odygrd
June 3, 2024, 6:13pm
4021
Could someone please review this when you have a chance? It’s a simple addition of a header-only C++ language package. It would be great to have this merged.
NixOS:master
← odygrd:quill_init
opened 12:18PM - 01 Jun 24 UTC
## Description of changes
For package updates please link to a changelo… g or describe changes, this helps your fellow maintainers discover breaking updates.
## Things done
- Built on platform(s)
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [ ] `sandbox = relaxed`
- [ ] `sandbox = true`
- [ ] Tested, as applicable:
Thanks a lot if you do!
Quill is an cross platform low latency logging library for C++17 and onwards. The library is header only.
The project can be found [here](https://github.com/odygrd/quill)
Moves neovim node-client out of nodePackages
into it’s own package. Has a question about buildNpmPackage
that needs clarification from someone more familiar with node packaging too.
NixOS:master
← fidgetingbits:neovim-node-host
opened 02:24AM - 05 Jun 24 UTC
This moves the neovim node-client out of nodePackages into it's own standalone p… ackage that uses `buildNpmPackage`.
Note that when moving to `buildNpmPackage` I ran into an issue where node-client wouldn't built, which I described here https://github.com/neovim/node-client/pull/365. That PR has been merged into node-client, but the node-client maintainer was concerned that this might be an issue with `buildNpmPackage` or with the way I packaged it, so it would be good if someone more familiar with node packaging could clarify.
Previous version of node-client is in `nodePackages` (currently 5.0.1), so the neovim package will have to get updated to reference this package for updates. Pinging @manveru @rvolosatovs for comment about that, and if you have any issue with the way I setup this package.
I'm listed as a maintainer for this, but also happy for neovim people to take it. I'm not in the maintainer list yet, as atm it's pending https://github.com/NixOS/nixpkgs/pull/296562 getting merged.
Lastly, I named the package neovim-node-host because that's the bin that's exposed by the package that neovim is using, but the repo is actually just called `node-client` (probably too ambiguous). neovim-node-client might make more sense, so happy to change that.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] `sandbox = true`
- [x] Tested, as applicable:
Need another review pass on this
NixOS:master
← matteo-pacini:easyaudiosync
opened 05:02AM - 02 Jun 24 UTC
Added new package "Easy Audio Sync".
[Easy Audio… Sync](https://github.com/complexlogic/EasyAudioSync) is an audio library syncing and conversion utility. The intended use is syncing an audio library with many lossless files to a mobile device with limited storage.
This fixes #314834.
Tested on Darwin (aarch64) and Linux (aarch64).
## Things done
- [ ] x86_64-linux
- [x] aarch64-linux
- [ ] x86_64-darwin
- [x] aarch64-darwin
- [X] Fits [CONTRIBUTING.md](https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md).
NixOS:master
← herberteuler:fix/jetbrains-boot-java-runtime
opened 05:46AM - 25 Apr 24 UTC
All JetBrain IDEs support setting boot-time Java runtime, which is helpful in some cases. For example, I had the issue of `error reading /nix/store/liz01j673lwb0wzkrykg39a7z388fy41-mps-2023.2/mps/lib/app.jar; Invalid CEN header (invalid zip64 extra data field size)` with an old version of JetBrains MPS. Similar issues have been [reported](https://youtrack.jetbrains.com/issue/MPS-36113) and the recommended solution at the time was to change the boot-time JDK.
This setting can be changed, for example, as described [here for MPS](https://www.jetbrains.com/help/mps/switching-boot-jdk.html), but also similarly for other JetBrains IDEs, resulting in `*.jdk` files in `~/.config/JetBrains/*`. For example, `~/.config/JetBrains/MPS2023.3/mps.jdk` is generated for MPS 2023.3 and `~/.config/JetBrains/IntelliJIdea2024.1/idea.jdk` is generated for IntelliJ Ultimate 2024.1.
This PR fixes the wrapper scripts so that they respect boot-time JDK settings. It achieves the goal by tweaking the settings of environment variables. For example, while the two variables were set directly for MPS as below:
export MPS_JDK=${MPS_JDK-'/nix/store/a9hjq76qi7acm4pfi928ih7z70d5bndj-jetbrains-jdk-jcef-17.0.8-b1000.8/lib/openjdk'}
export MPS_VM_OPTIONS=${MPS_VM_OPTIONS-''}
They are now only set when boot-time JDKs are not set as below:
if [[ ! -s $HOME/.config/JetBrains/MPS2023.3/mps.jdk ]]; then
export MPS_JDK=${MPS_JDK-'/nix/store/n8w0vqzagx2nbj43w143chrqhmpl680c-jetbrains-jdk-jcef-17.0.8-b1000.8/lib/openjdk'}
fi
VMOPTS_STR="$(dirname $HOME/.config/JetBrains/MPS2023.3/mps.jdk)/*.vmoptions"
VMOPTS=$(echo $VMOPTS_STR)
if [[ -s "$VMOPTS" ]]; then
export MPS_VM_OPTIONS=$(cat "$VMOPTS")
else
fi
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [24.05 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2405.section.md) (or backporting [23.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2305.section.md) and [23.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2311.section.md) Release notes)
Please help review this long-standing PR that allows user to set a custom JDK for running JetBrains’ IDEs.
