Hello,
I’m trying to do some Haskell on a recent NixOS installation and encounter the following problem in GHCi.
When running any recursive code, for example :
f 0 = 0
f n = f 0
(you can reproduce this by running nix shell nixpkgs#ihaskell
and then pasting those lines in GHCi
The computation stalls until it stack overflows
I do not encounter the same problem when compiling with ghc
or loading a file in GHCi
At one point the problem vanished, and then it came back, thus I assumed it was some kind of kernel bug (there have been kernel bugs breaking GHCi in the past Memory allocation errors on 6.1.1 / Kernel & Hardware / Arch Linux Forums)
(Haskell is not installed system wide, I use it in development flakes)
I’m running NixOS unstable
