Elserjo
February 17, 2024, 7:26am
3460
Can someone review this, please?
NixOS:master ← Elserjo:vbox
opened 10:31AM - 30 Jan 24 UTC
## Description of changes
Create symlink from `$libexec/nls` containing localiz… ation files for GUI to `$out/share/virtualbox/nls`
After this we get:
## Things done
- Built on platform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [ ] `sandbox = relaxed`
- [ ] `sandbox = true`
- [ ] Tested, as applicable:
- [24.05 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2405.section.md) (or backporting [23.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2305.section.md) and [23.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2311.section.md) Release notes)
Thanks a lot if you do!
RatCornu
February 17, 2024, 10:34am
3461
Backport of a previous PR already merged:
NixOS:release-23.11 ← RatCornu:backport-281871-to-release-23.11
opened 06:19PM - 21 Jan 24 UTC
Backport suwayomi-server package and module to rele… ase-23.11 (pull request #281871).
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] Tested, as applicable:
- [x] (Module addition) Added a release notes entry if adding a new NixOS module
My PR to add s3proxy has been waiting for review since November. We’re using s3proxy at work to access a Nix binary cache hosted on an Azure storage container, so pretty useful for anyone wanting to host their own binary cache on a non-s3-compatible blobstore.
A python package, should be ready for merge.
NixOS:master ← itslychee:package/python/jishaku
opened 08:46PM - 10 Feb 24 UTC
This PR adds [`jishaku`](https://github.com/Goriali… s/jishaku) as a python module, and due to `import-expression` being a missing module in nixpkgs as well, I also packaged it in a different commit.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
afh
February 19, 2024, 4:03am
3468
Two PRs that may take a while to review, agree on and get merged, yet could be useful or even important to consider for 24.05.
NixOS:staging ← afh:refactor-update-texinfo
opened 08:08AM - 18 Feb 24 UTC
ℹ️ This draft PR is my understanding of how the texinfo package could be improve… d based off [@AndersonTorres' comment](https://github.com/NixOS/nixpkgs/pull/262276#issuecomment-1950275968) on #262276 and work on `nv-codec-headers` (see #287918).
### texinfo 7.0.3 -> 7.1
Diff: http://git.savannah.gnu.org/cgit/texinfo.git/diff/?id=texinfo-7.0.3&id2=texinfo-7.1
Changelog: http://git.savannah.gnu.org/cgit/texinfo.git/tree/ChangeLog?h=texinfo-7.1
### TODO
- [ ] If this PR is headed in the right direction and people see value in pursuing this approach close #262276 in favour of this one.
* Modernize `texinfo/4.13a.nix` by using `finalAttrs` and `hash`
* I decided not to refactor `texinfo/4.13a.nix` into `texinfo/default.nix` (see below) as it shares no common attributes with the other texinfo versions apart from `meta`
* Modernize `texinfo/common.nix` by removing top-level `with lib`, using `hash`, and adding `meta.mainProgram`
* Fix `texinfo/common.nix` by adding missing `libiconv` input
* Refactor individual texinfo version-specific nix files into generic `texinfo/default.nix` and
* Rename texinfo version packages to fit with [nixpkgs Package naming convention](https://github.com/NixOS/nixpkgs/blob/master/pkgs/README.md#package-naming), e.g. `texinfo6_5` -> `texinfo_6_5`.
* Adapt `all-packages.nix` according to the changes above
* Replace `texinfo_7_0` with `texinfo_7_1`
* Default to `texinfo_7_1`
## Things I kindly request feedback on
- [ ] At first glance it seems no package specifically requires texinfo 7.0.3, therefore I assume 7.0.3 can be replaced with 7.1. If ofborg tests pass are people on board with this or should the texinfo 7.0.3 package continue to exist in nixpkgs?
- [ ] Is there a better way to manage the `meta` attributes?
- [ ] Do folks agree that the `mainProgram` should indeed be `texi2any`?
- [ ] This PR retains the `texinfo[4567]` names, yet this PR seems also like a good opportunity to either rename or remove them and change all dependent package.
- [ ] Should the way packages refer to a specific texinfo version be unified?
If yes, which of the following existing appraoches is then preferred? Ⓐ or Ⓑ?
#### Ⓐ The following packages reference a texinfo version specific package directly:
* [allegro](https://github.com/NixOS/nixpkgs/blob/master/pkgs/development/libraries/allegro/default.nix) (texinfo 6.5)
* [gcc48](https://github.com/NixOS/nixpkgs/blob/master/pkgs/development/compilers/gcc/all.nix) (`texinfo5`, i.e. texinfo 5.2)
* [ne](https://github.com/NixOS/nixpkgs/blob/master/pkgs/applications/editors/ne/default.nix) (`texinfo6`, i.e. texinfo 6.8)
* [singular](https://github.com/NixOS/nixpkgs/blob/master/pkgs/applications/science/math/singular/default.nix) (`texinfo4`, i.e. texinfo 4.13a)
* [eukleides](https://github.com/NixOS/nixpkgs/blob/master/pkgs/applications/science/math/eukleides/default.nix) (`texinfo4`, i.e. texinfo 4.13a)
#### Ⓑ whereas the following packages have a `texinfo` input, which is set to a specific texinfo version in `all-packages.nix`:
* [fwknop](https://github.com/NixOS/nixpkgs/blob/e85de28405879e43c2f36a737b278ef4b966dc1e/pkgs/top-level/all-packages.nix#L8405) (texinfo 6.7)
* [mitscheme](https://github.com/NixOS/nixpkgs/blob/e85de28405879e43c2f36a737b278ef4b966dc1e/pkgs/top-level/all-packages.nix#L16664) (`texinfo6`, i.e texinfo 6.8)
* [gpm](https://github.com/NixOS/nixpkgs/blob/e85de28405879e43c2f36a737b278ef4b966dc1e/pkgs/top-level/all-packages.nix#L27728) (texinfo 6.7)
* [iksemel](https://github.com/NixOS/nixpkgs/blob/e85de28405879e43c2f36a737b278ef4b966dc1e/pkgs/top-level/all-packages.nix#L32594) (texinfo 6.7)
## Things done
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
NixOS:staging ← afh:refactor-init-icu
opened 07:17PM - 18 Feb 24 UTC
ℹ️ This draft PR is my understanding of how the icu package could be improved in… a similar vein as #289690.
### TODO
If this PR is headed in the right direction and people see value in pursuing this approach close the following PRs
- [ ] #289782
- [ ] #289783
* Add `icu/default.nix` containing the icu version specific packages
* Remove `icu/[0-9]*.nix`
* Use `hash` instead of `sha256` in `icu/base.nix`
* Includes changes proposed in #289782 **icu73: use buildPackages.icu73 for nativeBuildRoot**
* Update `all-packages.nix` accordingly using `callPackages`
I'm uncertain whether the changes proposed here properly affect `buildPackages.icu[0-9]{2}` or whether more work is needed.
I'd appreciated if someone could chime in on this.
## Things done
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
