Problems with creating a nix-shell for miniforge
In my quest to install miniforge I have tried to adapt from the conda nix package but when I try to nix-shell execute my .nix file I run into the following error:
error: cannot evaluate a function that has an argument without a value ('fetchurl')
       Nix attempted to evaluate a function as a top level expression; in
       this case it must have its arguments supplied either by default
       values, or passed explicitly with '--arg' or '--argstr'. See
       https://nixos.org/manual/nix/stable/language/constructs.html#functions.
       at /home/nixos/miniforge.nix:3:3:
            2| , stdenv
            3| , fetchurl
            4| , runCommand
my .nix file looks like this:
 { lib
, stdenv
, fetchurl
, runCommand
, makeWrapper
, buildFHSEnv
, libselinux
, libarchive
, libGL
, xorg
, zlib
# Conda installs its packages and environments under this directory
, installationPath ? "~/.miniforge"
# Conda manages most pkgs itself, but expects a few to be on the system.
, condaDeps ? [ stdenv.cc xorg.libSM xorg.libICE xorg.libX11 xorg.libXau xorg.libXi xorg.libXrender libselinux libGL zlib]
# Any extra nixpkgs you'd like available in the FHS env for Conda to use
, extraPkgs ? [ ]
# How to use this package?
# First-time setup: this nixpkg downloads the conda installer and provides a FHS
# env in which it can run. On first use, the user will need to install conda to
# the installPath using the installer:
# $ nix-env -iA conda
# $ conda-shell
# $ conda-install
# Under normal usage, simply call `conda-shell` to activate the FHS env,
# and then use conda commands as normal:
# $ conda-shell
# $ conda install spyder
  version = "24.3.0-0";
  src = fetchurl {
      url = "https://github.com/conda-forge/miniforge/releases/download/${version}/Miniforge3-${version}-Linux-x86_64.sh";
      sha256 = "23367676b610de826f50f7ddc91139a816d4b59bd4c69cc9b6082d9b2e7fe8a3";
  conda = (
      libPath = lib.makeLibraryPath [
        zlib # libz.so.1
      runCommand "conda-install" { nativeBuildInputs = [ makeWrapper ]; buildInputs = [ zlib]; }
        # on line 10, we have 'unset LD_LIBRARY_PATH'
        # we have to comment it out however in a way that the number of bytes in the
        # file does not change. So we replace the 'u' in the line with a '#'
        # The reason is that the binary payload is encoded as number
        # of bytes from the top of the installer script
        # and unsetting the library path prevents the zlib library from being discovered
          mkdir -p $out/bin
          sed 's/unset LD_LIBRARY_PATH/#nset LD_LIBRARY_PATH/' ${src} > $out/bin/miniforge3-installer.sh
          chmod +x $out/bin/miniforge3-installer.sh
          makeWrapper                            \
            $out/bin/miniforge3-installer.sh      \
            $out/bin/conda-install               \
            --add-flags "-p ${installationPath}" \
            --add-flags "-b"                     \
            --prefix "LD_LIBRARY_PATH" : "${libPath}"
  buildFHSEnv {
    name = "miniforge-shell";
    targetPkgs = pkgs: (builtins.concatLists [ [ conda ] condaDeps extraPkgs]);
    profile = ''
      # Add conda to PATH
      export PATH=${installationPath}/bin:$PATH
      # Paths for gcc if compiling some C sources with pip
      export NIX_CFLAGS_COMPILE="-I${installationPath}/include"
      export NIX_CFLAGS_LINK="-L${installationPath}lib"
      # Some other required environment variables
      export FONTCONFIG_FILE=/etc/fonts/fonts.conf
      export QTCOMPOSE=${xorg.libX11}/share/X11/locale
      export LIBARCHIVE=${libarchive.lib}/lib/libarchive.so
      # Allows `conda activate` to work properly
      condaSh=${installationPath}/etc/profile.d/conda.sh
      if [ ! -f $condaSh ]; then
        conda-install
      fi
      source $condaSh
    runScript = "bash -l";
    meta = {
      description = "miniforge is a package manager for Python";
      mainProgram = "miniforge-shell";
      homepage = "https://conda-forge.org";
      platforms = lib.platforms.linux;
      license = lib.licenses.bsd3;
      maintainers = with lib.maintainers; [ toIhr ];
