The config you have pushed to GitHub should have a different error. You’ve used nixcolors in some places and nix-colors in others. Your colorScheme.nix has a function parameter named nixcolors, which you’re not passing to it.
It seems odd that you pass inputs, and pass nix-colors by itself, specifically.
i cant manage to have a pure config because when im doing ./path/to/file it doesnt work
Sorry for the fact that im blind, so i corrected itand it works, but what do you suggest other than passing nix-colors. And like you can see that lf.nix works when it is ./lf.nix in inputs but my dwm src in configuration.nix dont input the files when in ./path/to/file
im getting :
error: getting status of '/nix/store/fvilnylnr60i6h524fplzhhhhasp03il-source/nixos/dwm': No such file or directory
And i wanted to know if there was a way to get the path of the nixos config folder in bash so i can put the current wallpaper on my folder and get it with a not absolute path in colorSchemes.nix so lf can put it when i change the wallpaper
Instead of passing in nix-colors, you can instead have colorScheme.nix accept inputs, and then use inputs.nix-colors. I tend to prefer this, and it’s actually what I use everywhere, rather than re-numerating the inputs names in the flake, right after they were specified.
Flakes requires files be part of the git repo, but it looks like dwm is maybe a symlink outside your nix-config repo.
