Context: I maintain the idris2Packages β I donβt want to discourage review from anyone who might look at this and think βI donβt know anything about packaging Idris2 programs so I canβt say if this is an idiomatic package or not.β
NixOS:master β mattpolzin:idris2Packages-pack
opened 03:15AM - 24 Sep 24 UTC
## Description of changes
Pack is the most popular package manager for Idris2. β¦ Iβve mostly focused on making it easier to package Idris2 programs as Nix derivations but there is definitely demand for using nixpkgs to install Pack and then using Pack to build Idris2 projects.
## Things done
Result of `nixpkgs-review` run on x86_64-darwin [1](https://github.com/Mic92/nixpkgs-review)
<details>
<summary>1 package built:</summary>
<ul>
<li>idris2Packages.pack</li>
</ul>
</details>
Result of `nixpkgs-review` run on x86_64-linux [1](https://github.com/Mic92/nixpkgs-review)
<details>
<ul>
</ul>
</details>
Result of `nixpkgs-review pr 344109` run on aarch64-darwin [1](https://github.com/Mic92/nixpkgs-review)
<details>
<ul>
</ul>
</details>
- Built on platform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [x] x86_64-darwin
- [x] aarch64-darwin
- [ ] `sandbox = relaxed`
- [ ] `sandbox = true`
- [ ] Tested, as applicable:
Thanks a lot if you do!
klt
October 24, 2024, 8:12am
181
I can see the package in unstable.
Will this package be included in the next NixOS Release 24.11 ?
Yesterday I have spent hours to install the pack on my own,
without success
I installed installed Chez Scheme and Idris2 and now I would like to install idris2-pack . For this end I used the command provided:
bash -c "$(curl -fsSL https://raw.githubusercontent.com/stefan-hoeck/idris2-pack/main/install.bash)"
But that fails with the following error:
./_datatypes.h:3:10: fatal error: 'gmp.h' file not found
I have installed the following related packages:
chez
gmp
idris
idris2
and gmp.h is installed:
/nix/store/aakpck7mmlzf9m9sf1hkp3bjkm90kxnq-gmp-with-cxx-6.3.0-deβ¦
Yes. pack will be available in 24.11
Introduce SurrealEngine
The goal of this project is to reimplement enough of the original Unreal Engine
to make the Unreal Tournament (UT99) maps playable.
NixOS:master β hughobrien:master
opened 07:04PM - 24 Aug 24 UTC
Introduce [SurrealEngine](https://github.com/dpjuda⦠s/SurrealEngine)
Testing this package requires [Unreal Tournament (1999)](https://archive.org/details/Nova_UnrealTournamentUSA) to be available. I used wine to run the installer.
nix-shell -p p7zip --command '7z x -out99-img "Unreal Tournament (USA) (Disc 1) (Game).7z"'
nix-shell -p bchunk --command 'bchunk ut99-img/*.bin ut99-img/*.cue ut99-img/ut99'
nix-shell -p p7zip --command '7z x -out99-fs ut99-img/ut9901.iso'
WINEPREFIX=${PWD}/ut99-wine nix-shell -p wineWowPackages.full --command "wine ut99-fs/Setup.exe"
One should also [patch](https://unrealarchive.org/unreal-tournament/patches-updates/patches/patch-436/index.html) the installation to the version best supported by SurrealEngine
WINEPREFIX=${PWD}/ut99-wine nix-shell -p wineWowPackages.full --command "wine UTPatch436nodelta.exe"
Then run with
nix-shell -I nixpkgs=/data/nixpkgs -p surreal-engine --command "SurrealEngine ut99-wine/drive_c/UnrealTournament"
## Things done
- [X] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
hraban
November 23, 2024, 8:44pm
185
*Open since jan 2023 , I mean. Almost 2y old now.
Reviewed and ready to merge
NixOS:master β r17x:master
opened 01:20AM - 09 Jan 23 UTC
###### Description of changes
> Put the output from any script or program into β¦ your macOS Menu Bar (the BitBar reboot)
https://xbarapp.com/
###### Tested Compilations
```console
1 package added:
xbar (init at 2.1.7-beta)
1 package built:
xbar
###### Things done
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [23.05 Release Notes (or backporting 22.11 Release notes)](https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md#generating-2305-release-notes)
- [ ] (Release notes changes) Ran `nixos/doc/manual/md-to-db.sh` to update generated release notes
netali
November 24, 2024, 4:23pm
186
Open since december 2023, required for future updates of Zammad:
NixOS:master β NetaliDev:feature/zammad-refactor
opened 03:37AM - 29 Dec 23 UTC
This PR refactors the Zammad package, NixOS module β¦ and NixOS test. It does the following things:
- Use `inherit (lib) ...` instead of `with lib;`
- Make the Zammad system user and group configurable
- Use symlinks in the package to prevent the content of the package being copied to the state directory at every start of the systemd unit
- Drop MySQL support for multiple reasons:
- It wasn't really supported by the module before, since the `zammad-web` unit hard depended on a **local** PostgreSQL database (especially in the check if a database initialization is required)
- Support for MySQL will be dropped in Zammad 7 (see [here](https://docs.zammad.org/en/latest/prerequisites/software.html#database-server))
- Replace complicated, PostgreSQL specific query to check if the database was already seeded with a simple file in the state directory
- This also enables compatibility with other DB Backends that may be supported in the future
- Fix the systemd unit dependencies so that it only depends on a local PostgreSQL DB if it is created locally
- Remove locale hack in the test since it is not required anymore
- Remove hardcoded debug log level
- Add a cleanup task to the `preScript` of the `zammad-web` unit to clean the old package contents out of the state directory
## Things done
- [X] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [X] Tested, as applicable:
- [X] Tested basic functionality of all binary files (usually in `./result/bin/`)
- [24.05 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2405.section.md) (or backporting [23.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2305.section.md) and [23.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2311.section.md) Release notes)
- [X] Fits [CONTRIBUTING.md](https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md).
