PRs ready for review _
Apparently the helix editor derivation wasn’t built completely from the source, in particular it used binaries from the release tarball from GitHub.
The release of solaar in nixpkgs for Logitech devices is months behind upstream:
Clean up for with lib (needs to be merged)
e class="onebox githubpullrequest" data-onebox-src="https://github.com/NixOS/nixpkgs/pull/454048">
nzbget: 25.3 -> 25.4
masterdevusb:bump/nzbget
opened 01:23AM - 21 Oct 25 UTC
## Things done - Built on platform: - [x] x86_64-linux - [ ] aarch6
I’ve updated manticoresearch here - manticoresearch: 6.2.12 -> 13.13.4, add columnar by jdelStrother · Pull Request #451922 · NixOS/nixpkgs · GitHub - it needed some shenanigans to get it compiling on GCC, since I think they just rely on clang upstream.
I could use a second opinion on:
• whether adding SSE* flags to appease GCC is the right approach
• using forked dependencies vs just reusing the built-in nixpkg versions
fixes Build failure: chiaki-ng · Issue #454777 · NixOS/nixpkgs · GitHub
