Are there darwin members available?
https://github.com/NixOS/nixpkgs/pull/108590
https://github.com/NixOS/nixpkgs/pull/109368
This one helps avoid unintentionally installing some non-free packages:
New package!
If you have a couple of minutes to spare:
2 small PRs which have been ~approved!
https://github.com/NixOS/nixpkgs/pull/108294
https://github.com/NixOS/nixpkgs/pull/108242
I repost this one which stills needs review:
https://github.com/NixOS/nixpkgs/pull/107038
Now merged, thanks!
https://github.com/NixOS/nixpkgs/pull/108544
https://github.com/NixOS/nixpkgs/pull/109941
+ backport
I’m looking for someone to review the package portion of this PR:
https://github.com/NixOS/nixpkgs/pull/109711
It uses composer2nix
This pull request might be fun for some to review, as it experiments with an on-the-fly generated package. I don’t know whether this is considered proper or whether a more traditional approach (of checking in a huge automatically generated .nix file into nixpkgs) is preferred.
Adding some simple, straightforward tests:
https://github.com/NixOS/nixpkgs/pull/111642
https://github.com/NixOS/nixpkgs/pull/111643
Contains a new package for could storage encryption (like Dropbox).
https://github.com/NixOS/nixpkgs/pull/83434
I’ve been increasing the version for months now Can anyone have a look? This is a well-tested module.
I’m looking to get mine reviewed : ht-rust: init at 0.5.0 by bhankas · Pull Request #112110 · NixOS/nixpkgs · GitHub
It adds a tiny rust utility named “ht”, an HTTPie clone in Rust.
I also renamed the binary and package name to ht-rs, as there is already an “ht” in nixpkgs.
I chose ht-rs because apparently homebrew chose the same name.
Update CUDA 11 toolkits + corresponding CuDNN:
https://github.com/NixOS/nixpkgs/pull/112648
MAGMA: fix build with CUDA 11, also build for newer CUDA capabilities:
https://github.com/NixOS/nixpkgs/pull/112093
https://github.com/NixOS/nixpkgs/pull/80113
https://github.com/NixOS/nixpkgs/pull/110762
https://github.com/NixOS/nixpkgs/pull/73106
https://github.com/NixOS/nixpkgs/pull/84115
https://github.com/NixOS/nixpkgs/pull/84791
https://github.com/NixOS/nixpkgs/pull/74085
https://github.com/NixOS/nixpkgs/pull/63899
