Proper way to deal with plugins and circular depedencies?
Hi, I’m reworking the Python Application devpi-server. It uses a plugin architecture where the plugins are python packages and depend on devpi-server itself. My navie approach leads to this problem:
Rewriting #!/nix/store/m1fw8l8y9ycxh5dzispbb7cwl6rra14l-python3-3.13.12/bin/python3.13 to #!/nix/store/m1fw8l8y9ycxh5dzispbb7cwl6rra14l-python3-3.13.12
wrapping `/nix/store/gf607lw8wmcz4gc0b7hgdd0slgas4gkb-python3.13-devpi-server-6.19.1/bin/devpi-gen-secret’…
Executing pythonRemoveTestsDir
Finished executing pythonRemoveTestsDir
Running phase: installCheckPhase
no Makefile or custom installCheckPhase, doing nothing
Running phase: pythonCatchConflictsPhase
Found duplicated packages in closure for dependency ‘devpi_server’:
devpi_server 6.19.1 (/nix/store/gf607lw8wmcz4gc0b7hgdd0slgas4gkb-python3.13-devpi-server-6.19.1)
dependency chain:
this derivation: /nix/store/gf607lw8wmcz4gc0b7hgdd0slgas4gkb-python3.13-devpi-server-6.19.1
devpi_server 6.19.1 (/nix/store/vvpg8z3v87r3yv8r98p357zrq03qqkfj-python3.13-devpi-server-6.19.1)
dependency chain:
…depending on: /nix/store/ld3mh0mq9qvbyv9prs8k89ckyx2fyy7q-python3.13-devpi-web-5.0.1
…depending on: /nix/store/vvpg8z3v87r3yv8r98p357zrq03qqkfj-python3.13-devpi-server-6.19.1
Package duplicates found in closure, see above. Usually this happens if two packages depend on different version of the same dependency.
For full logs, run:
nix log /nix/store/pnr7l6xd14cdgjcy46hqrs7yxzm8mgn6-python3.13-devpi-server-6.19.1.drv
error: Cannot build ‘/nix/store/a8qlc0s2i9a4w16l342lsjiv4jzr4x6q-unit-devpi-server.service.drv’.
Reason: 1 dependency failed.
Output paths:
/nix/store/1wrim2461pavjqhj52b4z7bhyk3h47xk-unit-devpi-server.service
I.e. the plugins are build with the original devpi-server, but the new devpi-server that has the plugins as dependency collides with that.
What’s the proper way to build devpi-server interdependent with its packages here?
Usually the approach with software involving plugins would be to build it without the plugins, build the plugins, then make a wrapper derivation that plugs the two together, rather than rebuilding the software that uses the plugins.
Do you have an example for Python?
I’m not aware of one, off the top of my head. Sorry.
The nixpkgs Python builders are unable to deal with circular dependencies without patching packages. There is no “proper way” to deal with it in nixpkgs. It’s all ad-hoc hacking.
For some prior art on Python wrapping derivations see xonsh.
Thanks adis. I updated the PR and did this: devpi-web: init at 5.0.1 by con-f-use · Pull Request #495637 · NixOS/nixpkgs · GitHub I now,I get a devpi-server executable that uses the plugins.
python3Packages.callPackage ../../../development/python-modules/devpi-server/wrapper.nix {
    plugins = with python3Packages; [
      devpi-web
      devpi-ldap
However, when I try to integrate that in the nixos-module, like in l.92 here, it doesn’t know of the plugin options and doesn’t seem to use the wrapper, but the unwrapped package.
error: function 'anonymous lambda' called with unexpected argument 'plugins' at /nix/store/4ldjwr6icpc0p79a8xj0gwj5d28zyidi-source/pkgs/by-name/de/devpi-server/package.nix:1:1: 1| { python3Packages }: | ^ 2|
@adisbladis , do you have an idea, why that is or how do use my wrapper in the module?
This is me:
Nevermind, I think I got it working. The xonsh tip was worth its weight in gold.
