PRs ready for review _
I was packaging a Windows application and need to use innoextract, so I updated iscc as well with it.
6.4.3 or 6.5.1 are not supported by current innoextract.
This is more urgent (fixes a broken build):
This is less urgent (cleans up a redundant patch & adds test):
Both are packages maintained by me, and related to the rust 1.89 bump.
e class="onebox githubpullrequest" data-onebox-src="https://github.com/NixOS/nixpkgs/pull/436024">
wire: 0.6.0 -> 0.7.0
master ← aaronjheng:wire
opened 12:19AM - 23 Aug 25 UTC
## Things done - Built on platform: - [ ] x86_64-linux - [ ] aarch6…
Fixes the evdi kernel module and user libraries for DisplayLink
Backporting this plugin to 25.05: [Backport release-25.05] yaziPlugins.recycle-bin: init at 1.0.0-unstable-2025-08-20 by nixpkgs-ci[bot] · Pull Request #437770 · NixOS/nixpkgs · GitHub
I noticed that bazel’s bootstrap step was affected by a version bump without matching hash changes, this fixes it: Update missed bazelBootstrap hashes by Quozlet · Pull Request #438781 · NixOS/nixpkgs · GitHub
Though if someone knows how this is passing tests that would be helpful; I’d rather make sure this doesn’t happen (again). The README says to tag NixOS/bazel but I’m not sure if that exists
A few month+ old PRs:
Got a couple here that have been languishing :slightly_smiling_face:
kmidimon: init at 1.4.1 by qweered · Pull Request #383204 · NixOS/nixpkgs · GitHub - 2 approvals, nixpkgs-review run successfully
Latest Clickhouse OLAP database
I’d like to change artisan-scope to build from source. I already received some feedback upon which I improved the code. Can someone look at it again so I can close (or further improve) this PR? Thanks a lot: artisan: build from source by Bohreromir · Pull Request #405028 · NixOS/nixpkgs · GitHub
Refactoring the Moneydance package (a Java desktop GUI) to allow the user to override the choice of JVM: moneydance: Allow overriding the JVM by lucasbergman · Pull Request #439592 · NixOS/nixpkgs · GitHub
Already has one approval: https://github.com/NixOS/nixpkgs/pull/433252
Init PR for a CrowdSec module. I’ve already tested it and deployed it for more than a month, and would love for it to be merged
