Prosody and ACME (for Jitsi): trouble with key permissions
Here is my jitsi.nix:
# Adapted from
# https://nixos.org/manual/nixos/stable/#module-services-jitsi-meet
# https://nixos.org/manual/nixos/stable/#module-services-prosody
# https://discourse.nixos.org/t/setting-up-authentication-on-a-jitsi-server/17549
# https://github.com/NixOS/nixpkgs/issues/141641#issuecomment-1780184369
{ config, lib, pkgs, ... }:
  jitsi_fqdn = "jitsi.example.com";
  services.jitsi-meet = {
    hostName = jitsi_fqdn;
    prosody.lockdown = true;
    config = {
      authdomain = jitsi_fqdn;
      enableWelcomePage = false;
      prejoinPageEnabled = true;
      defaultLang = "fi";
      hosts = {
        anonymousdomain = "guests.${jitsi_fqdn}";
    interfaceConfig = {
      SHOW_JITSI_WATERMARK = false;
      SHOW_WATERMARK_FOR_GUESTS = false;
  services.jitsi-videobridge = {
    openFirewall = true;
  services.prosody = {
    allowRegistration = true;
    ssl.cert = "/var/lib/acme/${jitsi_fqdn}/fullchain.pem";
    ssl.key = "/var/lib/acme/${jitsi_fqdn}/key.pem";
    virtualHosts = {
      "${jitsi_fqdn}" = {
        enabled = true;
        domain = "${jitsi_fqdn}";
        extraConfig = ''
          authentication = "internal_hashed"
          c2s_require_encryption = false
          admins = { "focus@auth.${jitsi_fqdn}" }
          smacks_max_unacked_stanzas = 5
          smacks_hibernation_time = 60
          smacks_max_hibernated_sessions = 1
          smacks_max_old_sessions = 1
      "guests.${jitsi_fqdn}" = {
        enabled = true;
        extraConfig = ''
          authentication = "anonymous"
  services.jicofo = {
    config = {
      jicofo = {
        authentication = {
          enabled = true;
          type = "XMPP";
          login-url = "${jitsi_fqdn}";
        xmpp = {
          client = {
            client-proxy = "focus.${jitsi_fqdn}";
  security.acme = {
    acceptTerms = true;
    defaults.email = "me@example.com";
    defaults.group = "prosody";
When running prosodyctl register, I get these errors:
certmanager         error       Error indexing certificate directory /etc/prosody/certs: cannot open /etc/prosody/certs: No such file or directory
certmanager         error       SSL/TLS: Failed to load '/var/lib/acme/jitsi.example.com/key.pem': Check that the file exists and the permissions are correct (for client_https port 0)
The acme dirs and files are owned by group nginx:
$ ls -l /var/lib/acme/
total 8
drwxr-xr-x 3 acme nginx 4096 May  3 16:52 acme-challenge
drwxr-x--- 2 acme nginx 4096 May  3 16:52 jitsi.example.com
When building, I had not initially set defaults.group = "prosody" for acme. The group stays as nginx even if I remove the dirs and rebuild. The dir and file timestamps also seem to be from the earlier build, as if they are resurrected from somewhere. What could be the reason?
Edit: uff, now I realise doing this will mess up all my other sites, which run under Caddy. Those certs are under /var/lib/caddy/.local/share/caddy/certificates/. I wonder how to solve this.
Edit2: probably I should focus on clues like this for now: Jitsi Meet Caddy Config Error! - Help - Caddy Community
A late and not real answer but trying to deploy a self-hosted Matrix stack I’ve faced a similar issue and solved adding the NGINX group to the service, like
users.users.prosody.extraGroups = [ “nginx” ];
so prosody can read cert and key.
