xorrvin
March 30, 2026, 2:22pm
6655
dav-w
March 30, 2026, 4:16pm
6656
A refactor of an already existing package to build it from source.
master ← nanoyaki:suwayomi-server
opened 07:03PM - 04 May 25 UTC
This builds the package from source instead of pulling the jar from the release … binaries
Depends on https://github.com/NixOS/nixpkgs/pull/400589
## Things done
- Built on platform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [ ] `sandbox = relaxed`
- [ ] `sandbox = true`
- [x] Tested, as applicable:
- [25.05 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) (or backporting [24.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2411.section.md) and [25.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) Release notes)
Already approved, just need someone to merge it.
release-25.11 ← axodentally:backport-easyeffects
opened 02:25PM - 16 Mar 26 UTC
also backport fix for non-gnome DE: https://github.com/NixOS/nixpkgs/commit/40a4… 0fe335de5de3018d328213909521e62c2934
not cleanly backported because of: https://github.com/NixOS/nixpkgs/commit/6b612491068732c34396a47428309ee9f711353e
## Things done
- Built on platform:
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- Tested, as applicable:
- [ ] Tested basic functionality of all binary files, usually in `./result/bin/`.
- Nixpkgs Release Notes
- NixOS Release Notes
- [ ] Fits [CONTRIBUTING.md], [pkgs/README.md], [maintainers/README.md] and other READMEs.
I have opened a bunch of backports for Gnome. Both as individual backporting PRs and one that combines all into one.
The combined one is the following, with all the individual PRs linked in its initial message. I would appreciate some comments, likes or reviews on any of those to get things moving.
release-25.11 ← axodentally:backport-490335-to-release-25.11
opened 10:04PM - 28 Feb 26 UTC
This PR combines the backports of the following PRs with Gnome updates that have… been merged to master, but not to stable. The listed backports could also be merged before this PR is or alternatively closed in favor of this one, since it includes all the changes at once, but therefore is also a little more convoluted.
Anyway, here are the PRs:
- https://github.com/NixOS/nixpkgs/pull/496917
- https://github.com/NixOS/nixpkgs/pull/490335
- https://github.com/NixOS/nixpkgs/pull/483366
- https://github.com/NixOS/nixpkgs/pull/488388
- https://github.com/NixOS/nixpkgs/pull/479713
- https://github.com/NixOS/nixpkgs/pull/504985
- https://github.com/NixOS/nixpkgs/pull/467517
- https://github.com/NixOS/nixpkgs/pull/504983
- https://github.com/NixOS/nixpkgs/pull/477182
- https://github.com/NixOS/nixpkgs/pull/504982
- https://github.com/NixOS/nixpkgs/pull/485635
- https://github.com/NixOS/nixpkgs/pull/505099
- https://github.com/NixOS/nixpkgs/pull/475083
- https://github.com/NixOS/nixpkgs/pull/504998
Also includes
- https://github.com/NixOS/nixpkgs/pull/482791
- https://github.com/NixOS/nixpkgs/pull/504989
- https://github.com/NixOS/nixpkgs/pull/485764
- https://github.com/NixOS/nixpkgs/pull/504990
- https://github.com/NixOS/nixpkgs/pull/476875
- https://github.com/NixOS/nixpkgs/pull/504987
I could cherry-pick everything cleanly, except for `libglycin` from the latest 2026-02-14 updates, since much has changed for the package (see history: https://github.com/NixOS/nixpkgs/commits/master/pkgs/by-name/li/libglycin/package.nix) and since this commit: https://github.com/NixOS/nixpkgs/commit/df85a0ca0208cde603ecca36e26a57ff27d541b7 libglycin uses the gnome tarball as source instead of the gitlab.
I thought, backporting this change is not the idea of unstable/stable branch, and therefore I just updated the version with my own commit. Looking forward to feedback on this! Using nixpkgs-review I was able to build libglycin and loupe (which uses libglycin as a dependency) and tested its functionality, so it does work.
## Things done
- [x] x86_64-linux
=> only partly, see below
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] Ran `nixpkgs-review` on this PR. See [nixpkgs-review usage].
=> only of gnome papers and loupe
Hi, looking to get some updates to recyclarr merged: Recyclarr update by josephst · Pull Request #493140 · NixOS/nixpkgs · GitHub
Upstream version updated to v8 with some breaking changes that required modifying the NixOS module, so a simple update by rryan-tm isn’t possible here.
Prisma 7.5.0 → 7.6.0:
master ← Daste745:prisma-7-6-0
opened 05:01PM - 30 Mar 26 UTC
https://github.com/prisma/prisma/releases/tag/7.6.0
https://github.com/prisma/p… risma-engines/releases/tag/7.6.0
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] [Package tests] at `passthru.tests`.
Also, a backport to 25.11 is ready for Prisma 7.5.0:
release-25.11 ← backport-492456-to-release-25.11
opened 03:36AM - 28 Mar 26 UTC
Bot-based backport to `release-25.11`, triggered by a label in #492456.
**Befor… e merging, ensure that this backport is [acceptable for the release](https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md#changes-acceptable-for-releases).**
Even as a non-committer, if you find that it is not acceptable, leave a comment.
> [!TIP]
> If you maintain all packages touched by this pull request, and they are all located under `pkgs/by-name/*`, you can comment **`@NixOS/nixpkgs-merge-bot merge`** to automatically merge this PR using the [`nixpkgs-merge-bot`](https://github.com/NixOS/nixpkgs/blob/master/ci/README.md#nixpkgs-merge-bot).
imcquee
April 1, 2026, 11:59am
6667
Not my PR but I use this golang tool and reviewed it. Thanks for anyone who could review it!
master ← m7medVision:add-lazycommit
opened 03:32PM - 30 Jan 26 UTC
### Motivation for this change
New package: `lazycommit` - [brief description… of what lazycommit does and why it's useful]
### Things done
- [x] Built a runtime test using `nix-build -A lazycommit`
- [x] Ensured that relevant documentation is up to date
#### Testing
- [x] Tested using sandboxing ([nix.conf](https://nixos.org/manual/nix/stable/command-ref/conf-file#conf-sandbox) `sandbox = true`)
- [x] Built on platform(s):
- [x] x86_64-linux
- [x] aarch64-linux
- [x] x86_64-darwin
- [x] aarch64-darwin
- [x] Tested compilation of all packages that depend on this change using `nix-shell -p nixpkgs-review --run "nixpkgs-review wip"`
Prisma 6.19.1 → 6.19.3 (latest bumps the effect dependency, which resolves a vulnerability):
master ← Daste745:prisma-6-19-3
opened 12:23PM - 01 Apr 26 UTC
https://github.com/prisma/prisma/compare/6.19.1...6.19.3
https://github.com/pri… sma/prisma-engines/compare/6.19.1...6.19.3
https://github.com/prisma/prisma/releases/tag/6.19.3 bumps the `effect` dependency, which resolves a vulnerability.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
stv0g
April 1, 2026, 1:40pm
6669
Just missing another reviewer. 1 approval already given:
master ← stv0g:init-chirpstack-gateway-mesh
opened 10:49AM - 20 Mar 26 UTC
ChirpStack Gateway Mesh is a software component that can turn a LoRa® gateway in… to a relay. This makes it possible to extend the LoRa coverage, without the need to connect each LoRa gateway to the internet.
## Things done
- [x] x86_64-linux
- [x] aarch64-linux
- [ ] x86_64-darwin
This PR got one review comment about a week ago, which I’ve replied to. Could use another look
master ← MysteryBlokHed:pkgs/opentxl/use-pregenerated-csrc
opened 09:44PM - 18 Mar 26 UTC
Previously, the derivation for this package would clone the source repo and run … a codegen tool as part of the build process. However, the codegen tool only supports x86 architectures, while the emitted C is platform-agnostic. This PR allows the package to build on more platforms by instead fetching just the generated source .tar.gz from GitHub releases.
## Things done
- [x] x86_64-linux
- [x] aarch64-linux
- [x] x86_64-darwin
this PR has been waiting since december last year
master ← Mistyttm:refactor-mautrix-discord
opened 05:20AM - 11 Dec 25 UTC
After fixing the registration bug I determined that the module was way too verbo… se and did not need to provide all of the options provided in the application. I've stopped explicitly declaring all options that aren't needed to make a basic version of the module function. The assertions have also been updated to mirror this fact and will alert a user when the specific required options are unset. A new documentation file was also added as this module, like other mautrix modules, is quite complex and may need more explaining. I have also made a lot of option descriptions more concise
I am also on the fence about adding this default declaration in the config:
```nix
services.mautrix-discord.settings = {
homeserver = lib.mkDefault {
software = "standard";
status_endpoint = null;
message_send_checkpoint_endpoint = null;
async_media = false;
websocket = false;
ping_interval_seconds = 0;
appservice = lib.mkDefault {
hostname = "0.0.0.0";
database = {
type = "sqlite3";
uri = "file:${cfg.dataDir}/mautrix-discord.db?_txlock=immediate";
max_open_conns = 20;
max_idle_conns = 2;
max_conn_idle_time = null;
max_conn_lifetime = null;
id = "discord";
bot = {
username = "discordbot";
displayname = "Discord bridge bot";
avatar = "mxc://maunium.net/nIdEykemnwdisvHbpxflpDlC";
ephemeral_events = true;
async_transactions = false;
as_token = default_token;
hs_token = default_token;
bridge = lib.mkDefault {
username_template = "discord_{{.}}";
displayname_template = "{{if .Webhook}}Webhook{{else}}{{or .GlobalName .Username}}{{if .Bot}} (bot){{end}}{{end}}";
channel_name_template = "{{if or (eq .Type 3) (eq .Type 4)}}{{.Name}}{{else}}#{{.Name}}{{end}}";
guild_name_template = "{{.Name}}";
private_chat_portal_meta = "default";
public_address = null;
avatar_proxy_key = "generate";
portal_message_buffer = 128;
startup_private_channel_create_limit = 5;
delivery_receipts = false;
message_status_events = false;
message_error_notices = true;
restricted_rooms = true;
autojoin_thread_on_open = true;
embed_fields_as_tables = true;
mute_channels_on_create = false;
sync_direct_chat_list = false;
resend_bridge_info = false;
custom_emoji_reactions = true;
delete_portal_on_channel_delete = false;
delete_guild_on_leave = true;
federate_rooms = true;
prefix_webhook_messages = true;
enable_webhook_avatars = false;
use_discord_cdn_upload = true;
cache_media = "unencrypted";
direct_media = {
enabled = false;
allow_proxy = true;
server_key = "generate";
animated_sticker = {
target = "webp";
args = {
width = 320;
height = 320;
fps = 25;
double_puppet_server_map = { };
double_puppet_allow_discovery = false;
login_shared_secret_map = { };
command_prefix = "!discord";
management_room_text = {
welcome = "Hello, I'm a Discord bridge bot.";
welcome_connected = "Use `help` for help.";
welcome_unconnected = "Use `help` for help or `login` to log in.";
additional_help = "";
backfill = {
forward_limits = {
initial = {
dm = 0;
channel = 0;
thread = 0;
missed = {
dm = 0;
channel = 0;
thread = 0;
max_guild_members = -1;
encryption = {
allow = false;
default = false;
appservice = false;
msc4190 = false;
require = false;
allow_key_sharing = false;
plaintext_mentions = false;
delete_keys = {
delete_outbound_on_ack = false;
dont_store_outbound = false;
ratchet_on_decrypt = false;
delete_fully_used_on_decrypt = false;
delete_prev_on_new_session = false;
delete_on_device_delete = false;
periodically_delete_expired = false;
delete_outdated_inbound = false;
verification_levels = {
receive = "unverified";
send = "unverified";
share = "cross-signed-tofu";
rotation = {
enable_custom = false;
milliseconds = 604800000;
messages = 100;
disable_device_change_key_rotation = false;
provisioning = {
prefix = "/_matrix/provision";
shared_secret = "generate";
debug_endpoints = false;
permissions = {
"*" = "relay";
logging = lib.mkDefault {
min_level = "info";
writers = [{
type = "stdout";
format = "pretty-colored";
time_format = " ";
It's basically just the example config that is generated by default on normal linux systems, however it does bloat the file quite a bit. The upside to having the entire config be generated like this is if a user were to go double check the configuration file that nixos made they may see some defaults for the application they may want to change. This config would just ensure that every option in the program is set. But again, very torn on actually including it.
## Things done
- [X] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [X] [NixOS tests] in [nixos/tests].
- [X] Ran `nixpkgs-review` on this PR. See [nixpkgs-review usage].
- [X] Fits [CONTRIBUTING.md], [pkgs/README.md], [maintainers/README.md] and other READMEs.
release-25.11 ← backport-502759-to-release-25.11
opened 12:44AM - 31 Mar 26 UTC
Bot-based backport to `release-25.11`, triggered by a label in #502759.
> [!TIP]
Automatic backport to fix build issues in fceux. The original PR has already been merged.
