Edit: merged , thanks @lukegb
This one’s a mass rebuild (so I’m targeting staging), but it’s quite small, just enabling consistent support for HTTPS proxying via impureEnvVars. I’d love to get it in, it’s been open nearly a year
NixOS:staging
← timbertson:https_proxy
opened 08:28AM - 11 Apr 24 UTC
(this is a reopened version of https://github.com/NixOS/nixpkgs/pull/271161 for … technical reasons)
## Description of changes
**tl;dr** this PR makes `NIX_SSL_CERT_FILE` the preferred way to control CA certificates throughout nix, by allowing it to be set as in impureEnvVar, including it in proxyImpureEnvVars, and ensuring fetchers support it.
Nix (the executable) as well as much of its packaged software respects `NIX_SSL_CERT_FILE` as the preferred way to specify a custom set of root certificates. Within derivations, this is typically done by the setup hook of `cacert`.
However, there's no way to inject this variable from _outside_ (with impure env vars used in fetchers). This is required for most use cases of an an https proxy, as the proxy's own certificate will not likely be trusted by nix's builtin cacert package.
Functionality for injecting a custom trust store has been added to `fetchgit`, but because the setuphook will always override `NIX_SSL_CERT_FILE`, a different envvar had to be used (`NIX_GIT_SSL_CAINFO`). I have [an open PR](https://github.com/NixOS/nixpkgs/pull/266643) to add this same customisation to the go module fetcher.
However, it'd be preferable if we didn't invent a new envvar, and instead made `NIX_SSL_CERT_FILE` the single way to control this setting for both fetchers and nix itself.
For this to work, we need two small changes:
- `cacert` should only set this variable if it's not already set, so that any impure version is not overwritten
- this is in a setuphook so it's a mass rebuild
- add `"NIX_SSL_CERT_FILE"` to `proxyImpureEnvVars` (fetcher.nix). It's not strictly a proxy-only variable, but:
- this needs to be overridden for all HTTPS proxy use cases, and most things are https these days. Currently fetcher support for custom certs is patchy, because they're all doing their own thing (see below notes)
- using the certificates the system has explicitly set for nix (if any) is inline with user expectations even outside proxy setups, and this only affects fixed-output derivations anyway
Various fetchers current (and updated) behaviour is oulined below:
- fetchgit: previously added explicit support for `NIX_GIT_SSL_CAINFO` as the impure overrideable version. This is still supported, but the standard `NIX_SSL_CERT_FILE` now works and is preferred.
- fetchurl: passes `--insecure` to curl for a fixed-output derivation, so I guess it doesn't need modification
- fetchgomodule: previously no support for custom certs for git dependencies, now sets `GIT_SSL_CAINFO` to the value of `NIX_SSL_CERT_FILE` using whatever's provided by the user / setup hook
Looking through other fetchers, it seems most of them either have their own schemes or delegate to fetchurl. So this isn't a wide-reaching code change, but I think it's important to support `NIX_SSL_CERT_FILE` as an impureEnvVar, so that we don't force fetchers to invent their own envvars for this purpose.
## Things done
Since this is a mass-rebuild, I tested locally by only applying these changes to the version of `cacert` used by fetchers. With these modifications I tested fetching over https (using custom certs) with:
- fetchurl
- fetchgit (over https)
- go modules fetch (git https)
- Built on platform(s)
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [ ] `sandbox = relaxed`
- [ ] `sandbox = true`
- [ ] Tested, as applicable:
- [24.05 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2405.section.md) (or backporting [23.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2305.section.md) and [23.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2311.section.md) Release notes)
Added to an r-ryantm PR to update a downstream package which would otherwise be broken by the update, and add the relevant packages as passthru.test
NixOS:master
← r-ryantm:auto-update/python312Packages.recipe-scrapers
opened 10:30AM - 04 Aug 24 UTC
Automatic update generated by [nixpkgs-update](https://github.com/ryantm/nixpkgs… -update) tools. This update was made based on information from passthru.updateScript.
meta.description for python312Packages.recipe-scrapers is: Python package for scraping recipes data
meta.homepage for python312Packages.recipe-scrapers is: https://github.com/hhursev/recipe-scrapers
meta.changelog for python312Packages.recipe-scrapers is: https://github.com/hhursev/recipe-scrapers/releases/tag/15.0.0
###### Updates performed
- Ran passthru.UpdateScript
###### To inspect upstream changes
###### Impact
<b>Checks done</b>
- built on NixOS
- The tests defined in `passthru.tests`, if any, passed
- found 15.0.0 with grep in /nix/store/yr6d9sprn40db9nzmrr3nwpa7bf6qkfz-python3.12-recipe-scrapers-15.0.0
- found 15.0.0 in filename of file in /nix/store/yr6d9sprn40db9nzmrr3nwpa7bf6qkfz-python3.12-recipe-scrapers-15.0.0
<details>
<summary>
<b>Rebuild report</b> (if merged into master) (click to expand)
</summary>
5 total rebuild path(s)
5 package rebuild(s)
First fifty rebuilds by attrpath
mealie
python311Packages.recipe-scrapers
tandoor-recipes
</details>
<details>
<summary>
<b>Instructions to test this update</b> (click to expand)
</summary>
Either **download from Cachix**:
nix-store -r /nix/store/yr6d9sprn40db9nzmrr3nwpa7bf6qkfz-python3.12-recipe-scrapers-15.0.0 \
--option binary-caches 'https://cache.nixos.org/ https://nix-community.cachix.org/' \
--option trusted-public-keys '
nix-community.cachix.org-1:mB9FSh9qf2dCimDSUo8Zy7bkq5CX+/rkCWyvRCYg3Fs=
cache.nixos.org-1:6NCHdD59X431o0gWypbMrAURkbJ16ZPMQFGspcDShjY=
(The Cachix cache is only trusted for this store-path realization.)
For the Cachix download to work, your user must be in the `trusted-users` list or you can use `sudo` since root is effectively trusted.
Or, **build yourself**:
nix-build -A python312Packages.recipe-scrapers https://github.com/r-ryantm/nixpkgs/archive/2e24c5cde4dd01b03ca737a84d8c5e384328421a.tar.gz
Or:
nix build github:r-ryantm/nixpkgs/2e24c5cde4dd01b03ca737a84d8c5e384328421a#python312Packages.recipe-scrapers
After you've downloaded or built it, look at the files and if there are any, run the binaries:
ls -la /nix/store/yr6d9sprn40db9nzmrr3nwpa7bf6qkfz-python3.12-recipe-scrapers-15.0.0
ls -la /nix/store/yr6d9sprn40db9nzmrr3nwpa7bf6qkfz-python3.12-recipe-scrapers-15.0.0/bin
</details>
<br/>
### Pre-merge build results
We have automatically built all packages that will get rebuilt due to
this change.
This gives evidence on whether the upgrade will break dependent packages.
Note sometimes packages show up as _failed to build_ independent of the
change, simply because they are already broken on the target branch.
Result of `nixpkgs-review` run on x86_64-linux [1](https://github.com/Mic92/nixpkgs-review)
<details>
<summary>1 package failed to build:</summary>
<ul>
<li>tandoor-recipes</li>
</ul>
</details>
<details>
<summary>6 packages built:</summary>
<ul>
<li>mealie</li>
<li>mealie.dist</li>
<li>python311Packages.recipe-scrapers</li>
<li>python311Packages.recipe-scrapers.dist</li>
<li>python312Packages.recipe-scrapers</li>
<li>python312Packages.recipe-scrapers.dist</li>
</ul>
</details>
###### Maintainer pings
cc @ambroisie for [testing](https://github.com/ryantm/nixpkgs-update/blob/main/doc/nixpkgs-maintainer-faq.md#r-ryantm-opened-a-pr-for-my-package-what-do-i-do).
hraban
August 24, 2024, 4:20am
4461
Already reviewed and approved by two maintainers, just needs a merge.
NixOS:master
← hraban:smc-fuzzer
opened 10:23PM - 05 Aug 24 UTC
smc-fuzzer "https://github.com/theopolis/smc-fuzzer/"… is originally written to fuzz the SMC chip on apple laptops, but it's actually quite useful if you just want to have bona fide interaction with the SMC.
## Things done
- [ ] x86_64-linux
- [ ] aarch64-linux
- [x] x86_64-darwin
- [x] aarch64-darwin
Thanks a lot if you do!
NixOS:master
← returntoreality:indi-3rdparty-refactor
opened 10:47PM - 24 Apr 24 UTC
For package updates please link to a changelo… g or describe changes, this helps your fellow maintainers discover breaking updates.
This is refactoring the indi 3rdparty drivers into their own derivations instead of having the firmware and 3rdparty derivations. This also sets the architecture support for each driver and assign the correct licences (before the unfree binary blobs from the 3rdparty repo were not marked as unfree). indi-full is now containing only free drivers and there is a new indi-full-nonfree which also contains the nonfree drivers.
I also added myself to the maintainers.
## Things done
- [x] x86_64-linux
- [x] aarch64-linux
- [ ] x86_64-darwin
- [x] Tested, as applicable:
- [x] (Package updates) Added a release notes entry if the change is major or breaking
Has reviews and approval by one maintainer, just needs merge
ofalvai
August 25, 2024, 7:06am
4465
A few darwin build fixes:
NixOS:master
← ofalvai:legba-fix-darwin
opened 03:22PM - 20 Aug 24 UTC
Hydra:
- https://hydra.nixos.org/job/nixpkgs/trunk… /legba.aarch64-darwin
- https://hydra.nixos.org/job/nixpkgs/trunk/legba.x86_64-darwin
## Things done
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [X] aarch64-darwin
NixOS:master
← ofalvai:misskey-fix-darwin
opened 03:26PM - 20 Aug 24 UTC
Hydra:
https://hydra.nixos.org/job/nixpkgs/trunk… /misskey.aarch64-darwin
https://hydra.nixos.org/job/nixpkgs/trunk/misskey.x86_64-darwin
## Things done
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
NixOS:master
← ofalvai:postcss-cli-fix-darwin
opened 03:29PM - 20 Aug 24 UTC
Noticed this hash mismatch build failure. I'm not s… ure about the root cause, but everything builds with the updated hashes.
## Things done
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
