i tried to add a patch to dwm, but this error appeared and i cant do rebuild-switch, what do i do?
patching file dwm.c
Hunk #1 FAILED at 49.
Hunk #2 FAILED at 147.
Hunk #3 FAILED at 184.
Hunk #4 succeeded at 442 with fuzz 2 (offset 36 lines).
Hunk #5 FAILED at 1084.
Hunk #6 succeeded at 1442 with fuzz 1 (offset 228 lines).
Hunk #7 FAILED at 1449.
Hunk #8 FAILED at 1932.
6 out of 8 hunks FAILED -- saving rejects to file dwm.c.rej
this is the error that appears when i try to rebuild-switch
error: Cannot build '/nix/store/yix3sl7mhc02gzk6aj09v9phy0p52815-dwm-6.6.drv'. Reason: builder failed with exit code 2. Output paths: /nix/store/hxl8pci4mvcn7gas0abrsl0m1bz9y6d4-dwm-6.6 Last 17 log lines: > Running phase: unpackPhase > unpacking source archive /nix/store/pkc2iabz3ysdqiij7i2bscjh33hwg7cq-dwm > source root is dwm > Running phase: patchPhase > Running phase: updateAutotoolsGnuConfigScriptsPhase > Running phase: configurePhase > no configure script, doing nothing > Running phase: buildPhase > build flags: SHELL=/nix/store/gik3rh1vz2jlgnifb9dh6vc6sxwwz9jj-bash-5.3p9/bin/bash PREFIX=/nix/store/hxl8pci4mvcn7gas0abrsl0m1bz9y6d4-dwm-6.6 CC=gcc > gcc -c -std=c99 -pedantic -Wall -Wno-deprecated-declarations -Os -I/usr/X11R6/include -I/usr/include/freetype2 -D_DEFAULT_SOURCE -D_BSD_SOURCE -D_XOPEN_SOURCE=700L -DVERSION=\"6.8\" -DXINERAMA drw.c > gcc -c -std=c99 -pedantic -Wall -Wno-deprecated-declarations -Os -I/usr/X11R6/include -I/usr/include/freetype2 -D_DEFAULT_SOURCE -D_BSD_SOURCE -D_XOPEN_SOURCE=700L -DVERSION=\"6.8\" -DXINERAMA dwm.c > In file included from dwm.c:273: > config.h:47:10: fatal error: vanitygaps.c: No such file or directory > 47 | #include "vanitygaps.c" > | ^~~~~~~~~~~~~~ > compilation terminated. > make: *** [Makefile:12: dwm.o] Error 1 For full logs, run: nix log /nix/store/yix3sl7mhc02gzk6aj09v9phy0p52815-dwm-6.6.drv error: Cannot build '/nix/store/c9md63q34b4r9a1nnxsm4vjw52136g2a-system-path.drv'. Reason: 1 dependency failed. Output paths: /nix/store/adpsyb1g23bdhjqfqrx59fm9xwqhpsg2-system-path error: Build failed due to failed dependency error: Cannot build '/nix/store/gdgy9mwiiwifhdfyf8agrk19wllyydxz-X-Restart-Triggers-polkit.drv'. Reason: 1 dependency failed. Output paths: /nix/store/7dhvgid0mbzdhchxbx56n15wa3dk6vp5-X-Restart-Triggers-polkit error: Cannot build '/nix/store/dcmzc9malcfsa2010kq9dzp5g9rb28ci-dbus-1.drv'. Reason: 1 dependency failed. Output paths: /nix/store/nlrn129dp5v6z3wrajcgsxz5b45w6i6n-dbus-1 error: Cannot build '/nix/store/x3ib71q9089r46dg680k0b6sq77lsqkk-etc.drv'. Reason: 1 dependency failed. Output paths: /nix/store/xdnm3grgx4l91ixr3bxdzx3pj06w628b-etc error: Cannot build '/nix/store/26hmawnsmfln091and039k4l99q4yh2h-nixos-system-nixos-26.05.20260611.a037402.drv'. Reason: 1 dependency failed. Output paths: /nix/store/sxj7al2ww6hly7s9sv7czmhr2ybjmrqb-nixos-system-nixos-26.05.20260611.a037402 error: Build failed due to failed dependency Command 'nix --extra-experimental-features 'nix-command flakes' build --print-out-paths '/home/snece/nixos-dotfiles#nixosConfigurations."nixos".config.system.build.toplevel' --no-link' returned non-zero exit status 1.
i dont know which files do i have to put here also, so ask me for any file
(btw i have flakes and home-manager, if thats important to add)
