Just bump a package update and disabled tests duo to cargo dev-dependency weird behavior,
Bots should be able to continue to auto update just fine after this PR
NixOS:master ← xgroleau:chore/update-slint-lsp
opened 09:22PM - 24 Oct 24 UTC
^ Please summarise the changes you have done and explain why they are nece… ssary here ^
## Things done
- Built on platform(s)
- [ ] x86_64-linux
- [x] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [ ] `sandbox = relaxed`
- [ ] `sandbox = true`
- [ ] Tested, as applicable:
Thanks a lot if you do!
Tested the build and briefly the LSP
I have a PR on an update of qiskit, a python package, and am waiting for review.
NixOS:master ← comavius:qiskit
opened 01:23PM - 24 Oct 24 UTC
## Things done
- Updated qiskit 1.0.1 -> 1.2.4
- Set rust dependencies for bui… lding qiskit
- Updated rustworkx 0.14.2 -> 0.15.1 (necessary for qiskit 1.2.4)
- Disabled qiskit optional module install (qiskit-aer is marked as broken)
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
Srylax
October 28, 2024, 8:52am
4760
Implemented all requested changes. Hoping for a re-review.
NixOS:master ← Srylax:master
opened 03:36PM - 09 Oct 24 UTC
Add `fido2-manage`, allows to manage fido2 keys. Developed by Token2
## Thing… s done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] aarch64-darwin
- [ ] Tested, as applicable: `Since upstream has no tests and a hardware key would be required this is hard to do`
