NixOS:master ← DataHearth:add/dvr-scan
opened 09:29PM - 24 Apr 25 UTC
^ Please summarise the changes you have done and explain why they are nece… ssary here ^
Required PR:
- [x] #401450
Note for testing: this package provides a CLI binary and a GUI binary. GUI is based on `tkinter` which is why it is added as dependency.
## Things done
- Built on platform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [ ] `sandbox = relaxed`
- [ ] `sandbox = true`
- [x] Tested, as applicable:
- [25.05 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) (or backporting [24.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2411.section.md) and [25.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) Release notes)
Thanks a lot if you do!
A small PR sitting for while. It adds a motion detection software and previously required a new python library before merging. Everything is ready now .
This has a several approvals (including the maintainer’s), but no-one to merge it
master ← jamesward:bump/jetbrains-jdk
opened 04:23AM - 13 May 25 UTC
jetbrains-jdk: 21.0.4 -> 21.0.6
jcef-jetbrains: 242 -> 251
This should be th… e JDK & JCEF used in JetBrains 2025.1 which might resolve issues like:
https://github.com/NixOS/nixpkgs/issues/401540
Note: I removed the thrift jar stuff because it was removed upstream.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] Tested, as applicable:
master ← dotboris:coredns-external-plugins-position
opened 04:36PM - 01 Dec 24 UTC
This adds a new `position` attr in `externalPlugins` that allows users to contro… l where their external plugins are placed in the `plugin.cfg` file.
Valid values are:
- `position = "end-of-file"` (the default)
- `position.before = "{other plugin}"`
- `position.after = "{other plugin}"`
Controlling the order of the items in `plugin.cfg` is very important when installing an external plugin into CoreDNS. This is because the order of items in this file controls the order of execution and therefor priority of plugins. See [the header comment of `plugin.cfg`](https://github.com/coredns/coredns/blob/7429380b1cacebde73084ad3cb6fb676c69bd6b8/plugin.cfg#L1-L5)
Fixes #354869
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
I tested my changes with the following file:
<details>
<summary>__scratch/coredns-test.nix</summary>
```nix
pkgs = import ./.. {};
pkgs.coredns.override {
externalPlugins = [
name = "blocklist0";
repo = "github.com/relekang/coredns-blocklist";
version = "v1.12.0";
name = "blocklist1";
position = "end-of-file";
name = "blocklist2";
position = "start-of-file";
name = "blocklist3";
position.before = "hosts";
name = "blocklist4";
position.after = "hosts";
# This one generates an error to test the error case
# name = "blocklist4";
# repo = "github.com/relekang/coredns-blocklist";
# version = "v1.12.0";
# position = "bogus";
vendorHash = "sha256-omff6rCwUqU0Kn1vozabT4xMT34B7XRpLnWCb5kNjJU=";
</details>
I ran this with the following command and I inspected the contents of `result/plugin.cfg`
```sh
nix build -L --file __scratch/coredns-test.nix goModules
This PR has been waiting for a review for 6 months now
