PRs ready for review _
Any chance python311Packages.connectorx: init at 0.3.3 by coastalwhite · Pull Request #312884 · NixOS/nixpkgs · GitHub can be reviewed again, I have some other packages that I maintain in my own fork that I would like to put up next.
iperf2 version upgrade - thanks in advance!
cc @fpletz - fellow iperfer :slight_smile:
Shadow PC Cloud Workstation is Windows Virtual PC streamed from the cloud
(reposting that because upstream made a release so it’s now just a version bump)
go 1.23.4 → 1.23.5
go1.23.5 (released 2025-01-16) includes security fixes to the crypto/x509 and net/http packages, as well as bug fixes to the compiler, the runtime, and the net package. See the Go 1.23.5 milestone on our issue tracker for details.
Adds a new feature to the coredns package to allow external plugins to be installed correctly by specifying where they should go in the plugin.cfg file which controls their order of execution.
Added a new package for VRCX, a VRChat companion application
nixos-container: add support for --private-user for the massive security boost.
A very small, effectively 1 cli arg change fixing powerdns-admin, which otherwise will fail to start on 24.11. Would be great to get merged.
(Not my pull request)
I’ve made some changes after a review due to usage of versioned python package
A few month+ old PRs:
This PR changes VRCX from an unstable release to a stable release now that AppImages are officially supported
