https://github.com/NixOS/nixpkgs/pull/263606
https://github.com/NixOS/nixpkgs/pull/263550
NixOS:master
← anthonyroussel:thanos_0_32_4
opened 10:18PM - 09 Oct 23 UTC
## Description of changes
https://github.com/thanos-io/thanos/releases/tag/v0… .32.0
https://github.com/thanos-io/thanos/releases/tag/v0.32.1
https://github.com/thanos-io/thanos/releases/tag/v0.32.2
https://github.com/thanos-io/thanos/releases/tag/v0.32.3
https://github.com/thanos-io/thanos/releases/tag/v0.32.4
https://github.com/thanos-io/thanos/releases/tag/v0.32.5
## Things done
- Built on platform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [x] Tested, as applicable:
- [23.11 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2311.section.md) (or backporting [23.05 Release notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2305.section.md))
Thanks a lot if you do!
bouk
November 8, 2023, 2:06pm
2894
vs49688
November 8, 2023, 6:39pm
2895
malt3
November 10, 2023, 9:21am
2901
My first NixOS module, athens, is awaiting a review. It’s a go module proxy (GOPROXY) named athens. Very handy for CI use cases, where you have ephemeral test runners that need to pull go dependencies over and over.
https://github.com/NixOS/nixpkgs/pull/265349
One ZHF fix, a few other packages that I’m finally upstreaming after having them in a local overlay for much too long, and a vim plug-in.
NixOS:master
← ambroisie:fix-tandoor-recipes
opened 02:17PM - 09 Nov 23 UTC
Upstream has yet to update to the new version which… is packaged in our repo, so bring in the patch [1] while waiting for an update.
ZHF: #265948
[1]: https://github.com/TandoorRecipes/recipes/pull/2706
## Things done
- [X] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] `sandbox = relaxed`
- [ ] `sandbox = true`
- [ ] Tested, as applicable:
- [X] Fits [CONTRIBUTING.md](https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md).
https://github.com/NixOS/nixpkgs/pull/266102
https://github.com/NixOS/nixpkgs/pull/266098
https://github.com/NixOS/nixpkgs/pull/266097
NixOS:master
← ambroisie:add-vimix-cursors
opened 05:00PM - 07 Nov 23 UTC
I've had this in an overlay since 2021, time to fin… ally upstream it.
## Things done
- [X] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
NixOS:master
← ambroisie:add-modus-themes
opened 04:30PM - 07 Nov 23 UTC
Adds https://github.com/miikanissi/modus-themes.nvi… m.
## Things done
PR was already approved, and nixpkgs-review
succeed
in building it.
https://github.com/NixOS/nixpkgs/pull/256685
bbigras
November 10, 2023, 7:27pm
2905
NixOS:master
← bbigras:remmina
opened 01:09AM - 09 Nov 23 UTC
For package updates please link to a changelo… g or describe changes, this helps your fellow maintainers discover breaking updates.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
https://github.com/NixOS/nixpkgs/pull/266365
https://github.com/NixOS/nixpkgs/pull/266346
https://github.com/NixOS/nixpkgs/pull/266340
nadir
November 10, 2023, 10:42pm
2906
A neat little cli rss reader I’ve recently encountered. Thought this would be a great little project for my first package to be upstreamed:
https://github.com/NixOS/nixpkgs/pull/266742
ipetkov
November 10, 2023, 11:59pm
2907
sikmir
November 11, 2023, 7:43pm
2909
al3x
November 12, 2023, 8:08pm
2912
