
The output of nix log /nix/store/fbd4wbgknpgns5pcr6h5xnyrmagnqi2n-electron-unwrapped-28.2.10.drv
gives the following:
warning: The interpretation of store paths arguments ending in `.drv` recently changed. If this command is now failing try again with '/nix/store/fbd4wbgknpgns5pcr6h5xnyrmagnqi2n-electron-unwrapped-28.2.10.drv^*'
@nix { "action": "setPhase", "phase": "unpackPhase" }
Running phase: unpackPhase
unpackPhase completed in 3 minutes 37 seconds
@nix { "action": "setPhase", "phase": "patchPhase" }
Running phase: patchPhase
applying patch /nix/store/qn9vd010ylciqv44d6wahrmkshysqphl-cross-compile.patch
patching file build/toolchain/linux/unbundle/BUILD.gn
applying patch /nix/store/fjrcvjbm60cyssfsh24y1fjhb3m4af9g-no-build-timestamps.patch
patching file build/compute_build_timestamp.py
Hunk #1 succeeded at 101 (offset 7 lines).
applying patch /nix/store/6vy0aq93la5bw5rbqp6ckjxy5mjk6zzy-widevine-79.patch
patching file third_party/widevine/cdm/BUILD.gn
Hunk #1 succeeded at 22 with fuzz 2 (offset 8 lines).
applying patch /nix/store/kysac7gkm7480yqa85v494kh4vycc97q-angle-wayland-include-protocol.patch
patching file third_party/angle/BUILD.gn
Hunk #1 succeeded at 588 (offset 99 lines).
Hunk #2 succeeded at 1183 (offset 104 lines).
patching file third_party/angle/src/third_party/volk/BUILD.gn
applying patch /nix/store/p57bs1svsz91d2vm41knifi2j327zlxs-chromium-initial-prefs.patch
patching file chrome/browser/first_run/first_run_internal_linux.cc
applying patch /nix/store/838ngmr2y2bplcvkjvgjn1gdjhyayqmg-chromium-120-llvm-17.patch
patching file build/config/compiler/BUILD.gn
applying patch /nix/store/cdzsrjbhi7h3dfis0jnb52kj1cva7qk2-b9bef8e9555645fc91fab705bec697214a39dbc1.patch
patching file build/config/linux/atspi2/BUILD.gn
yarn config v1.22.22
success Set "yarn-offline-mirror" to "/nix/store/xi7gvn71f2zk3h1lw2ljcn5h9s9cqmwq-offline".
Done in 0.11s.
yarn install v1.22.22
[1/4] Resolving packages...
[2/4] Fetching packages...
[3/4] Linking dependencies...
warning " > @electron/lint-roller@1.10.0" has incorrect peer dependency "typescript@^4.5.5".
[4/4] Building fresh packages...
warning Ignored scripts due to flag.
Done in 23.24s.
applying in src: build_gn.patch
applying in src: dcheck.patch
applying in src: accelerator.patch
applying in src: blink_file_path.patch
applying in src: blink_local_frame.patch
applying in src: can_create_window.patch
applying in src: disable_hidden.patch
applying in src: dom_storage_limits.patch
applying in src: render_widget_host_view_base.patch
applying in src: render_widget_host_view_mac.patch
applying in src: webview_cross_drag.patch
applying in src: gin_enable_disable_v8_platform.patch
applying in src: enable_reset_aspect_ratio.patch
applying in src: boringssl_build_gn.patch
applying in src: pepper_plugin_support.patch
applying in src: gtk_visibility.patch
applying in src: resource_file_conflict.patch
applying in src: scroll_bounce_flag.patch
applying in src: mas_blink_no_private_api.patch
applying in src: mas_no_private_api.patch
applying in src: mas-cgdisplayusesforcetogray.patch
applying in src: mas_disable_remote_layer.patch
applying in src: mas_disable_remote_accessibility.patch
applying in src: mas_disable_custom_window_frame.patch
applying in src: mas_avoid_usage_of_private_macos_apis.patch
applying in src: mas_use_public_apis_to_determine_if_a_font_is_a_system_font.patch
applying in src: add_didinstallconditionalfeatures.patch
applying in src: desktop_media_list.patch
applying in src: proxy_config_monitor.patch
applying in src: gritsettings_resource_ids.patch
applying in src: isolate_holder.patch
applying in src: notification_provenance.patch
applying in src: dump_syms.patch
applying in src: command-ismediakey.patch
applying in src: printing.patch
applying in src: support_mixed_sandbox_with_zygote.patch
applying in src: unsandboxed_ppapi_processes_skip_zygote.patch
applying in src: build_add_electron_tracing_category.patch
applying in src: worker_context_will_destroy.patch
applying in src: frame_host_manager.patch
applying in src: crashpad_pid_check.patch
applying in src: network_service_allow_remote_certificate_verification_logic.patch
applying in src: disable_color_correct_rendering.patch
applying in src: add_contentgpuclient_precreatemessageloop_callback.patch
applying in src: picture-in-picture.patch
applying in src: disable_compositor_recycling.patch
applying in src: allow_new_privileges_in_unsandboxed_child_processes.patch
applying in src: expose_setuseragent_on_networkcontext.patch
applying in src: feat_add_set_theme_source_to_allow_apps_to.patch
applying in src: add_webmessageportconverter_entangleandinjectmessageportchannel.patch
applying in src: ignore_rc_check.patch
applying in src: remove_usage_of_incognito_apis_in_the_spellchecker.patch
applying in src: allow_disabling_blink_scheduler_throttling_per_renderview.patch
applying in src: hack_plugin_response_interceptor_to_point_to_electron.patch
applying in src: feat_add_support_for_overriding_the_base_spellchecker_download_url.patch
applying in src: feat_enable_offscreen_rendering_with_viz_compositor.patch
applying in src: gpu_notify_when_dxdiag_request_fails.patch
applying in src: feat_allow_embedders_to_add_observers_on_created_hunspell.patch
applying in src: feat_add_onclose_to_messageport.patch
applying in src: allow_in-process_windows_to_have_different_web_prefs.patch
applying in src: refactor_expose_cursor_changes_to_the_webcontentsobserver.patch
applying in src: crash_allow_setting_more_options.patch
applying in src: upload_list_add_loadsync_method.patch
applying in src: allow_setting_secondary_label_via_simplemenumodel.patch
applying in src: feat_add_streaming-protocol_registry_to_multibuffer_data_source.patch
applying in src: fix_patch_out_profile_refs_in_accessibility_ui.patch
applying in src: skip_atk_toolchain_check.patch
applying in src: worker_feat_add_hook_to_notify_script_ready.patch
applying in src: chore_provide_iswebcontentscreationoverridden_with_full_params.patch
applying in src: fix_properly_honor_printing_page_ranges.patch
applying in src: export_gin_v8platform_pageallocator_for_usage_outside_of_the_gin.patch
applying in src: fix_export_zlib_symbols.patch
applying in src: web_contents.patch
applying in src: webview_fullscreen.patch
applying in src: disable_unload_metrics.patch
applying in src: fix_add_check_for_sandbox_then_result.patch
applying in src: extend_apply_webpreferences.patch
applying in src: build_libc_as_static_library.patch
applying in src: build_do_not_depend_on_packed_resource_integrity.patch
applying in src: refactor_restore_base_adaptcallbackforrepeating.patch
applying in src: hack_to_allow_gclient_sync_with_host_os_mac_on_linux_in_ci.patch
applying in src: logging_win32_only_create_a_console_if_logging_to_stderr.patch
applying in src: fix_media_key_usage_with_globalshortcuts.patch
applying in src: feat_expose_raw_response_headers_from_urlloader.patch
applying in src: process_singleton.patch
applying in src: add_ui_scopedcliboardwriter_writeunsaferawdata.patch
applying in src: feat_add_data_parameter_to_processsingleton.patch
applying in src: load_v8_snapshot_in_browser_process.patch
applying in src: fix_adapt_exclusive_access_for_electron_needs.patch
applying in src: fix_aspect_ratio_with_max_size.patch
applying in src: fix_crash_when_saving_edited_pdf_files.patch
applying in src: port_autofill_colors_to_the_color_pipeline.patch
applying in src: fix_non-client_mouse_tracking_and_message_bubbling_on_windows.patch
applying in src: build_make_libcxx_abi_unstable_false_for_electron.patch
applying in src: introduce_ozoneplatform_electron_can_call_x11_property.patch
applying in src: make_gtk_getlibgtk_public.patch
applying in src: build_disable_print_content_analysis.patch
applying in src: custom_protocols_plzserviceworker.patch
applying in src: feat_filter_out_non-shareable_windows_in_the_current_application_in.patch
applying in src: disable_freezing_flags_after_init_in_node.patch
applying in src: short-circuit_permissions_checks_in_mediastreamdevicescontroller.patch
applying in src: chore_add_electron_deps_to_gitignores.patch
applying in src: chore_allow_chromium_to_handle_synthetic_mouse_events_for_touch.patch
applying in src: add_maximized_parameter_to_linuxui_getwindowframeprovider.patch
applying in src: add_electron_deps_to_license_credits_file.patch
applying in src: fix_crash_loading_non-standard_schemes_in_iframes.patch
applying in src: create_browser_v8_snapshot_file_name_fuse.patch
applying in src: feat_configure_launch_options_for_service_process.patch
applying in src: feat_ensure_mas_builds_of_the_same_application_can_use_safestorage.patch
applying in src: fix_on-screen-keyboard_hides_on_input_blur_in_webview.patch
applying in src: preconnect_manager.patch
applying in src: fix_remove_caption-removing_style_call.patch
applying in src: build_allow_electron_to_use_exec_script.patch
applying in src: build_only_use_the_mas_build_config_in_the_required_components.patch
applying in src: chore_introduce_blocking_api_for_electron.patch
applying in src: chore_patch_out_partition_attribute_dcheck_for_webviews.patch
applying in src: expose_v8initializer_codegenerationcheckcallbackinmainthread.patch
applying in src: chore_patch_out_profile_methods_in_profile_selections_cc.patch
applying in src: add_gin_converter_support_for_arraybufferview.patch
applying in src: chore_defer_usb_service_getdevices_request_until_usb_service_is.patch
applying in src: refactor_expose_hostimportmoduledynamically_and.patch
applying in src: feat_expose_documentloader_setdefersloading_on_webdocumentloader.patch
applying in src: fix_remove_profiles_from_spellcheck_service.patch
applying in src: chore_patch_out_profile_methods_in_chrome_browser_pdf.patch
applying in src: chore_patch_out_profile_methods_in_titlebar_config.patch
applying in src: fix_disabling_background_throttling_in_compositor.patch
applying in src: fix_select_the_first_menu_item_when_opened_via_keyboard.patch
applying in src: fix_return_v8_value_from_localframe_requestexecutescript.patch
applying in src: fix_harden_blink_scriptstate_maybefrom.patch
applying in src: chore_add_buildflag_guard_around_new_include.patch
applying in src: fix_use_delegated_generic_capturer_when_available.patch
applying in src: build_remove_ent_content_analysis_assert.patch
applying in src: fix_activate_background_material_on_windows.patch
applying in src: fix_move_autopipsettingshelper_behind_branding_buildflag.patch
applying in src: revert_remove_the_allowaggressivethrottlingwithwebsocket_feature.patch
applying in src: fix_handle_no_top_level_aura_window_in_webcontentsimpl.patch
applying in src: feat_allow_passing_of_objecttemplate_to_objecttemplatebuilder.patch
applying in src: chore_remove_check_is_test_on_script_injection_tracker.patch
applying in src: crash_gpu_process_and_clear_shader_cache_when_skia_reports.patch
applying in src: revert_same_party_cookie_attribute_removal.patch
applying in src: fix_restore_original_resize_performance_on_macos.patch
applying in src: fix_font_flooding_in_dev_tools.patch
applying in src: feat_allow_code_cache_in_custom_schemes.patch
I thought well I’ll just use do it with the Flatpak version for now. But commenting bitwarden-desktop gives an error again, now with Electron 27 to build Logseq.
error: builder for '/nix/store/40qn9m7i28j5wbd4dn2ghv3fpp8hs5y1-electron-unwrapped-27.3.9.drv' failed with exit code 1;
last 10 log lines:
> applying in src: cherry-pick-4a98f9e304be.patch
> applying in src: fix_racy_iterator_use_in_node_addconnection.patch
> applying in src: fix_a_crash_when_a_bmp_image_contains_an_unnecessary_eof_code.patch
> applying in src: m120_ipcz_fix_a_few_weak_asserts.patch
For full logs, run 'nix log /nix/store/40qn9m7i28j5wbd4dn2ghv3fpp8hs5y1-electron-unwrapped-27.3.9.drv'.
error: 1 dependencies of derivation '/nix/store/ppxwfh6827azdf6p8axb26jbbblq44y2-electron-27.3.9.drv' failed to build
error: 1 dependencies of derivation '/nix/store/w0lym3sgb2p6x452hxw5ihh2w78rjlpa-logseq-0.10.8.drv' failed to build
error: 1 dependencies of derivation '/nix/store/h2z2cqxi3x869my6z9whkhakyz8v2m7a-user-environment.drv' failed to build
error: 1 dependencies of derivation '/nix/store/9acyy2r3v9kg5hs02k2a103319yh93n7-etc.drv' failed to build
error: 1 dependencies of derivation '/nix/store/5c5k4hyqms77k9v6sl9wcav07zbpzbh7-nixos-system-pie-24.05.20240408.4cba8b5.drv' failed to build
gives the same sort of log with the same errors and warnings. Especially:
Commenting Logseq now triggers Obsidian to build same Electron version as Bitwarden, wich fails again.
I don’t know if this is a problem with Nixpkgs or with my configuration.
Help is much appreciated!
