Im trying to get OpenCL working on my system
This is my config
# Configurations for AMDGPU and ROCm setup
# Some programs hard-code the path to HIP
systemd.tmpfiles.rules = ["L+ /opt/rocm/hip - - - - ${pkgs.rocmPackages.clr}"];
# Enable ROCM on my RX 580
environment = {
variables = {
ROC_ENABLE_PRE_VEGA = "1";
systemPackages = with pkgs; [
clinfo
chaotic.mesa-git.enable = true;
# Additional hardware configurations
services.xserver.videoDrivers = ["amdgpu"];
boot.initrd.kernelModules = ["amdgpu"];
hardware.amdgpu.opencl = true;
hardware.amdgpu.loadInInitrd = true;
hardware.opengl = {
driSupport = true;
driSupport32Bit = true;
output of nix-info
- system: `"x86_64-linux"`
- host os: `Linux 6.8.5, NixOS, 24.05 (Uakari), 24.05.20240412.cfd6b5f`
- multi-user?: `yes`
- sandbox: `yes`
- version: `nix-env (Nix) 2.18.2`
- nixpkgs: `/etc/nix/path/nixpkgs`
Output of clinfo
Number of platforms 0
ICD loader properties
ICD loader Name OpenCL ICD Loader
ICD loader Vendor OCL Icd free software
ICD loader Version 2.3.2
ICD loader Profile OpenCL 3.0
Output of rocminfo
ROCk module is loaded
HSA System Attributes
Runtime Version: 1.1
System Timestamp Freq.: 1000.000000MHz
Sig. Max Wait Duration: 18446744073709551615 (0xFFFFFFFFFFFFFFFF) (timestamp count)
Machine Model: LARGE
System Endianness: LITTLE
Mwaitx: DISABLED
DMAbuf Support: YES
HSA Agents
Agent 1
Name: AMD Ryzen 7 1700 Eight-Core Processor
Uuid: CPU-XX
Marketing Name: AMD Ryzen 7 1700 Eight-Core Processor
Vendor Name: CPU
Feature: None specified
Profile: FULL_PROFILE
Float Round Mode: NEAR
Max Queue Number: 0(0x0)
Queue Min Size: 0(0x0)
Queue Max Size: 0(0x0)
Queue Type: MULTI
Node: 0
Device Type: CPU
Cache Info:
L1: 32768(0x8000) KB
Chip ID: 0(0x0)
ASIC Revision: 0(0x0)
Cacheline Size: 64(0x40)
Max Clock Freq. (MHz): 3000
BDFID: 0
Internal Node ID: 0
Compute Unit: 16
SIMDs per CU: 0
Shader Engines: 0
Shader Arrs. per Eng.: 0
WatchPts on Addr. Ranges:1
Features: None
Pool Info:
Pool 1
Segment: GLOBAL; FLAGS: FINE GRAINED
Allocatable: TRUE
Alloc Granule: 4KB
Alloc Alignment: 4KB
Accessible by all: TRUE
Pool 2
Segment: GLOBAL; FLAGS: KERNARG, FINE GRAINED
Allocatable: TRUE
Alloc Granule: 4KB
Pool 3
Segment: GLOBAL; FLAGS: COARSE GRAINED
Allocatable: TRUE
Alloc Granule: 4KB
ISA Info:
Agent 2
Uuid: GPU-XX
Marketing Name: AMD Radeon RX 580 Series
Vendor Name: AMD
Feature: KERNEL_DISPATCH
Profile: BASE_PROFILE
Max Queue Number: 128(0x80)
Queue Min Size: 64(0x40)
Queue Max Size: 131072(0x20000)
Queue Type: MULTI
Node: 1
Device Type: GPU
Cache Info:
L1: 16(0x10) KB
Chip ID: 26591(0x67df)
ASIC Revision: 1(0x1)
Max Clock Freq. (MHz): 1150
BDFID: 2304
Internal Node ID: 1
Compute Unit: 36
SIMDs per CU: 4
Shader Engines: 4
Shader Arrs. per Eng.: 1
WatchPts on Addr. Ranges:4
Coherent Host Access: FALSE
Features: KERNEL_DISPATCH
Fast F16 Operation: TRUE
Wavefront Size: 64(0x40)
Workgroup Max Size: 1024(0x400)
Workgroup Max Size per Dimension:
x 1024(0x400)
y 1024(0x400)
z 1024(0x400)
Max Waves Per CU: 40(0x28)
Max Work-item Per CU: 2560(0xa00)
Grid Max Size: 4294967295(0xffffffff)
Grid Max Size per Dimension:
x 4294967295(0xffffffff)
y 4294967295(0xffffffff)
z 4294967295(0xffffffff)
Max fbarriers/Workgrp: 32
Packet Processor uCode:: 730
SDMA engine uCode:: 58
IOMMU Support:: None
Pool Info:
Pool 1
Allocatable: TRUE
Alloc Granule: 4KB
Accessible by all: FALSE
Pool 2
Segment: GLOBAL; FLAGS: EXTENDED FINE GRAINED
Allocatable: TRUE
Alloc Granule: 4KB
Pool 3
Segment: GROUP
Allocatable: FALSE
Alloc Granule: 0KB
Alloc Alignment: 0KB
ISA Info:
ISA 1
Machine Models: HSA_MACHINE_MODEL_LARGE
Profiles: HSA_PROFILE_BASE
Default Rounding Mode: NEAR
Fast f16: TRUE
x 1024(0x400)
y 1024(0x400)
z 1024(0x400)
FBarrier Max Size: 32
*** Done ***
