I’m trying to setup a systemd timer to run a command daily. I followed the example in the wiki but the service keeps failing when I try systemctl start epg
systemd.timers."epg" = {
wantedBy = [ "timers.target" ];
timerConfig = {
OnCalendar = "daily";
Persistent = true;
systemd.services."epg" = {
script = ''
${pkgs.nodejs_18}/bin/npm run --prefix /media/TV/epg/ grab -- --site=web.magentatv.de
path = [ pkgs.nodejs_18 ];
serviceConfig = {
Type = "oneshot";
User = "root";
The command runs perfectly and also the script produced by NixOS works as intended.
systemctl status epg
× epg.service
Loaded: loaded (/etc/systemd/system/epg.service; linked; preset: enabled)
Active: failed (Result: exit-code) since Tue 2024-04-30 16:46:51 CEST; 12min ago
TriggeredBy: ● epg.timer
Process: 8145 ExecStart=/nix/store/3h6aq4h1s38z0rhv5irk32j6qx32w2fq-unit-script-epg-start/bin/epg-start (code=exited, sta>
Main PID: 8145 (code=exited, status=254)
IP: 0B in, 0B out
CPU: 401ms
Apr 30 16:46:51 Jans-Server epg-start[8146]: npm ERR! syscall spawn sh
Apr 30 16:46:51 Jans-Server epg-start[8146]: npm ERR! path /media/TV/epg
Apr 30 16:46:51 Jans-Server epg-start[8146]: npm ERR! errno -2
Apr 30 16:46:51 Jans-Server epg-start[8146]: npm ERR! enoent spawn sh ENOENT
Apr 30 16:46:51 Jans-Server epg-start[8146]: npm ERR! enoent This is related to npm not being able to find a file.
Apr 30 16:46:51 Jans-Server epg-start[8146]: npm ERR! A complete log of this run can be found in: /root/.npm/_logs/2024-04-30>
Apr 30 16:46:51 Jans-Server systemd[1]: epg.service: Main process exited, code=exited, status=254/n/a
Apr 30 16:46:51 Jans-Server systemd[1]: epg.service: Failed with result 'exit-code'.
Apr 30 16:46:51 Jans-Server systemd[1]: Failed to start epg.service.
