Hey there. Is someone able to use Gamescope at the moment? I can’t get it to work. Games are just crashing right after launch. This happens with Steam, Lutris and Heroic. I found several issues on GitHub regarding Gamescope, so mabe it is not just me beeing dumb?
Some context:
Launching Steam with Gamescope like mentioned in the Arch Wiki:
gamescope -e -- steam
No CAP_SYS_NICE, falling back to regular-priority compute and threads.
Performance will be affected.
wlserver: [backend/headless/backend.c:68] Creating headless backend
vulkan: selecting physical device 'AMD Radeon RX 6700 XT (RADV NAVI22)': queue family 1
vulkan: physical device supports DRM format modifiers
vulkan: supported DRM formats for sampling usage:
vulkan: AR24 (0x34325241)
vulkan: XR24 (0x34325258)
vulkan: AB24 (0x34324241)
vulkan: XB24 (0x34324258)
vulkan: NV12 (0x3231564E)
vulkan: AB4H (0x48344241)
vulkan: XB4H (0x48344258)
vulkan: AB48 (0x38344241)
vulkan: XB48 (0x38344258)
vulkan: AB30 (0x30334241)
vulkan: XB30 (0x30334258)
vulkan: AR30 (0x30335241)
vulkan: XR30 (0x30335258)
[1] 10727 segmentation fault (core dumped) gamescope -e -- steam
Steam installed like that:
programs.steam = {
remotePlay.openFirewall = true; # Open ports in the firewall for Steam Remote Play
gamescopeSession.enable = true;
dedicatedServer.openFirewall = true; # Open ports in the firewall for Source Dedicated Server
Lutris installed like that:
lutris
(lutris.override {
extraPkgs = pkgs: [
wineWowPackages.stable
gamescope
winetricks
extraLibraries = pkgs: [
gamescope
Thx
