Just a simple package upgrade
master ← nanoyaki:pangolin-cli/update
opened 02:55PM - 14 Apr 26 UTC
Updated the package and set the required flag for setting the version
## … Things done
- Built on platform:
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- Tested, as applicable:
- Nixpkgs Release Notes
- NixOS Release Notes
I have a long standing PR to add some features + fixes related to supporting NixOS RFC108 imperative containers. The implementation recently got overhauled and I believe it is in a really good state now with tests written for all major changes.
master ← m1cr0man:rfc108-minimal
opened 05:26PM - 12 Feb 23 UTC
###### Description of changes
This is a fork of #140669 in a minified and ref… actored form covering the changes which cannot be placed in a separate flake.
I have been working on [python-nixos-nspawn](https://github.com/m1cr0man/python-nixos-nspawn) which implements all the components for managing imperative RFC108 style containers. I have been able to refactor almost all parts of the original POC to work within this repo/flake however I could not find a satisfactory way to otherwise apply the changes covered in this PR.
- Skip some more mountpoints within containers which are covered by systemd-nspawn
- Avoid altering imperative containers and add the necessary logic to handle declarative containers in switch-to-configuration
With this, it would be possible to use python-nixos-nspawn as a tool or module to manage RFC108 containers on any system with networkd enabled + configured appropriately.
###### TODO
None - all done
###### Things done
- Built on platform(s)
- [X] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [X] Tested, as applicable:
- [X] Tested basic functionality of all binary files (usually in `./result/bin/`)
- [23.05 Release Notes (or backporting 22.11 Release notes)](https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md#generating-2305-release-notes)
- [X] Fits [CONTRIBUTING.md](https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md).
CC @ma27
Bumping this, I opened it two weeks ago. https://github.com/NixOS/nixpkgs/pull/504779 introduces Headlamp, a K8s client.
pbek
April 15, 2026, 11:36am
6746
master ← pbek:feature/sonar
opened 09:46PM - 20 Mar 26 UTC
Add package for [sonar](https://github.com/raskrebs/sonar), a CLI tool for inspe… cting and managing services listening on localhost ports.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
A CLI tool for inspecting and managing services listening on localhost ports.
Would like to get this in if possible, it has the support of the Flutter team
master ← hacker1024:flutter-refactor-revert
opened 11:00AM - 12 Apr 26 UTC
This PR reverts #500309.
I appreciate and welcome @kyehn's effort and contrib… utions, but I do not think this PR was in a state suitable to merge. Most importantly, I think it changes too much in a single commit. This makes the several different new ideas included in the PR difficult to discuss, review, and debug for the existing maintainers. I would like to see it split up into several commits or even PRs so we can discuss the changes in more detail. I do not necessarily agree with all of them.
There are also several bugs caused by the PR. While it is possible to fix these individually (and there are even some open PRs), I'd rather deal with those when we look at the original PR again.
[Additional context](https://github.com/NixOS/nixpkgs/pull/500309#issuecomment-4196517482)
- Closes #507700
- Closes #508402
- Closes #508415
- Closes #507712
- Closes #508396
CC @limwa
## Things done
- [x] x86_64-linux
- [x] aarch64-linux
- [ ] x86_64-darwin
