NixOS:master ← konradmalik:mise
opened 07:14PM - 21 Apr 24 UTC
## Description of changes
Update the package and fix hash inconsistency betwe… en linux and darwin.
The inconsistency broke automated updates.
This post helped me: https://github.com/NixOS/nixpkgs/issues/39308
Cloning the repo locally on darwin showed duplicated paths in the `registry` folder.
## Things done
- Built on platform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [x] x86_64-darwin
- [ ] aarch64-darwin
- [ ] `sandbox = relaxed`
- [ ] `sandbox = true`
- [ ] Tested, as applicable:
- [24.05 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2405.section.md) (or backporting [23.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2305.section.md) and [23.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2311.section.md) Release notes)
Thanks a lot if you do!
Updates the version and fixes issue that blocked automated updates
NixOS:master ← vinnymeller:init-rimsort
opened 01:32AM - 18 Apr 24 UTC
Closes #304832
WIP to get [RimSort](https://githu… b.com/RimSort/RimSort) working.
The application currently gets built but I have no way to test if it works. I think I got as much of it as I can working without having steam / RimWorld to verify further
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
appreciate any feedback on this one
eljamm
April 23, 2024, 9:09pm
3825
NixOS:master ← eljamm:ki
opened 02:20AM - 05 Apr 24 UTC
Adds Ki, a command-line tool for converting Anki co… llections and decks into git repositories.
https://github.com/langfield/ki
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
Package has been ready for a while now. First time contributor, so I’m thankful for any tips or corrections.
EDIT: first one is already merged
There are two PRs for ROCm, which need some attention.
I have reviewed both of them myself already, and both are IMO actually ready to merge, but it would be good if someone could take a look and check if they agree.
The first one is easier, since it fixes ROCm, which will otherwise remain broken until https://nixpk.gs/pr-tracker.html?pr=304111 lands in master/unstable.
NixOS:master ← GZGavinZhao:rocm-cmake-fix
opened 08:34PM - 23 Apr 24 UTC
Fixes #305641.
Ensure CMake 3.9.2 is used to bui… ld clr, both for ROCm 5 and 6. The changes can be reverted once CMake 3.9.2 lands in unstable, if desired.
I have tested that `rocsparse` (5 and 6), `rocfft` (6), and `composable_kernel` (6) all build.
See #305641 for more details.
cc @mschwaig
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
The second one is a more complicated change to review, because it adds a few patches that make ROCm run on more cards without additional configuration/modifications.
For that one you could either only review the code or try it on your own hardware, ideally with some card that gets enabled by the PR.
NixOS:master ← GZGavinZhao:rocm-gfx-compat
opened 03:46PM - 23 Mar 24 UTC
- **rocmPackages: extend rocm-runtime ISA compatibility**
- **rocmPackages: ext… end clr ISA compatibility**
- **rocmPackages: extend tensile ISA compatibility**
- **rocmPackages: extend rocblas ISA compatibility**
- **rocmPackages: extend miopen ISA compatibility**
This will eliminate the need for users to use `HSA_OVERRIDE_GFX_VERSION` to emulate their GPUs as a supported GPU model.
For more info, see [this](https://lists.debian.org/debian-ai/2024/02/msg00178.html) mailing thread.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] `sandbox = true`
- [x] Tested, as applicable:
I have added myself as a maintainer to ROCm a few months ago, when I updated it from 5.7 to 6.0.
@ulrikstrid has been very generous with his time and reviewed/merged that PR and looked at everything else that came up by me and other contributors in ROCm since then.
Still I would appreciate if I could additionally tag or @ someone else for review, so that it’s not just him who always has to review in order for anything to merged.
If you use ROCm with Nix I would appreciate your reviews and comments, even if you can’t merge, since that thelps speard the load.
simple package and PR. moved to by-name, updated, added a maintainer.
NixOS:master ← name-snrl:update-wl-clip-persist
opened 04:35PM - 16 Apr 24 UTC
https://github.com/Linus789/wl-clip-persist/compare… /6ba11a2aa295d780f0b2e8f005cf176601d153b0...v0.4.0
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
hraban
April 25, 2024, 7:17pm
3831
Building from source on aarch64-darwin an application that was previously a binary release:
NixOS:master ← afh:update-refactor-dockutil
opened 02:57PM - 03 Mar 24 UTC
Diff: https://github.com/kcrawford/dockutil/compare/3.0.2...3.1.3
## Descript… ion of changes
* Update to 3.1.3
* Refactor to build from source on aarch64 instead of extracting pre-built binary from downloaded `.pkg`
❓ Is such a refactoring to build a package from source desirable from this project's point of view or less so?
## Things done
- [ ] x86_64-linux
- [ ] aarch64-linux
- [x] x86_64-darwin
- [x] aarch64-darwin
dockutil: 3.0.2 → 3.1.3 and refactor to build from source #293032
It’s been quiet for a while after a lot of initial back & forth.
drakon
April 26, 2024, 2:19pm
3833
I’ve raised xivlauncher: Fix GameMode not being detected by drakon64 · Pull Request #299304 · NixOS/nixpkgs · GitHub to fix an issue where XIVLauncher wouldn’t detect GameMode. There was some discussion about it but then it fell silent.
NixOS:master ← Tochiaha:xmltoman
opened 04:56PM - 18 Apr 24 UTC
For package updates please link to a changelo… g or describe changes, this helps your fellow maintainers discover breaking updates.
## Things done
- [x] x86_64-linux
- [x] aarch64-linux
- [ ] x86_64-darwin
approval and merging needed.
Hello, it’s my first contribution to nixpkgs where I update plover.dev to 4.0.0.dev12.
I had one of the maintainers that provided feedback and suggested to post the PR here
NixOS:master ← FirelightFlagboy:update-plover-4.0.0.dev12
opened 05:40PM - 12 Apr 24 UTC
Changelog for [plover-v4.0.0.dev12](https://github.… com/openstenoproject/plover/releases/tag/v4.0.0.dev12).
This updates the Plover development version to 4.0.0.dev12.
- I was having an issue first when build the project without `pyproject = true`.
The error was `Requirements should be satisfied by a PEP 517 installer.`
- With `pyproject` enabled, 2 dependencies were missing: `plover_stroke` and `rtf_tokenize`.
- `postPatch` step was removed since the `setup.cfg` file no longer specify `PyQt5`.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
