socksy
July 17, 2024, 1:57pm
4271
Init of https://friction.graphics/ which is officially recommended by Inkscape as a way to animate an SVG
NixOS:master β socksy:add-friction
opened 04:18PM - 27 Jun 24 UTC
## Description of changes
- Add [friction.graphics](https://friction.graphics),β¦ a motion vector graphics program for making SVG animations
## Things done
- Built on platform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [ ] `sandbox = relaxed`
- [ ] `sandbox = true`
- [ ] Tested, as applicable:
Thanks a lot if you do!
adrlau
July 18, 2024, 2:46pm
4275
Not really sure if im following proper guidelines, as its my first application, but would like some feedback on.
NixOS:master β adrlau:init-mricron
opened 07:30PM - 02 Apr 24 UTC
I tried to package mricron
can be found on https:/β¦ /github.com/neurolabusc/MRIcron or https://www.nitrc.org/projects/mricron
(github was used as upstream)
description from website:
MRIcron is a cross-platform NIfTI format image viewer. It can load multiple layers of images, generate volume renderings and draw volumes of interest. It also provides dcm2nii for converting DICOM images to NIfTI format and NPM for statistics. MRIcron is a mature and useful tool, however you may want to consider the more recent MRIcroGL as an alternative.
Currently only mricron is packaged because i found the package [dcm2niix](https://search.nixos.org/packages?query=dcm2nii) and i dont think it would be nessesary to add the bundeled one.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] `sandbox = true`
- [24.05 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2405.section.md) (or backporting [23.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2305.section.md) and [23.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2311.section.md) Release notes)
Here is a Python package ready for review and merge. Has been tested by the creator and by myself, and works flawlessly on both Linux and MacOS. Just needs a button press from someone who can.
NixOS:master β liam-murphy14:add-python-nodriver
opened 04:16AM - 11 Jul 24 UTC
Add python package for nodriver. homepage: https://β¦ github.com/ultrafunkamsterdam/nodriver
## Things done
- [ ] x86_64-linux
- [ ] aarch64-linux
- [x] x86_64-darwin
I added neotest-golang here, and Iβm wondering if thereβs anything else I have to do to get the PR reviewed:
NixOS:master β fredrikaverpil:neotest-golang
opened 07:13PM - 17 Jul 24 UTC
For package updates please link to a changelo⦠g or describe changes, this helps your fellow maintainers discover breaking updates.
This adds the Neotest adapter for running Go tests: https://github.com/fredrikaverpil/neotest-golang
I'm following the instructions here: https://github.com/NixOS/nixpkgs/blob/master/doc/languages-frameworks/vim.section.md#adding-new-plugins-to-nixpkgs-adding-new-plugins-to-nixpkgs
```bash
docker run -it --rm -v $(pwd):/workspace -w /workspace -e GITHUB_API_TOKEN=$GITHUB_API_TOKEN nixos/nix:latest nix-shell -p vimPluginsUpdater --run 'vim-plugins-updater add "fredrikaverpil/neotest-golang"'
docker run -it --rm -v $(pwd):/workspace -w /workspace -e GITHUB_API_TOKEN=$GITHUB_API_TOKEN nixos/nix:latest nix-shell -p vimPluginsUpdater --run vim-plugins-updater
## Things done
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
Iβm the author of neotest-golang.
NixOS:master β litchipi:ifm
opened 03:23PM - 18 Jul 24 UTC
Create a web-app module for a single-file service c⦠alled IFM for Improved File Manager.
See homepage here: https://github.com/misterunknown/ifm
I thought it wasn't worth a package (as it's just downloading a file), so only the module is done here.
Not really familiar with PHP's web server, so I don't know if that's an acceptable way to serve the PHP file, or if we should set up a nginx / caddy / whatever in the module as a replacement.
For security purposes, the systemd service is isolated, and only has a bind mount access to the `dataDir` provided in the configuration.
Didn't test the advanced configuration as described here: https://github.com/misterunknown/ifm/wiki/Configuration, particularly the authentication, but as it's not very "bound" to the operating system (except ldap), it should not break.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
Could use an in-depth look, not a very experienced contributor
Neovim node client package moved into standalone package. Already approved by neovim maintainer, but needs another review pass.
NixOS:master β fidgetingbits:neovim-node-host
opened 02:24AM - 05 Jun 24 UTC
This moves the neovim node-client out of nodePackages into it's own standalone p⦠ackage that uses `buildNpmPackage`.
EDIT: The follow two paragraphs are already solved. See comment thread.
Note that when moving to `buildNpmPackage` I ran into an issue where node-client wouldn't built, which I described here https://github.com/neovim/node-client/pull/365. That PR has been merged into node-client, but the node-client maintainer was concerned that this might be an issue with `buildNpmPackage` or with the way I packaged it, so it would be good if someone more familiar with node packaging could clarify.
Previous version of node-client is in `nodePackages` (currently 5.0.1), so the neovim package will have to get updated to reference this package for updates. Pinging @manveru @rvolosatovs for comment about that, and if you have any issue with the way I setup this package.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] Tested, as applicable:
