Hi everyone,
I have been trying to learn more about how different projects are packaged in the Nixpkgs repository. In particular, I was looking into packaging a Matrix client called “Tammy”. Since it uses Gradle, I looked into the manual to see an example package. However, I have encountered an issue that left me stumped, in part because I do not know its workings well.
So far, I got this package file:
androidenv,
fetchFromGitLab,
gradle_8,
jdk17,
makeWrapper,
lib,
stdenv,
writeText,
androidComposition = androidenv.composeAndroidPackages {
buildToolsVersions = [ "35.0.0" ];
platformVersions = [ 35 ];
gradle = gradle_8.override { java = jdk17; };
stdenv.mkDerivation (finalAttrs: {
pname = "tammy";
version = "1.1.21";
src = fetchFromGitLab {
owner = "connect2x";
repo = "tammy";
tag = "v${finalAttrs.version}";
hash = "sha256-TZF0KwDvfxIQaIyTVGa4Oh9tkBZkzO92zSvYbSzXC1o=";
nativeBuildInputs = [ androidComposition.androidsdk gradle makeWrapper ];
gradleFlags = [ "-Dfile.encoding=utf-8" ];
configurePhase = ''
export ANDROID_USER_HOME=$tmpdir/.android
mkdir -p $ANDROID_USER_HOME
runHook preConfigure
runHook postConfigure
gradleInitScript = writeText "empty-init-script.gradle" "";
mitmCache = gradle.fetchDeps {
inherit (finalAttrs) pname;
data = ./deps.json;
Naturally, before building it, I first needed to generate the file with dependencies. Trying to run the command to do so, however, did not go successfully.
Initially, I did not have the configurePhase
snippet, which produced the following error:
Error text:
FAILURE: Build failed with an exception.
* Where:
Build file '/tmp/nix-shell-2-3/tmp.kqknhuiojx/source/build.gradle.kts' line: 18
* What went wrong:
An exception occurred applying plugin request [id: 'com.android.application', version: '8.9.3']
> Failed to apply plugin 'com.android.internal.application'.
> Failed to create service 'com.android.build.gradle.internal.services.AndroidLocationsBuildService_8bff33ad-a35c-4cd6-99b6-114de51369db'.
> Could not create an instance of type com.android.build.gradle.internal.services.AndroidLocationsBuildService.
> Could not create provider for value source AndroidLocationsBuildService.AndroidDirectoryCreator.
From what I understood, this was a matter of a writeable directory the project expects to have. That is when I added the configurePhase
. After that, the error mentioned above indeed disappearaed, and the command reached the stage of downloading dependencies… until it hit a now different error:
New error text (somewhat lengthy):
Initialization script '/nix/store/wdw15x3256w3gv7jkjmaz211q3344xvc-init-deps.gradle' line: 5
* What went wrong:
Execution failed for task ':nixDownloadDeps'.
> Could not resolve all files for configuration ':DEVDebugAndroidTestCompileClasspath'.
> The consumer was configured to find a library for use during compile-time, preferably optimized for Android, as well as attribute 'com.android.build.api.attributes.AgpVersionAttr' with value '8.9.3', attribute 'com.android.build.api.attributes.BuildTypeAttr' with value 'debug', attribute 'com.android.build.api.attributes.ProductFlavor:version' with value 'DEV', attribute 'org.jetbrains.kotlin.platform.type' with value 'androidJvm'. However we cannot choose between the following variants of root project :
- Configuration ':DEVDebugApiElements' variant android-app-symbol-for-data-binding declares a library for use during compile-time, preferably optimized for Android, as well as attribute 'com.android.build.api.attributes.AgpVersionAttr' with value '8.9.3', attribute 'com.android.build.api.attributes.BuildTypeAttr' with value 'debug', attribute 'com.android.build.api.attributes.ProductFlavor:version' with value 'DEV', attribute 'org.jetbrains.kotlin.platform.type' with value 'androidJvm':
- Unmatched attributes:
- Provides attribute 'artifactType' with value 'android-app-symbol-for-data-binding' but the consumer didn't ask for it
- Provides attribute 'com.android.build.gradle.internal.attributes.VariantAttr' with value 'DEVDebug' but the consumer didn't ask for it
- Provides attribute 'version' with value 'DEV' but the consumer didn't ask for it
- Configuration ':DEVDebugApiElements' variant android-base-module-metadata declares a library for use during compile-time, preferably optimized for Android, as well as attribute 'com.android.build.api.attributes.AgpVersionAttr' with value '8.9.3', attribute 'com.android.build.api.attributes.BuildTypeAttr' with value 'debug', attribute 'com.android.build.api.attributes.ProductFlavor:version' with value 'DEV', attribute 'org.jetbrains.kotlin.platform.type' with value 'androidJvm':
- Provides attribute 'artifactType' with value 'android-base-module-metadata' but the consumer didn't ask for it
- Configuration ':DEVDebugApiElements' variant android-classes-jar declares a library for use during compile-time, preferably optimized for Android, as well as attribute 'com.android.build.api.attributes.AgpVersionAttr' with value '8.9.3', attribute 'com.android.build.api.attributes.BuildTypeAttr' with value 'debug', attribute 'com.android.build.api.attributes.ProductFlavor:version' with value 'DEV', attribute 'org.jetbrains.kotlin.platform.type' with value 'androidJvm':
- Provides attribute 'artifactType' with value 'android-classes-jar' but the consumer didn't ask for it
- Provides its elements packaged as a jar but the consumer didn't ask for it
- Configuration ':DEVDebugApiElements' variant android-feature-all-metadata declares a library for use during compile-time, preferably optimized for Android, as well as attribute 'com.android.build.api.attributes.AgpVersionAttr' with value '8.9.3', attribute 'com.android.build.api.attributes.BuildTypeAttr' with value 'debug', attribute 'com.android.build.api.attributes.ProductFlavor:version' with value 'DEV', attribute 'org.jetbrains.kotlin.platform.type' with value 'androidJvm':
- Provides attribute 'artifactType' with value 'android-feature-all-metadata' but the consumer didn't ask for it
- Configuration ':DEVDebugApiElements' variant android-feature-res-ap_ declares a library for use during compile-time, preferably optimized for Android, as well as attribute 'com.android.build.api.attributes.AgpVersionAttr' with value '8.9.3', attribute 'com.android.build.api.attributes.BuildTypeAttr' with value 'debug', attribute 'com.android.build.api.attributes.ProductFlavor:version' with value 'DEV', attribute 'org.jetbrains.kotlin.platform.type' with value 'androidJvm':
- Provides attribute 'artifactType' with value 'android-feature-res-ap_' but the consumer didn't ask for it
- Configuration ':DEVDebugApiElements' variant android-feature-signing-config-data declares a library for use during compile-time, preferably optimized for Android, as well as attribute 'com.android.build.api.attributes.AgpVersionAttr' with value '8.9.3', attribute 'com.android.build.api.attributes.BuildTypeAttr' with value 'debug', attribute 'com.android.build.api.attributes.ProductFlavor:version' with value 'DEV', attribute 'org.jetbrains.kotlin.platform.type' with value 'androidJvm':
- Provides attribute 'artifactType' with value 'android-feature-signing-config-data' but the consumer didn't ask for it
- Configuration ':DEVDebugApiElements' variant android-feature-signing-config-versions declares a library for use during compile-time, preferably optimized for Android, as well as attribute 'com.android.build.api.attributes.AgpVersionAttr' with value '8.9.3', attribute 'com.android.build.api.attributes.BuildTypeAttr' with value 'debug', attribute 'com.android.build.api.attributes.ProductFlavor:version' with value 'DEV', attribute 'org.jetbrains.kotlin.platform.type' with value 'androidJvm':
- Provides attribute 'artifactType' with value 'android-feature-signing-config-versions' but the consumer didn't ask for it
- Configuration ':DEVDebugApiElements' variant android-java-res declares a library for use during compile-time, preferably optimized for Android, as well as attribute 'com.android.build.api.attributes.AgpVersionAttr' with value '8.9.3', attribute 'com.android.build.api.attributes.BuildTypeAttr' with value 'debug', attribute 'com.android.build.api.attributes.ProductFlavor:version' with value 'DEV', attribute 'org.jetbrains.kotlin.platform.type' with value 'androidJvm':
- Provides attribute 'artifactType' with value 'android-java-res' but the consumer didn't ask for it
- Configuration ':DEVDebugApiElements' variant android-manifest-metadata declares a library for use during compile-time, preferably optimized for Android, as well as attribute 'com.android.build.api.attributes.AgpVersionAttr' with value '8.9.3', attribute 'com.android.build.api.attributes.BuildTypeAttr' with value 'debug', attribute 'com.android.build.api.attributes.ProductFlavor:version' with value 'DEV', attribute 'org.jetbrains.kotlin.platform.type' with value 'androidJvm':
- Provides attribute 'artifactType' with value 'android-manifest-metadata' but the consumer didn't ask for it
- Configuration ':DEVDebugApiElements' variant jar declares a library for use during compile-time, preferably optimized for Android, as well as attribute 'com.android.build.api.attributes.AgpVersionAttr' with value '8.9.3', attribute 'com.android.build.api.attributes.BuildTypeAttr' with value 'debug', attribute 'com.android.build.api.attributes.ProductFlavor:version' with value 'DEV', attribute 'org.jetbrains.kotlin.platform.type' with value 'androidJvm':
- Provides attribute 'artifactType' with value 'jar' but the consumer didn't ask for it
- Configuration ':DEVDebugApiElements' variant merged-test-only-native-libs declares a library for use during compile-time, preferably optimized for Android, as well as attribute 'com.android.build.api.attributes.AgpVersionAttr' with value '8.9.3', attribute 'com.android.build.api.attributes.BuildTypeAttr' with value 'debug', attribute 'com.android.build.api.attributes.ProductFlavor:version' with value 'DEV', attribute 'org.jetbrains.kotlin.platform.type' with value 'androidJvm':
- Provides attribute 'artifactType' with value 'merged-test-only-native-libs' but the consumer didn't ask for it
I am not certain how to resolve this error; it might be something very simple that I overlooked due to inexperience, but between trying to configure more environment variables and using alternative tools, such as gradle2nix, I have not managed to overcome the problem. Does someone else have an idea what direction to take in order to resolve this issue?
