nadir
February 3, 2024, 10:00pm
3385
This one is mostly done but the author still needs some help to get rid of an error:
NixOS:master
← dotlambda:vorta-0.9.1
opened 07:36PM - 28 Jan 24 UTC
## Description of changes
Diff: https://github.com/borgbase/vorta/compare/v0.8.… 12...v0.9.1
Changelog: https://github.com/borgbase/vorta/releases/tag/v0.9.1
fixes https://github.com/NixOS/nixpkgs/issues/284532
## Things done
- Built on platform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [ ] `sandbox = relaxed`
- [ ] `sandbox = true`
- [ ] Tested, as applicable:
- [24.05 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2405.section.md) (or backporting [23.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2305.section.md) and [23.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2311.section.md) Release notes)
Thanks a lot if you do!
cc @nadir-ishiguro
Hi, somewhat frustrated maintainer of the Sonarr derivation here, with a > 1 month-old approved PR that bumps a major version but seems to be languishing. Looking for a merger to confirm there’s nothing more to be done.
NixOS:master
← purcell:sonarr-4
opened 11:55AM - 01 Jan 24 UTC
For package updates please link to a changelo… g or describe changes, this helps your fellow maintainers discover breaking updates.
As pointed out in #278002 we were lagging a long way behind the latest releases, with v4 coming out in Nov 2022: https://forums.sonarr.tv/t/sonarr-v4-beta/31078
There's no longer a plain "linux" (actually cross-platform) package available for download, so I made an attempt to build from source (like jellyfin) but abandoned it due to obscure issues with an apparently-vendored .NET library, instead opting to follow the pattern of per-platform downloads used for `radarr`.
## Things done
- [x] x86_64-linux
- [x] aarch64-linux
- [ ] x86_64-darwin
- [x] aarch64-darwin
- [x] `sandbox = true`
- [x] Tested, as applicable:
- [x] (Package updates) Added a release notes entry if the change is major or breaking
panicgh
February 5, 2024, 7:57pm
3390
A PR to restore the build of fastcdr by treating doxygen warnings as warnings instead of as errors. fastcdr currently fails to build (e.g. see hydra) with the new doxygen >= 1.10.0. An upstream issue was already created, but while we’re waiting for a fix, the temporary workaround to the fastcdr package could already be merged.
NixOS:master
← panicgh:fastcdr-doc-error
opened 07:49PM - 30 Jan 24 UTC
Make the build pass despite of doxygen warnings unt… il upstream has resolved the issue.
See upstream issue https://github.com/eProsima/Fast-CDR/issues/193.
Failed Hydra build, e.g.: https://hydra.nixos.org/build/247546464
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
A new language server (LSP) for C#
NixOS:master
← konradmalik:roslyn-ls
opened 09:37PM - 01 Feb 24 UTC
VSCode [C# Dev Toolkit](https://github.com/dotnet/v… scode-csharp) released [in 2023 ](https://devblogs.microsoft.com/visualstudio/announcing-csharp-dev-kit-for-visual-studio-code/) introduced a new roslyn-based LSP server.
In this PR I propose to introduce this underlying LSP server to nixpkgs.
`roslyn-ls` is already integrated in neovim [via a new plugin](https://github.com/jmederosalvarado/roslyn.nvim) as well [an ongoing effort to integrate it into emacs](https://github.com/emacs-lsp/lsp-mode/pull/4279).
There is also a [thread in nvim-lspconfig](https://github.com/neovim/nvim-lspconfig/issues/2657) that can also shine a bit of light on the history of this server.
The release process of this server is a bit convoluted, but my TL;DR understanding is:
- the server is hosted in [dotnet/roslyn](https://github.com/dotnet/roslyn) repository
- dotnet/roslyn repo creates a tag VSCode-CSharp-2.16.24 which builds this server and pushes it to nuget (not sure about that but such tags are being created on that repo and the server is for sure published to nuget)
- version of the server is based on the general roslyn version, not vscode-csharp version
- dotnet/vscode-csharp bumps the roslyn-ls version and tags a new release - 2.16.24 (also not sure about that but tags in vscode-csharp match tags in dotnet/roslyn)
Also related to naming - wanted to use `roslyn` but it's already used in nixpkgs so I went with `roslyn-ls`.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
A REPL shell for C# (.NET Tool)
NixOS:master
← DontEatOreo:pkgs-csharprepl
opened 11:24PM - 28 Jan 24 UTC
Added .NET Tool CSharpRepl
For package upd… ates please link to a changelog or describe changes, this helps your fellow maintainers discover breaking updates.
## Things done
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
@NixOS/dotnet
I’m new to contributing to NixOS, may I know what are the next steps to get reviewers to this PR →
NixOS:master
← siddarthkay:init/xcbeautify
opened 01:08PM - 04 Feb 24 UTC
[xcbeautify](https://github.com/cpisciotta/xcbeauti… fy) is a tool to format `xcodebuild` output.
derivation of `xcbeautify` in status-mobile repo -> https://github.com/status-im/status-mobile/blob/develop/nix/pkgs/xcbeautify/default.nix
## Things done
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
I don’t see an option to attach reviewers etc.
What would be a normal ETA for such things?
Thank you
NixOS:master
← StarGate01:nrfconnect
opened 09:43PM - 14 Sep 23 UTC
This PR re-adds some packages which were purged due… to their usage of QT4 in #174634 : `segger-jlink`, and two packages which depend on it: `nrfconnect` and `nrf-command-line-tools`.
Unfortunately the SEGGER J-Link tools are only distributed in binary form and have a hard requirement on (the bundled) QT4. I have packaged the bundled QT4 libs as a secondary package to not pollute the global namespace.
Supersedes #252137, #244637, #263487
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [23.11 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2311.section.md) (or backporting [23.05 Release notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2305.section.md))
SEGGER and Nordic NRF tools re-added after the removal of QT4 apps. This PR has been sitting for months, would be nice to finally upsteam the apps back.
Not my PR, but I think it needs some attention
NixOS:master
← Infinidoge:fix/firefox-wrapper
opened 08:52AM - 25 Nov 23 UTC
Properly passes through `requireSigning` and `allow… AddonSideload` so the wrapper will accept valid browsers.
Additionally, makes `requireSigning` and `allowAddonSideload` overridable.
This fixes some issues introduced by #244591.
## Things done
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
### Priorities
getchoo
February 9, 2024, 12:37am
3403
fixes issues with libtiff decoding webp/zstd compressed content in some apps - namely cartridges but could be more?
NixOS:staging
← getchoo:pkgs/libtiff/webp
opened 09:23PM - 06 Feb 24 UTC
this fixes #284608, along with issues in other appl… ications that may read webp/zstd compressed TIFF files with libtiff. it follows the example of other distributions such as [fedora](https://src.fedoraproject.org/rpms/libtiff/c/163d5da8528cee194fb1326bf2ca5abc75d3d7c7?branch=rawhide)
basing this on master for now -- i imagine it'll need to go to staging once ofborg gets us the rebuild count
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
