zyx
June 5, 2025, 7:50pm
5546
Not my PR, but I have been unable to input traditional Chinese with ibus on Gnome since March and waiting for this PR to be merged:
https://github.com/NixOS/nixpkgs/pull/392427
Rucadi
June 7, 2025, 7:55pm
5551
Zelda Tears Of The Kingdom Mod Manager
master ← Rucadi:tkmm
opened 05:42PM - 07 Jun 25 UTC
https://tkmm.org/ is a mod manager for Tears Of The Kingdom switch game, the off… icial software distribution doesn't work on nixos, since I wanted to use it, I packaged it and tested basic functionality.
Image demonstrating it:
## Things done
- Packaged TKMM for nixos (even the official appimage didn't work)
- Created desktop entry
- Tested functionality
- Built on platform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [ ] `sandbox = relaxed`
- [ ] `sandbox = true`
- [ ] Tested, as applicable:
- [Nixpkgs 25.11 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/doc/release-notes/rl-2511.section.md) (or backporting [24.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/release-notes/rl-2411.section.md) and [25.05](https://github.com/NixOS/nixpkgs/blob/master/doc/manual/release-notes/rl-2505.section.md) Nixpkgs Release notes)
- [NixOS 25.11 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2511.section.md) (or backporting [24.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2411.section.md) and [25.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) NixOS Release notes)
It’s been almost a year since this PR was first submitted. I’ve been using the service it provides with no issues for several months now. The author has recently resolved all merge conflicts. I think it deserves a review/merge:
master ← mrene:openthread-border-router
opened 05:03PM - 04 Aug 24 UTC
## Description of changes
This adds [OpenThread](https://openthread.io/)'s open… source [border router component](https://github.com/openthread/ot-br-posix) along with a NixOS service.
Thread is a mesh networking technology based on 6LoWPAN (ipv6-based) and 802.15.4. The border router component bridges the mesh network to an ipv6 network on a local interface. If no ipv6 connectivity exists, it'll advertise a new prefix for the local network so communication is possible.
Once setup, it can be used to bridge a [Thread network](https://en.wikipedia.org/wiki/Thread_(network_protocol)) with the local network to expose IoT devices to other systems like Home Assistant, Apple Home, etc..
I've been using this implementation along with Home Assistant and some Nanoleaf light bulbs using both Matter and their proprietary "ltpdu" protocol for about a week now. It's pretty stable.
For the SkyConnect specifically, some options have to be used (see example). There doesn't seem to be a lot of hardware-specific options in nixpkgs so I chose not to include an option for this. Do let me know if there is an appropriate pattern to use here.
```nix
services.openthread-border-router = {
radio = {
device = "/dev/serial/by-id/.....";
baudRate = 460800;
flowControl = true;
## Things done
- [x] x86_64-linux
- [x] aarch64-linux
- [ ] x86_64-darwin
- [x] Tested, as applicable:
- [x] (Module addition) Added a release notes entry if adding a new NixOS module
Reposting again, unfortunately none of these got a review last time I posted them.
I have used all three, and confirmed they are working.
master ← ambroisie:openbooks
opened 07:29PM - 01 May 25 UTC
## Things done
Not writing a module, somebody else can do that if they so wis… h.
- [X] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [25.05 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) (or backporting [24.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2411.section.md) and [25.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) Release notes)
master ← ambroisie:add-upsies
opened 01:49AM - 16 May 25 UTC
## Things done
- [X] x86_64-linux
- [ ] aarch64-… linux
- [ ] x86_64-darwin
- [X] Tested basic functionality of all binary files (usually in `./result/bin/`)
master ← ambroisie:add-trguing
opened 03:23AM - 18 May 25 UTC
## Things done
- [X] x86_64-linux
- [ ] x86_64-darwin
Add main glueviz application
master ← ifurther:glueviz
opened 06:26PM - 31 May 25 UTC
- change name for Python3package.gluviz to Python3package.glue-core
- add pytho… n3Packages.glue-qt for glue visual with qt
- add glueviz meta package
- change python3package.echo qt version
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
