master ← donottellmetonottellyou:donottellmetonottellyou/legendsviewer-next
opened 03:14PM - 10 May 25 UTC
## Add legendsviewer-next
### Commits
- maintainers: add donottellmetnotte… llyou
- legendsviewer-next: init at 1.2.0
### Description
[LegendsViewer-Next](https://github.com/Kromtec/LegendsViewer-Next) is a cross-platform revamp (by the same author) of the [original Windows-only LegendsViewer](https://github.com/Kromtec/LegendsViewer), a legends-mode explorer for the indie game Dwarf Fortress. LegendsViewer-Next supports world information overviews, maps, populations, war/battle death tolls, and has a very user-friendly interface.
LegendsViewer-Next hosts a web app on port 8081 with the api on port 5054. Its configuration on Linux is stored at `~/.config/LegendsViewer`, currently only `bookmarks.json`.
### Tests
Currently, there is one unit test, which makes sure the frontend serves an html document and the backend reports the correct version, and both are working.
## Things done
- Built on platform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- ~~[ ] `sandbox = relaxed`~~
- [x] `sandbox = true`
- [x] Tested, as applicable:
- ~~[NixOS test(s)](https://nixos.org/manual/nixos/unstable/index.html#sec-nixos-tests) (look inside [nixos/tests](https://github.com/NixOS/nixpkgs/blob/master/nixos/tests))~~
- ~~or, for functions and "core" functionality, tests in [lib/tests](https://github.com/NixOS/nixpkgs/blob/master/lib/tests) or [pkgs/test](https://github.com/NixOS/nixpkgs/blob/master/pkgs/test)~~
- ~~made sure NixOS tests are [linked](https://github.com/NixOS/nixpkgs/blob/master/pkgs/README.md#linking-nixos-module-tests-to-a-package) to the relevant packages~~
- [25.05 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) (or backporting [24.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2411.section.md) and [25.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) Release notes)
- ~~[ ] (Package updates) Added a release notes entry if the change is major or breaking~~
- ~~[ ] (Module updates) Added a release notes entry if the change is significant~~
- ~~[ ] (Module addition) Added a release notes entry if adding a new NixOS module~~
The new release of LegendsViewer-Next 1.2.5 came out 5 days ago, and tomorrow is the 1 year anniversary of the PR!
With this cumulative release comes several notable improvements, including:
A favorites bar!
Advanced filtering!
And in addition, some Unix-specific improvements were made, including a better default folder starting location and the ability to open the hidden steam directory. Better handling of multiple backends opening allows the desktop entry to avoid launching the program in a terminal.
Finally, this version does not come with an OSX downloadable release: if this PR is merged it will be the only way to install on OSX without installing from source!
Dwarf Fortress is a popular deep simulation and storytelling game available on Linux and WIndows, along with having a free version and being playable on OSX using Steam. LegendsViewer-Next is a rewrite by the same author of the original LegendsViewer, which enables easier searching of in-game histories and storytelling elements.
Please review my rather large PR for creating a module to run and configure qbit-manage
Thank you for your time.
https://github.com/NixOS/nixpkgs/pull/495731
release-25.11 ← backport-517908-to-release-25.11
opened 07:08AM - 08 May 26 UTC
Bot-based backport to `release-25.11`, triggered by a label in #517908.
**Befor… e merging, ensure that this backport is [acceptable for the release](https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md#changes-acceptable-for-releases).**
Even as a non-committer, if you find that it is not acceptable, leave a comment.
> [!TIP]
> If you maintain all packages touched by this pull request, and they are all located under `pkgs/by-name/*`, you can comment **`@NixOS/nixpkgs-merge-bot merge`** to automatically merge this PR using the [`nixpkgs-merge-bot`](https://github.com/NixOS/nixpkgs/blob/master/ci/README.md#nixpkgs-merge-bot).
Automatic backport for the Brazilian goverment tax report. Thanks.
beviu
May 12, 2026, 7:09am
6894
staging ← beviu:substitute-bcachefs
opened 01:57PM - 15 Apr 26 UTC
Substitute the `bcachefs` command in `nixos-generate-config.pl` instead of relyi… ng on its availability in PATH (similar to https://github.com/NixOS/nixpkgs/pull/180603).
Fixes #291843.
## Things done
- Built on platform:
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- Tested, as applicable:
- Nixpkgs Release Notes
- NixOS Release Notes
Small PR to fix nixos-generate-config.pl expecting bcachefs to be in PATH
I would like to keep this package up to date, and therefore I wanna become its maintainer.
The PR is sitting there for over a week.
master ← ArtifyCZ:update-openttd-jgrpp
opened 09:05PM - 03 May 26 UTC
- Updated the openttd-jgrpp package from 0.69.2 to 0.72.0
- Added myself as a m… aintainer of the openttd-jgrpp package
## Things done
- [X] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [X] Tested basic functionality of all binary files, usually in `./result/bin/`.
