Problems running `node-packages/generate.sh` in nixpkgs
I’ve been trying to bump a nodejs application, namely tedicross and from what I have seen I need to run the generate.sh shell script to update the generated .nix file. However after running the script for about 4 hours the output reads:
info attempt registry request try #1 at 12:18:55 AM
http request GET https://registry.npmjs.org/rollup
http 200 https://registry.npmjs.org/rollup
info attempt registry request try #1 at 12:18:56 AM
http request GET https://registry.npmjs.org/fsevents
http 200 https://registry.npmjs.org/fsevents
fetching local directory: ../../applications/editors/vscode/extensions/rust-analyzer/build-deps from .
Error: ENOENT: no such file or directory, open '(removed)/nixpkgs/pkgs/applications/editors/vscode/extensions/rust-analyzer/build-deps/package.json'
I am on commit 4e80e89031451e8172176997c2bf609d004458a9 and I have tested this on two computers, one on my laptop and one on a server and they both failed with the same message.
Same issue here as of dade3cbe77fe6c63620e04d5577b8ec222d86a52. Any update on this?
created nodePackages: generate.sh does not work, blocking all nodePackages changes · Issue #384934 · NixOS/nixpkgs · GitHub to track
