b-m-f
July 9, 2024, 6:09am
4213
NixOS:master ← kit-ty-kate:opam-2.2.0
opened 05:22PM - 03 Jul 24 UTC
## Description of changes
For package updates please link to a changelo… g or describe changes, this helps your fellow maintainers discover breaking updates.
## Things done
- Built on platform(s)
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [ ] `sandbox = relaxed`
- [ ] `sandbox = true`
- [ ] Tested, as applicable:
Thanks a lot if you do!
Pkg has no maintainers set. Its an essential OCaml tool
A small step towards better nix shell infrastructure in Nixpkgs: devShellTools
End goal is to implement all nix shell functionality in Nixpkgs instead. Nix will act as a tiny nix run-like wrapper when pkg.devShell is found (planned).
Make the hacks in nix-shell+nix develop obsolete
Let stdenv and setup.sh evolve without having to comply with those hacks in Nix
Allow more innovation. Nix can’t be pinned in a project whereas Nixpkgs can. This makes Nix conservative about compatibility. Nixpkgs can make changes more freely. It can even develop a v2 or v3 of its shell implementation without disruption.
NixOS:master ← NixOS:devShellTools-env
opened 11:16AM - 05 Jul 24 UTC
Moves the environment functions, adds tests, docs, … and fixes.
See commit messages.
- Builds on https://github.com/NixOS/nixpkgs/pull/323398
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
NixOS:master ← justinas:nginxlog-exporter-typed-options
opened 06:05PM - 20 Nov 22 UTC
###### Description of changes
Add a little bit of typing to `services.prometh… eus.exporters.nginxlog.settings`. Using `types.attrs` here does not allow one to merge multiple definitions, e.g.:
```nix
lib.mkMerge [
services.prometheus.exporters.nginxlog.settings.namespaces = [
name = "domain1";
name = "domain2";
results in lists not getting merged, but one overriding the other, and the config file ends up with only one of the namespaces.
###### Things done
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] Tested, as applicable:
- [22.11 Release Notes (or backporting 22.05 Release notes)](https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md#generating-2211-release-notes)
- [ ] (Release notes changes) Ran `nixos/doc/manual/md-to-db.sh` to update generated release notes
This little PR has been sitting for a while, to the point where I myself forgot about it. Would be great to merge.
NixOS:master ← StarGate01:vsmartcard
opened 06:22PM - 07 Oct 22 UTC
This PR adds the virtual smart card reader and … relay: https://frankmorgner.github.io/vsmartcard/ . It can be used to e.g. emulate a smartcard when combined with e.g. https://jcardsim.org/ , or to debug smartcard communications via an Android phone bridge.
The service module `service.services.vsmartcard-vpcd` is used to enable and configure the virtual smart card driver. It appends a configuration to the `pcscd` `readers.conf`. To facilitate this, the `readerConfig` option of `services.pcscd` was upgraded to a list `readerConfigs`, which is internally joined into the single config file. The old `readerConfig` option has been marked as deprecated, but continues to work.
###### Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
Reworked this PR (started 2022) to include a module and adjustments to pcscd.
Fix Virtualbox with linux_latest in 24.05
NixOS:release-24.05 ← lelgenio:backport-virtualbox-7.0.18
opened 06:02PM - 08 Jun 24 UTC
Backport https://github.com/NixOS/nixpkgs/pull/3113… 62
Depends on https://github.com/NixOS/nixpkgs/pull/318311
Fixes https://github.com/NixOS/nixpkgs/issues/312336
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
