Louis
January 1, 2026, 9:49pm
6224
I opened my first PR on nixpkgs to add foldersync (https://foldersync.io/ ). I really like this app, in particular I like that the UI is the same on desktop and android.
Could someone have a look?
master ← LouisJalouzot:foldersync-desktop-init
opened 10:40AM - 30 Dec 25 UTC
Add FolderSync Desktop, a file synchronization and backup application supporting… 20+ cloud storage providers.
- Homepage: https://foldersync.io/
- License: Proprietary (unfree)
## Things done
- Built on platform:
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- Tested, as applicable:
- [x] Ran `nixpkgs-review` on this PR. See [nixpkgs-review usage].
- Nixpkgs Release Notes
- NixOS Release Notes
andersk
January 2, 2026, 6:09am
6225
Three GCC 15 build failure fixes:
master ← andersk:picat
opened 05:37AM - 02 Jan 26 UTC
Fix a `picat` [build error](https://hydra.nixos.org/job/nixos/unstable/nixpkgs.p… icat.x86_64-linux) with GCC 15, and update to the current version.
- #475479
- https://picat-lang.org/updates.txt
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] Tested basic functionality of all binary files, usually in `./result/bin/`.
master ← andersk:lingeling
opened 05:57AM - 02 Jan 26 UTC
- https://hydra.nixos.org/job/nixos/unstable/nixpkgs.lingeling.x86_64-linux
- #… 475479
- arminbiere/lingeling#11
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
master ← andersk:criterion
opened 06:06AM - 02 Jan 26 UTC
This fixes a build failure with GCC 15.
- https://hydra.nixos.org/job/nixos/u… nstable/nixpkgs.criterion.x86_64-linux
- https://github.com/Snaipe/Criterion/releases/tag/v2.4.3
- https://github.com/Snaipe/Criterion/compare/v2.4.2...v2.4.3
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
Izorkin
January 4, 2026, 7:22pm
6233
https://github.com/NixOS/nixpkgs/pull/475363
master ← Izorkin:add-nginx-multipath
opened 06:44PM - 02 Aug 25 UTC
Add support connections via Multipath TCP.
Currently supported only in `freengin… x` and `angie` packages.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] Fits [CONTRIBUTING.md], [pkgs/README.md], [maintainers/README.md] and other READMEs.
gaelj
January 4, 2026, 7:25pm
6234
This makes llama-swap work with the recently added ffmpeg convert option
master ← gaelj:llama-swap-fix-ffmeg-whisper
opened 05:12PM - 30 Nov 25 UTC
Following up on https://github.com/NixOS/nixpkgs/pull/463682, when trying to use… whisper-cpp I now get `{"error":"FFmpeg conversion failed."}% `
The log says:
[in#0 @ 0x56457df2f040] Error opening input: No such file or directory
Error opening input file whisper-server-20251121-014036-459268320.wav.
Error opening input files: No such file or directory
This change fixes the problem. If there is a better way than exposing `/tmp`, let me know and I'll be glad to implement it.
@06kellyjac @podium868909
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
Package for Labrador, a cool ~$50 oscilloscope and signal generator
EspoTek Labrador is a USB device that transforms your PC or smartphone into a fully-featured electronics lab. This repo holds all of the source code!
master ← randomizedcoder:Labrador
opened 04:20PM - 05 Jan 26 UTC
## Summary
Add [EspoTek Labrador](https://github.com/espotek-org/Labrador) - … an open-source USB device that turns your PC into a full-featured electronics lab bench with oscilloscope, signal generator, logic analyzer, and multimeter functionality.
This package builds the Qt5 desktop application for interfacing with the Labrador hardware.
### Features
- **Cross-platform**: Supports Linux (x86_64, aarch64, i686, armv7l) and macOS (Darwin)
- **Firmware updates**: Includes bundled libdfuprog library
- **Complete installation**: Firmware files, waveforms, icons, and desktop file
### udev rules (Linux)
For non-root USB access, users need to add udev rules. On NixOS:
```nix
services.udev.extraRules = ''
ENV{ID_VENDOR_ID}=="03eb", ENV{ID_MODEL_ID}=="ba94", MODE="0666"
ENV{ID_VENDOR_ID}=="03eb", ENV{ID_MODEL_ID}=="a000", MODE="0666"
ENV{ID_VENDOR_ID}=="03eb", ENV{ID_MODEL_ID}=="2fe4", MODE="0666"
### Build verification
$ nix-build -A labrador
/nix/store/...-labrador-0-unstable-2026-01-05
$ ls result/bin/
labrador
$ ldd result/bin/.labrador-wrapped | grep -E "(Qt|fftw|usb)"
libfftw3_omp.so.3 => /nix/store/...-fftw-double-3.3.10/lib/libfftw3_omp.so.3
libusb-1.0.so.0 => /nix/store/...-libusb-1.0.29/lib/libusb-1.0.so.0
libfftw3.so.3 => /nix/store/...-fftw-double-3.3.10/lib/libfftw3.so.3
libQt5PrintSupport.so.5 => /nix/store/...-qtbase-5.15.18/lib/libQt5PrintSupport.so.5
libQt5Widgets.so.5 => /nix/store/...-qtbase-5.15.18/lib/libQt5Widgets.so.5
libQt5Gui.so.5 => /nix/store/...-qtbase-5.15.18/lib/libQt5Gui.so.5
libQt5Core.so.5 => /nix/store/...-qtbase-5.15.18/lib/libQt5Core.so.5
Application launches successfully and scans for USB device (expected "DEVICE NOT FOUND" without hardware connected).
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
Yarny
January 6, 2026, 8:53am
6241
Simple update, waiting since Nov:
master ← Yarny0:foomatic-db-update
opened 06:28PM - 21 Nov 25 UTC
The only changes https://github.com/OpenPrinting/foomatic-db/pull/53 and https:/… /github.com/OpenPrinting/foomatic-db/pull/54 affects printer driver metadata.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
## `nixpkgs-review` result
Generated using [`nixpkgs-review`](https://github.com/Mic92/nixpkgs-review).
Command: `nixpkgs-review`
Commit: `fe9c43d1110dae418c02aa675923d3b4b0245fe6`
### `x86_64-linux`
<details>
<summary>:white_check_mark: 3 packages built:</summary>
<ul>
<li>foomatic-db</li>
<li>foomatic-db-ppds</li>
<li>foomatic-db-ppds-withNonfreeDb</li>
</ul>
</details>
Yethal
January 6, 2026, 10:24am
6242
Package for Tailsnitch, security auditor for Tailscale
master ← Yethal:init-tailsnitch
opened 10:18AM - 06 Jan 26 UTC
## Things done
A security auditor for Tailscale configurations.
- Built… on platform:
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
