Janik
June 28, 2023, 2:52pm
2374
XYenon
June 28, 2023, 4:12pm
2375
azuwis
June 30, 2023, 9:28am
2378
NixOS:master ← stepbrobd:metawear
opened 06:23PM - 19 Jun 23 UTC
###### Description of changes
For package updates please link to a chan… gelog or describe changes, this helps your fellow maintainers discover breaking updates.
python3Packages.metawear: init at 1.0.8
metawear
- https://pypi.org/project/metawear/
- https://github.com/mbientlab/metawear-sdk-python
dependency [warble](https://github.com/NixOS/nixpkgs/pull/238628)
- https://github.com/NixOS/nixpkgs/pull/238628
```shell
$ nix-shell -p nixpkgs-review --run "nixpkgs-review rev HEAD"
2 packages built:
python310Packages.metawear python311Packages.metawear
###### Things done
- Built on platform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [ ] Tested, as applicable:
- [23.11 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2311.section.md) (or backporting [23.05 Release notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2305.section.md))
Thanks a lot if you do!
https://github.com/NixOS/nixpkgs/pull/225502
sents
July 2, 2023, 1:32pm
2384
This backports some PRs for integrating Vencord with Discord to 23.05
https://github.com/NixOS/nixpkgs/pull/236237
moody
July 4, 2023, 3:41pm
2389
Berkeley DB doesn’t appear to have maintainers, so I’m linking this here to see if someone can take a look at it. While not strictly required for the clang 16 bump on Darwin, you’re probably not going to get far after building a stdenv without it.
https://github.com/NixOS/nixpkgs/pull/241178
